ASR 9000 ISM No translation entry drops
Hi all!!
We set up ISM on ASR 9000 in nat44 mode. All works fine, but No translation entry drops grows as I can see in
sh cgn nat44 NAT1 statistics
Can you explain me why does it happens and which troubles will I expect?
Or may be there is a way to avoid these drops....
service cgn CGN1
service-location preferred-active 0/7/CPU0
service-type nat44 NAT1
  portlimit 5000
  alg ActiveFTP
  inside-vrf insidevrf1
   map outsideServiceApp ServiceApp2 address-pool x.x.x.x/25
   external-logging netflow version 9
    server
     address 10.11.13.28 port 9996
Statistics summary of NAT44 instance: 'NAT1'
Number of active translations: 11016
Number of sessions: 650
Translations create rate: 47
Translations delete rate: 0
Inside to outside forward rate: 1122
Outside to inside forward rate: 1595
Inside to outside drops port limit exceeded: 0
Inside to outside drops system limit reached: 0
Inside to outside drops resource depletion: 0
No translation entry drops: 15579
PPTP active tunnels: 0
PPTP active channels: 0
PPTP ctrl message drops: 0
Number of subscribers: 1726
Drops due to session db limit exceeded: 0
Drops due to source ip not configured: 0
Pool address totally free: 0
Pool address used: 128
somnathr
Hi Andrew,
This counter indicates:
Number of times Outside-to-Inside packets (TCP + UDP + ICMP, Static + Dynamic) dropped because there is no NAT DB entry corresponding to the Destination IP and L4 Port.
Please check your static route and ensure only the packets with destination address matching with public IP pool is sent to outside service app interface.
Alternatively, some of those entries could be timed out as well so when the O2I packets reach, it does not find a NAT DB entry and gets dropped.
You can refer the following guides as well to check out some other relevant commands (like, 'show .. outside-translations'):
Config guide - http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.3/cg_nat/configuration/guide/cgnat_43.html
Command Ref guide - http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.3/cg_nat/command/reference/b_cgnat_cr43xasr9k.html
regards,
Somnath.
Hi Somnath!
May be these drops appears because of small sesion timeout of port translations?
I.e. translation is already closed but traffic from internet still comes to it.
All timeout values are default.
