ASR 9001 BNG IPoE problems
Goergi Genov
I have read and try these guides
https://supportforums.cisco.com/docs/DOC-23170
https://supportforums.cisco.com/docs/DOC-19702
https://supportforums.cisco.com/docs/DOC-19726
But have some problems , here is my config ( almost same like the guides )
radius-server host xxx.xxx.xxx.46 auth-port 1812 acct-port 1813
aaa server radius dynamic-author
port 3799
client yyy.yyy.yyy.102 vrf default
client xxx.xxx.xxx.46 vrf default
aaa attribute format MY_AUTH
mac-address
aaa attribute format NAS_PORT_FORMAT
circuit-id plus remote-id separator .
aaa radius attribute nas-port format e SSAAPPPPQQQQQQQQQQVVVVVVVVVVUUUU type 32
aaa radius attribute nas-port-id format NAS_PORT_FORMAT
aaa group server radius RADIUS_GR
server xxx.xxx.xxx.46 auth-port 1812 acct-port 1813
source-interface Loopback0
aaa authorization network default group RADIUS_GR
aaa accounting subscriber default group RADIUS_GR
aaa authorization subscriber AUTH_GR group RADIUS_GR
aaa authorization subscriber default group RADIUS_GR
aaa authorization subscriber RADIUS_GR group RADIUS_GR
aaa authentication subscriber default group RADIUS_GR
aaa accounting update periodic 10
dhcp ipv4
profile IP_DEFAULT proxy
  class IP_DEFAULT
   helper-address vrf default yyy.yyy.yyy.102 giaddr zzz.zzz.zzz.1
  relay information option
  relay information policy keep
  relay information option allow-untrusted
   interface Bundle-Ether100.361 proxy profile IP_DEFAULT
ipv4 access-list PERM_ALL
10 permit ipv4 any any
20 permit icmp any any
30 permit ipv4 any any
bundle load-balancing hash dst-ip
ipv4 point-to-point
ipv4 unnumbered Loopback100
service-policy type control subscriber IP_PM
encapsulation dot1q 361
ipsubscriber ipv4 l2-connected
  initiator dhcp
interface Loopback0
ipv4 address ccc.ccc.ccc.174 255.255.255.255
interface Loopback100
description 4dhcp
ipv4 address zzz.zzz.zzz.1 255.255.255.0
interface TenGigE0/0/2/0
bundle id 100 mode on
interface TenGigE0/0/2/1
dynamic-template
type ipsubscriber IPSUB_TPL
  ipv4 access-group PERM_ALL ingress
  ipv4 access-group PERM_ALL egress
class-map type control subscriber match-any DHCP
match protocol dhcpv4
end-class-map
policy-map type control subscriber IP_PM
event session-start match-first
  class type control subscriber DHCP do-until-failure
   5 activate dynamic-template IPSUB_TPL
   10 authorize aaa list AUTH_GR format MY_AUTH password cisco
end-policy-map
Without  service-policy type control subscriber IP_PM on the interface , CPE gets ip address and all works.
The radius server is configured always to autothenticate with access-accept but there are errors
  Total Deadtime: 0s Last Deadtime: 0s
  Timeout: 5 sec, Retransmit limit: 3
  Quarantined: No
  Authentication:
    468 requests, 1 pending, 154 retransmits
    0 accepts, 0 rejects, 0 challenges
    204 timeouts, 417 bad responses, 417 bad authenticators
    0 unknown types, 417 dropped, 0 ms latest rtt
    Throttled: 0 transactions, 0 timeout, 0 failures
    Estimated Throttled Access Transactions: 0
    Maximum Throttled Access Transactions: 0
  The most strange issue is this
000c.42a8.71e2  0.0.0.0         INIT       57         BE100.361            default    0x0
and
RP/0/RSP0/CPU0:Sep 23 17:08:03.507 : dhcpd[1077]: DHCPD ERROR: TP2468: rib route delete failed, null ifhandle or IPv4 address
Here is the subscriber session info
RP/0/RSP0/CPU0:ASR9001#show subscriber session all
Mon Sep 23 17:08:46.995 EET
Codes: IN - Initialize, CN - Connecting, CD - Connected, AC - Activated,
       ID - Idle, DN - Disconnecting, ED - End
Type         Interface                State     Subscriber IP Addr / Prefix
                                                LNS Address (Vrf)
IP:DHCP      No                       CN        -
RP/0/RSP0/CPU0:ASR9001#show subscriber session all detail
Mon Sep 23 17:08:48.394 EET
Interface:                None
Circuit ID:               000401690107
Remote ID:                0006001ebd7b2f00
Type:                     IP: DHCP-trigger
IPv4 State:               Up Pending, Mon Sep 23 17:08:32 2013
Mac Address:              000c.42a8.71e2
Account-Session Id:       000001e0
Nas-Port:                 67114640
User name:                unknown
Outer VLAN ID:            361
Subscriber Label:         0x0000005f
Created:                  Mon Sep 23 17:08:32 2013
State:                    Connecting
Authentication:           unauthenticated
Access-interface:         Bundle-Ether100.361
Policy Executed:
  event Session-Start match-first [at Mon Sep 23 17:08:32 2013]
    class type control subscriber DHCP do-until-failure [Succeeded]
      5 activate dynamic-template IPSUB_TPL [Succeeded]
Session Accounting: disabled
Last COA request received: unavailable
Pending Callbacks:
  Waiting for Authorization to complete
  Waiting for Authentication response from AAA
20 Replies 20
xthuijs
Hi Goergi,
radius is not giving us access-accepts back, instead the client on the 9k side complains about invalid authenticators, this usually is caused by incorrect keys between the client and server.
