SNMP help with IOS XR 4.0.0
easinab01
I need to extract the following information through SNMPWALK. Can you please help me with the OIDs that can get me the exact information?
1.      The Information About The Router
                    -Ip Address,
                      -Description,
2        Platform
3.      Number of ports on each interfaces
4.      Type of Each port (For eg., Fiber, 10gig, 1gig,100mbps)
5.      Status of each port Whether UNI or NNI
6.      If Port is NNI then IP of the router at other end
7.      VLans Added to each port
8.      Address of each router / LAT/LONG (if available)
Parthiv Shah
There are various MIBS and OIDs which you need to use for your different/different item or you can do complete snmpwalk and find all the information. SNMPWALK might be sometime cpu intensive so be creaful while running in production network.
You can find list of ASR9K supported MIBs @
ftp://ftp.cisco.com/pub/mibs/supportlists/asr9000/asr9000-supportlist.html#Supported_and_Verified_MIBs_XE_4_2_X
IF MIB is @  ftp://ftp.cisco.com/pub/mibs/v2/IF-MIB.my
Parthiv
