Ask the Expert: IOS-XR Architecture and Troubleshooting
Monica Lluis
Level 9
Level 9
This session will provide an opportunity to learn and ask questions about Cisco IOS XR Software architecture which is modular and fully distributed network operating system used by most of the leading service providers in the industry. IOS XR is widely used in big platforms like GSR, CRS, NCS and ASR9K etc. You will also learn different troubleshooting scenarios and use cases on Cisco IOS XR Infrastructure, Configuration Management, XR Monitoring and Operations, process crash decode etc. c.
To participate in this event, please use the Reply Button to ask your question.
Ask questions from Monday June 6 to Friday June 17, 2016
Featured Experts
Raj Pathak is a customer support engineer in High-Touch Technical Services at Cisco specializing in service provider technologies and platforms. He serves as a support engineer for technical issues supporting Cisco IOS XR Software customers on Cisco CRS, ASR 9K and Cisco XR 12000 Series Routers. Raj has more than 10 years of experience in the IT industry and holds double CCIE certification (38760) in routing and switching and Data Center. He has already delivered webcast and other ask the expert session on cisco support community.
Sudhir Kumar is a customer support engineer in High-Touch Technical Services at Cisco specializing in service provider technologies and platforms. His areas of expertise include Cisco GSR, CRS, ASR 9K and Cisco XR 12000 Series Routers. Sudhir has more than 12 years of experience in the IT industry and holds CCIE certification (35219) in Service provider and Routing and switching and Data Centers. He has already delivered webcast and other ask the expert session on cisco support community.
Find other  https://supportforums.cisco.com/expert-corner/events.
** Ratings Encourage Participation! **
Please be sure to rate the Answers to Questions
https://supportforums.cisco.com/expert-corner/events ">https://supportforums.cisco.com/expert-corner/events.
We look forward to your participation. This event is open to all, including partners. Please Share this event in your social channels. Have a technical question? Get answers here before opening a TAC case by visiting the Cisco Support Community.
I hope you and your love ones are safe and healthy
Monica Lluis
Community Manager Lead
58 Replies 58
Hello Wilson,
A cosmetic bug is something that doesn't effect the functionality. For example you are not getting proper output of expected command output but it is actually NOT impacting any service.
Raj Pathak
Hi Raj
But that "Bug cosmetic" will always exist or have to be resolved at the time by TAC staff.
Wilson V.
Hello Wilson,
Bug Is condition where things (H/W or S/W) not working as expected. so bugs can be seen any point of time, however few of them doesn't effect the functionality of the system hence they are called cosmetics bug. For example some errors messages is coming on the router which is not service impacting but customer can still talk to TAC to find out the reasons behind that and if TAC says it Cosmetic BUG they don't have to worry about it.
HTH.
Raj Pathak
I have a question.
I have two remote offices on VLAN 50 but not on same subnet. Both offices have AP flexconnect in VLAN 50.
  • Office 1: 10.1.0.0 /24
  • Office 2: 10.2.0.0 /24
WLC is in office 1 with IP address 10.1.0.250. Wi-Fi users in office 2 will have IP adress in 10.1.0.0 /24 or 10.2.0.0 /24 in order to have connectivity ?
Best regards.
Hi Olivier,
Greetings
I understand your query is related to flexconnect product and WLC. This forum is for IOS-XR architecture. I would suggest you to use the right forum according to technology and product. I am not seeing any expert event on flexconnect or WLC nearby. You can put your question on Cisco Support community or open a TAC case with Cisco.
Sudhir Kumar
foysol_bgd
Hi Experts,
Would you please provide me a link to understand more about the CSM tool. I already checked this link http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/smu/csmuser.html
1. I downloaded CSM 3.2. Would you please confirm that this will support 9904?
2. The link describes the windows installation process but I could not able to located .cmd file when I unzip csm 3.2.
3. What tcp/udp ports we need to open if there is a firewall in the path.
4. If I want to manually track the SMU/PIE/Service pack etc. what is the best way?
Hi Foysol,
CSM 3.2 is linux based, CSM 2.x is Windows based, for windows download it, right click and unzip it and install it.
For 3.2. linux, you do need to follow the install instructions inside the pdf file.
CSM is the best method to manage upgrades, smus and services packs.
To HTTP into CSM, its over port 5000. From CSM to the routers allow telnet or SSH through the firewalls.
Eddie.
Thank you Eddie,
My plan to install the CSM on our NMS systems. Which don't have direct access to internet.
I have to install this in NMS because NMS allowed to access the devices. I understand CSM needs to talk with Cisco site to get the updates. Would you please provide some details how CSM communicates with Cisco.
I tried the ACT tool and understand now this is NOT supported by Cisco anymore. Would you please confirm that CSM version 2.X will not be obsolete soon.
CSM uses HTTP to talk to Cisco.com. CSM will not be obsolete anytime soon, its very heavily used by customers.
Eddie.
Thanks Eddie.
Hi Eddie,
I installed CSM 2.0 and looks good. I was able to see the recommended and optional SMU list. But when I tried to download the SMUs I received an error. I definitely can download the SMU manually from cisco.com.
Foysol,
You need to accept the cisco software use agreement i believe, you may have not done it for a while. Go to the bottom of the below link, accept it, wait 24h and try again.
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html
Eddie.
If you have follow up questions on this topic, please feel free to post the question on the community. This event is closing at this point. Thank you for your participation.
Monica Lluis
Community Mgr.
Monica Lluis
Hi Foysol,
You can also refer this link for CSM.
https://supportforums.cisco.com/document/12554686/smu-list-through-cisco-software-manager-csm-recommended-smu-list-using-csm
Sudhir Kumar