although the radius-server may respond with an access accept always, it should fill the authenticator field and when we parse the response, we dont have a good match on it and therefore fail the request.
the dhcp discover is held until the access accept is properly processed.
make sure the profile does not include a service-type outbound in there!!
cheers!
xander
Hi Alex,
I have a problem for establishing IPoE Subscriber.
my router has send Access-Request to Radius  :
LC/0/0/CPU0:Jan  6 17:04:52.711 : radiusd[320]:  RADIUS: Send Access-Request to 202.158.x8.6x:1645 id 58, len 275
LC/0/0/CPU0:Jan  6 17:04:52.711 : radiusd[320]:  RADIUS:  authenticator 92 EA 87 99 8D CF D0 0E - 1F 8F 00 B3 58 71 AF 57
C/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:  Vendor,Cisco        [26]    41
LC/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:   Cisco AVpair        [1]    35      client-mac-address=000f.b0d1.a219
LC/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:  Vendor,Cisco        [26]    34
LC/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:   Cisco AVpair        [1]    28      dhcp-vendor-class=MSFT 5.0
LC/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:  Acct-Session-Id     [44]    10      04000933
LC/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:  NAS-Port            [5]     6       2147498128
LC/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:  NAS-Port-Id         [87]    3       .
LC/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:   cisco-nas-port      [2]    3       .
LC/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:  User-Name           [1]     16      000f.b0d1.a219
LC/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:  Service-Type        [6]     6       Outbound[0]
LC/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:  Vendor,Cisco        [26]    9
LC/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:  Vendor,Cisco        [26]    33
LC/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:   Cisco AVpair        [1]    27      parent-if-handle=67111360
LC/0/0/CPU0:Jan  6 16:58:26.943 : radiusd[320]:  RADIUS:  NAS-Port-Type       [61]    6       IPOEOVLAN[0]
LC/0/0/CPU0:Jan  6 16:58:26.943 : radiusd[320]:  RADIUS:  Event-Timestamp     [55]    6       1389002276
LC/0/0/CPU0:Jan  6 16:58:26.943 : radiusd[320]:  RADIUS:  Vendor,Cisco        [26]    35
LC/0/0/CPU0:Jan  6 16:58:26.943 : radiusd[320]:  RADIUS:   Cisco AVpair        [1]    29      dhcp-client-id=000fb0d1a219
LC/0/0/CPU0:Jan  6 16:58:26.943 : radiusd[320]:  RADIUS:  Nas-Identifier      [32]    26      HOSTNAME-BNG
LC/0/0/CPU0:Jan  6 16:58:26.943 : radiusd[320]:  RADIUS:  NAS-IP-Address      [4]     6       210.x.x.x
LC/0/0/CPU0:Jan  6 16:58:26.942 : radiusd[320]:  RADIUS:  User-Password       [2]     18      *
And My Radius has Accept-Access:
*** Sending to 210.x.x.x port 39694 ....
Code:       Access-Accept
Identifier: 44
Authentic:  E{q<200><171><0><14><22><231><192><7><188><210>/<233>?
