ASA 5525 EEM
1pgordo
I want to write in the event manager if the ping is not successful (Success rate is 0 percent), then you need to execute clear crypto ikev2 sa "x.x.x.x" Check available IP once every 3-5 minutes. Maybe someone will share the script.
you face issue with child SA ?
if Yes try ping from LAN to LAN, this make IKEv2 have always child SA
MHM
Ruben Cocheno
@1pgordo
Check this https://github.com/leonmflai/Cisco-EEM-Auto-Export
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
