ASR 9000 configuration backup
jorgensor
Need a simple script (TCL/EEM) that backs up running-config of an ASR9k router on a daily basis.
Destination FTP och SFTP via a VRF
/Jorgen
6 Replies 6
xthuijs
this is maybe even nicer, we set a trigger on the MGBL commit from XR and then trigger a config backup right away:
event syslog pattern "%MGBL-CONFIG-6-DB_COMMIT : Configuration committed by user"
for more detail on the setup of eem check here:
https://supportforums.cisco.com/document/59496/using-embedded-event-manager-eem-ios-xr-asr9000-simulate-ecmp-min-links
here is an example script:
::cisco::eem::event_register_syslog
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set arr_einfo [event_reqinfo]
if [catch {cli_open} result] {
    error $result $errorInfo
} else {
    array set cli1 $result
array set _sinfo [sys_reqinfo_routername]
set _info_routername $_sinfo(routername)
if [catch {cli_write $cli1(fd) "copy run tftp"} _cli_result] {
    error $_cli_result $errorInfo
if [catch {cli_read_pattern $cli1(fd) "Address"} _cli_result] {
if [catch {cli_write $cli1(fd) "w.x.y.z"} _cli_result] {
if [catch {cli_read_pattern $cli1(fd) "filename"} _cli_result] {
if [catch {cli_exec $cli1(fd) } _cli_result] {
action_syslog msg
# Close open cli before exit.
catch {cli_close $cli1(fd) $cli1(tty_id)} result
namnguyenptit
I have this problem too
Can anyone help us?
What problem are you having? How about you configure the router to do the backup each time the config is changed, take a look at the following:
https://supportforums.cisco.com/document/12735651/xr-configuration-auto-backup
Eddie.
Thankyou!
But one more thing. When I use auto-save command there's a problem:
my ftp server's name: cisco
Password: snoc@123
When I excute the command: configuration commit auto-save filename ftp://cisco:snoc@123@192.168.1.1/config.cfg
The system cant understand the server IP 192.168.1.1 but 123@192.168.1.1
Is there anyway to troubleshoot this? (I cant change password because it is related to many other things).
Thanks!
Break it down as such and see if it works. Else you might need to change the password:
configuration commit auto-save filename ftp://123.29.0.147/config.cfg
ftp client password snoc@123
ftp client username cisco
let me know how it goes.
Eddie.
It's OK now.
Thanks verymuch!