Attributes:
cisco-avpair = "subscriber:sa=IPSUB_TPL"
but the router never accept-access packet from the Radius ?
the weird thing is my router has state radius source interface is loopback0, but it still send NAS-IP-Address from interface physical. 210.x.x.x instead my loopback 202.158.x.233
interface Loopback0
ipv4 address 202.158.x.233 255.255.255.255
radius source-interface Loopback0 vrf default
class-map type control subscriber match-any IP_SUB
match protocol dhcpv4 dhcpv6
end-class-map
  class type control subscriber IP_SUB do-all
   10 activate dynamic-template IPSUB_TPL
   20 authorize aaa list author_grp format USERNAME_FORMAT password iosxr
event account-logon match-first
   10 authenticate aaa list default
end-policy-map
please help for clue.
thank you.
hi rommy,
it could be your radius server is replying back to the nas-ip-address and therefore we never see the response, this is incorrect from both the radius (as it should use the socket info) as well as the bng, which should have set the nas-ip-addr to the loopback source as per configuration.
for that latter clause, I am thinking that this is a bug from older releases, I recently verified this in xr43(2) and it was working solid there, which version are you using there?
regards
xander
rommy:
try adding this to your configuration:
server auth-port xxxx acct-port yyyy
i've seen this before, albeit, with 4.2, but try it and see what happens.
for some reason, this was not enough in my case:
regards,
c.
rommykuntoro
Hi Carlos & Alex
im using version 5.1.0
asr9k-bng, V 5.1.0[Default], Cisco Systems, at disk0:asr9k-bng-5.1.0
    Built on Sat Sep  7 05:01:13 GMT 2013
    By iox-bld5 in /auto/srcarchive8/production/5.1.0/all/workspace for pie
below my configuration, did i miss something ?
thank you for the helps.
radius-server host 202.aa.bb.cc auth-port 1645 acct-port 1646
key 7
radius-server timeout 10
pool vrf default ipv4 test
address-range 101.aaa.abc.2 101.aaa.abc.254
dhcp ipv4
profile DHCP server
  pool test
  dns-server 8.8.8.8
  subnet-mask 255.255.255.0
  default-router 101.aaa.abc.1
interface GigabitEthernet0/0/0/0.905 server profile DHCP
aaa attribute format USERNAME_FORMAT
mac-address
aaa group server radius radiator
server 202.aa.bb.cc auth-port 1645 acct-port 1646
aaa accounting subscriber default group radiator
aaa authorization subscriber default group radiator
aaa authorization subscriber author_grp group radiator
aaa authentication subscriber default group radiator
dynamic-template
  ipv4 unnumbered Loopback2000
end-class-map
end-policy-map
interface Loopback2000
ipv4 address 101.aa.bb.1 255.255.255.0
ipv4 point-to-point
encapsulation dot1q 905
  initiator dhcp
  initiator unclassified-source
ok looks like you may are running into a new bug in xr51.
do you need func from xr51, otherwise I would recommend sticking with 434 for bng deployments.
ps great suggestion btw Carlos!
thanks
xander
Alex, thank you for you clarification. i will try to downgrade my ASR9001 to 4.3.4.
i will let you know the updates.
Hi Alex, i have downgrade my router to 4.3.4, in this version there are no DHCPv4 Server option. how do i get the dhcp server in my router ?
I have try to connect my demo client, the result is my router doesn't recieved Accept-Access from my Radius and also the routing system still send radius packet from interface physical instead loopback0.
