A9K - Route Scale on FIB
Pedro Morais
Hello XR Gurus,
We are currently doing some tests with internet full routing inside two VRFs and we are encountering some issues that we would like you to help.
Scenario:
IOS-XR with 4.2.3 P image
Trident LCs
RSP-4G
Only Two VRFs configured on the box, both with full routing
Issue:
We are sending 450K V4 prefixes, plus 25K V6 prefixes with 65K /24 prefixes per each /8, which should be inside the subtree limits. Still we are getting the following error message:
LC/0/0/CPU0:Feb 19 16:42:55.833 : prm_server_tr[295]: %PLATFORM-NP-3-OOR : Routing Table Full : PRM failed to install a route (114.255.239.0/24) because the subtree  was full. Each subtree is limited to 262144 routes per subtree.Subtree where install failed is 114.0.0.0/8
Although, we get this error message we can see the prefix installed on CEF HW:
RP/0/RSP0/CPU0:A9K-LAB02#
RP/0/RSP0/CPU0:A9K-LAB02#show cef vrf publico hardware ingress location 0/4/CPU0 | i 114.255.239.0/24
Tue Feb 19 17:04:40.589 WET
114.255.239.0/24    101.101.101.2       <recursive>
Can anyone help us???
Thanks!!!
Cheers,
Pedro
5 Replies 5
Parthiv Shah
Let us know what smu running on your router. Following output might be useful
show platform
show install active summary
Also check you have all the SMU recommended @
http://www.cisco.com/web/Cisco_IOS_XR_Software/pdf/ASR9000_423_Release_Recommendation.pdf
Parthiv
Hi Parthiv,
Yes we have pretty much all the recommended SMUs installed. Requested outputs are below:
RP/0/RSP0/CPU0:A9K-LAB02(admin)#show platform
Wed Feb 20 10:32:46.135 WET
Node           Type                     State           Config State
0/RSP0/CPU0     A9K-RSP-4G(Active)       IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP-4G(Standby)       IOS XR RUN       PWR,NSHUT,MON
0/FT0/SP       FAN TRAY                READY
0/FT1/SP       FAN TRAY                 READY
0/0/CPU0       A9K-4T-B                 IOS XR RUN       PWR,NSHUT,MON
0/1/CPU0       A9K-4T-B                 IOS XR RUN       PWR,NSHUT,MON
0/4/CPU0       A9K-40GE-B               IOS XR RUN       PWR,NSHUT,MON
0/PM0/SP       A9K-2KW-DC               READY           PWR,NSHUT,MON
0/PM1/SP       A9K-2KW-DC               READY           PWR,NSHUT,MON
0/PM3/SP       A9K-2KW-DC               READY           PWR,NSHUT,MON
0/PM4/SP      A9K-2KW-DC               READY           PWR,NSHUT,MON
RP/0/RSP0/CPU0:A9K-LAB02(admin)#show install active summary
Wed Feb 20 10:32:47.822 WET
Default Profile:
SDRs:
   Owner
Active Packages:
   disk0:asr9k-p-4.2.3.CSCud37351-1.0.0
   disk0:asr9k-p-4.2.3.CSCud29892-1.0.0
   disk0:asr9k-mini-p-4.2.3
   disk0:asr9k-doc-p-4.2.3
   disk0:asr9k-p-4.2.3.CSCub22596-1.0.0
   disk0:asr9k-k9sec-p-4.2.3
   disk0:asr9k-p-4.2.3.CSCuc17410-1.0.0
   disk0:asr9k-mpls-p-4.2.3
   disk0:asr9k-mgbl-p-4.2.3
   disk0:asr9k-mcast-p-4.2.3
   disk0:asr9k-p-4.2.3.CSCud07536-1.0.0
   disk0:asr9k-p-4.2.3.CSCub74517-1.0.0
   disk0:asr9k-p-4.2.3.CSCub96985-1.0.0
   disk0:asr9k-p-4.2.3.CSCud54093-1.0.0
Thanks!!
Could you try following config.
vrf <>
mode big
Please provide following
show cef ipv4 summary location all
show cef ipv6 summary location all
show tech cef
Parthiv
Hi Parthiv,
Strangely (or not) it worked with "mode big"... However I do not understand why, since I only have two VRFs configured on the router. Any idea?
Do you still want the requested outputs?
Cheers,
Pedro
Hi Parthiv,
we did some more tests with and without "mode big". Please take a look at the bellow output:
RP/0/RSP0/CPU0:A9K-LAB02#conf t
RP/0/RSP0/CPU0:A9K-LAB02(config)#vrf telepac
RP/0/RSP0/CPU0:A9K-LAB02(config-vrf)#mode big
RP/0/RSP0/CPU0:A9K-LAB02(config-vrf)#commit
Fri Feb 22 15:37:16.352 WET
RP/0/RSP0/CPU0:A9K-LAB02#show uid data location 0/4/CPU0 GigabitEthernet0/4/0/23 ingress | i Table Fri Feb 22 15:38:42.259 WET
  Table ID                         0x200
Fri Feb 22 15:39:51.002 WET
RP/0/RSP0/CPU0:A9K-LAB02(config-vrf)#no mode big
Fri Feb 22 15:39:57.583 WET
RP/0/RSP0/CPU0:A9K-LAB02#show uid data location 0/4/CPU0 GigabitEthernet0/4/0/23 ingress | i Table Fri Feb 22 15:40:00.285 WET
  Table ID                         0x1200
Fri Feb 22 15:40:15.187 WET
Fri Feb 22 15:40:19.577 WET
RP/0/RSP0/CPU0:A9K-LAB02(config-vrf)#exit
RP/0/RSP0/CPU0:A9K-LAB02(config)#exit
Fri Feb 22 15:40:23.947 WET
  Table ID                         0x300
RP/0/RSP0/CPU0:A9K-LAB02#admin
Fri Feb 22 15:40:28.559 WET
RP/0/RSP0/CPU0:A9K-LAB02(admin)#reload location all Fri Feb 22 15:40:32.356 WET
Preparing system for backup. This may take a few minutes especially for large configurations.
        Status report: node0_RSP0_CPU0: START TO BACKUP
        Status report: node0_RSP0_CPU0: BACKUP HAS COMPLETED SUCCESSFULLY [Done] Proceed with reload? [confirm]
This node received reload command. Reloading in 5 secs
Connection to 172.25.200.6 closed by foreign host.
bash-3.00#
bash-3.00#
bash-3.00#
bash-3.00# telnet 172.25.200.6
Trying 172.25.200.6...
Connected to 172.25.200.6.
Escape character is '^]'.
User Access Verification
Username: admin
Password:
Fri Feb 22 15:58:04.109 WET
  Table ID                         0x200
Any comment?
Cheers,
PM