Access-Request from Router to Radius #
  7 09:45:02.753 : radiusd[315]:  RADIUS: Send Access-Request to 202.xxx.xxx.60:1645 id 24, len 254
  7 09:45:02.754 : radiusd[315]:  RADIUS:  authenticator FC 30 00 B2 EB 76 ED 27 - 82 51 DF 8C F2 45 AA 6F
  7 09:45:02.754 : radiusd[315]:  RADIUS:  Vendor,Cisco        [26]    41
  7 09:45:02.754 : radiusd[315]:  RADIUS:   Cisco AVpair        [1]    35      client-mac-address=000f.b0d1.a219
  7 09:45:02.754 : radiusd[315]:  RADIUS:  Vendor,Cisco        [26]    34
  7 09:45:02.754 : radiusd[315]:  RADIUS:   Cisco AVpair        [1]    28      dhcp-vendor-class=MSFT 5.0
  7 09:45:02.754 : radiusd[315]:  RADIUS:  Acct-Session-Id     [44]    10      0400000a
  7 09:45:02.754 : radiusd[315]:  RADIUS:  NAS-Port-Id         [87]    13      130/8/0/905
  7 09:45:02.754 : radiusd[315]:  RADIUS:  Vendor,Cisco        [26]    19
  7 09:45:02.754 : radiusd[315]:  RADIUS:   cisco-nas-port      [2]    13      130/8/0/905
  7 09:45:02.754 : radiusd[315]:  RADIUS:  User-Name           [1]     16      000f.b0d1.a219
  7 09:45:02.754 : radiusd[315]:  RADIUS:  Service-Type        [6]     6       Outbound[5]
  7 09:45:02.754 : radiusd[315]:  RADIUS:  User-Password       [2]     18      *
  7 09:45:02.754 : radiusd[315]:  RADIUS:  Vendor,Cisco        [26]    33
  7 09:45:02.754 : radiusd[315]:  RADIUS:   Cisco AVpair        [1]    27      parent-if-handle=67111360
  7 09:45:02.754 : radiusd[315]:  RADIUS:  NAS-Port-Type       [61]    6       IPOEOVLAN[40]
  7 09:45:02.754 : radiusd[315]:  RADIUS:  Event-Timestamp     [55]    6       1389062702
  7 09:45:02.754 : radiusd[315]:  RADIUS:  Nas-Identifier      [32]    26      HOSTNAME-BNG
  7 09:45:02.754 : radiusd[315]:  RADIUS:  NAS-IP-Address      [4]     6      210.xxx.yyy.2
Access-Request from Radius which got from Router #
*** Received from 210.xxx.yyy.2 port 51185 ....
Code:       Access-Request
Identifier: 31
Authentic:  *<134><174><25><251>a<140><17><170><255>S<191><205>;T<153>
Attributes:
cisco-avpair = "client-mac-address=000f.b0d1.a219"
cisco-avpair = "dhcp-vendor-class=MSFT 5.0"
Acct-Session-Id = "0400000b"
NAS-Port-Id = "130/8/0/905"
Cisco-NAS-Port = "130/8/0/905"
User-Name = "000f.b0d1.a219"
Service-Type = 5
User-Password = <251><10>h<203><11><203><151><132>i<29><222>@<251>t7<166>
cisco-avpair = "parent-if-handle=67111360"
NAS-Port-Type = 40
Event-Timestamp = 1389062760
NAS-Identifier = "HOSTNAME-BNG"
NAS-IP-Address = 210.xxx.yyy.2
##Accept-Access from Radius to Router ##
Tue Jan  7 09:42:53 2014: DEBUG: Handling with Radius::AuthFILE:
Tue Jan  7 09:42:53 2014: DEBUG: Radius::AuthFILE looks for match with 000f.b0d1.a219 [000f.b0d1.a219]
Tue Jan  7 09:42:53 2014: DEBUG: Radius::AuthFILE ACCEPT: : 000f.b0d1.a219 [000f.b0d1.a219]
Tue Jan  7 09:42:53 2014: DEBUG: AuthBy FILE result: ACCEPT,
Tue Jan  7 09:42:53 2014: DEBUG: Access accepted for 000f.b0d1.a219
Tue Jan  7 09:42:53 2014: DEBUG: Packet dump:
*** Sending to 210.xxx.yyy.2 port 51185 ....
Code:       Access-Accept
Identifier: 31
Authentic:  $U<226><252>4<219><171><228><226>q^<28><135>?<143><175>
Attributes:
## BUT The Router never recieved Access-Accept Packet from the Radius ##
== Current Configuration After Downgrade to 4.3.4 ==
radius-server host 202.158.58.60 auth-port 1645 acct-port 1646
key 7
circuit-id plus remote-id separator #
mac-address
server 202.xx.xx.60 auth-port 1645 acct-port 1646
aaa accounting update periodic 5
dhcp ipv4
profile DHCPv4 proxy
  helper-address vrf default 202.xxx.1.34 giaddr 101.aaa.bbb.1
interface GigabitEthernet0/0/0/0.905 proxy profile DHCPv4
interface Loopback0
ipv4 address 202.ccc.ddd.233 255.255.255.255
ipv4 address 101.aaa.bbb.1 255.255.255.0
ipv4 point-to-point
  initiator dhcp
  dynamic-template
end-class-map
end-policy-map
#Radius Status#
show radius
Tue Jan  7 09:56:52.137 GMT
Global dead time: 0 minute(s)
Number of Servers:1
Server: 202.xx.xx.60/1645/1646  is UP
  Timeout: 10 sec, Retransmit limit: 3
  Quarantined: No
  Authentication:
    11 requests, 1 pending, 31 retransmits
    41 timeouts, 0 bad responses, 0 bad authenticators
    0 unknown types, 0 dropped, 0 ms latest rtt
    Automated TEST Stats:
        0 requests, 0 timeouts, 0 response, 0 pending
  Accounting:
    0 requests, 0 pending, 0 retransmits
    0 responses, 0 timeouts, 0 bad responses
    0 bad authenticators, 0 unknown types, 0 dropped
    0 ms latest rtt
    Estimated Throttled Accounting Transactions: 0
    Maximum Throttled Accounting Transactions: 0
from this logging it looks like the radius-server replies back to the nas-ip-address.
depending on what the socket value was from where the request originated (can you see that in your radius-server
log too where the request came from on the socket?)
if you have defined a radius-server group, make sure that the source address is configured under the group properly also.
make sure that the address of the source interface is the right address also.
if this all confirmed, then try a proc restart on radiusd for me, on the rsp.
another thing to try is to use the aaa authentication subscriber default group radius (to leverage the global group of radius servers as opposed to the group defined one)
Also a sniffer trace capturing the radius traffic between bng and radius may help here as I can't see from this logging what the source address was used on the socket of the bng.
xr43 doesnt have a local dhcp server, so you may need to use an external one, eg a simple ios device can do that for you, but that is not necessary to verify/demonstrate this particular issue.
regards
xander
Thank you xander,
i'm sured that my radius-server source interface is already state to my loopback address, and my loopback address also right. but the weird one is  why my router send nas-ip-address as my physcial interface ip instead my loopback ip which i have stated from my global radius or group radius source interface using loopback0.
im afraid that when the return packet accept-access from radius, the router expect from my router loopback0, but when he send the access-request to the radius, my router send it from the physical address.
i will try to sniff my bng and radiator to see what happens there.
Hi Xander,
i have sniff between Radiator and BNG:
1. from the interface radius, radiator has recieved Access-Request from router, and transmit Access-Accept to router
2. from the interface bng, bng send Access-Request to radius and the radius accepted it. and then Access-Accept was sent from radius to bng, but from the inside the bng, the access-accept packet never recevied.
do you have any clue on that, xander ? btw the radius server is also used for BNG(PPPoE) router ASR1K  and they are perfectly running well.
thanks for the helps
Carlos A. Silva
Level 3
Level 3
A couple of questions rommy:
In your sniffer: are all you expected ip addresses correct? both dst-ip and src-ip in both the access request and access accept packets?
Are the BNG and radius server connected back to back? I ask because you say you have a sniffer between them.
If not, is there a cloud of routers in between them? Radius communications are straight forward, as long as dst-ip and src-ip are ok, the only thing that could be wrong is the radius key and (if back 2 back) just maybe the MAC address on the packets.
Hi Carlos,
Yes, all the addresses are correct. both dst-ip and src-ip, also the identifier of the radius packet.
the BNG and Radius are not back to back, they are talk each other via routing.  yes,  i sniffed both of them. from the radius interface side and and from the interface router side.
just like you said carlos, they talked straight forward. even if i stated my radius source-interface to physical interface, it is the same thing, my router never got the accept-access.  and i really confuse, when i state radius source-interface to loopback0, the router send NAS-IP-Address still physical interface addresses. is it kind a bug ? of miss configuration ?
all my config was posted above. did i something wrong?, and never been experience like this until now when using ASR1K platform.
so, let me backtrack a little, you never got the BNG to change the source-ip for the radius packets to the loopback address? wow! i missed that part.
best guess it is a bug. kinda hard to guess without actually looking.
i'll share a config from a live/working box with 4.3.2:
radius-server host x.x.x.x auth-port 1812 acct-port 1813
key 7 XXXXXXXX
radius-server host y.y.y.y auth-port 1812 acct-port 1813
key 7 YYYYYYYY
aaa group server radius ZZZZZ
server x.x.x.x auth-port 1812 acct-port 1813
server y.y.y.y auth-port 1812 acct-port 1813
aaa accounting subscriber default group ZZZZZ
aaa authorization subscriber default group ZZZZZ
aaa authentication subscriber default group ZZZZZ
i also looked for public bugs and nothing.
