BVI: ACL
kozorezdi
Hello everyone,
1) Could you tell me why ACL is not working under BVI2?
l2vpn
bridge group 2
  bridge-domain 2
   interface GigabitEthernet0/7/0/18
   interface GigabitEthernet0/7/0/20
   routed interface BVI2
interface BVI2
ipv4 address 10.1.1.1 255.255.255.0
description *** DDD ***
negotiation auto
transceiver permit pid all
l2transport
ipv4 access-group 120 egress
ipv6 access-group IPV6-ACL egress
It is working under a phy interface, but I have a few interfaces under the same Bridge Domain.
I guess it should be working like under SVI.
RP/0/RSP0/CPU0:R01#sh access-lists 120 usage pfilter location all
Thu Jan  9 15:13:08.355 UTC
Interface : GigabitEthernet0/7/0/18
    Input ACL : N/A    Output ACL : 120
RP/0/RSP0/CPU0:R01#
2) How to see matches per ACL line on IOS-XR?
R02#sh ip access-lists 120
Extended IP access list 120
    10 permit ***
    200 deny ip any any (24463 matches)
R02#
Thank you for your time!
Best regards,
Dmitry
2 Accepted Solutions
Rivalino Tamaela
Hello Dmitry,
What kind of card do you have and what version is the software? Just fyi, ACL on BVI is supported starting release 4.2.1 for Typhoon card only. Please refer to this:
http://www.cisco.com/en/US/partner/docs/routers/asr9000/software/asr9k_r4.2/general/release/notes/reln_a9k_421.html#concept_641E24E225D747C08099E20F3AFAA93A
HTH,
Rivalino
Rivalino Tamaela
For second question, see example below:
RP/0/RP0/CPU0:CRS4A#show run int gi0/1/0/3
Thu Jan 27 11:14:45.691 PST
interface GigabitEthernet0/1/0/3
cdp
ipv4 address 12.1.1.2 255.255.255.0
ipv4 access-group ACL egress hardware-count interface-statistics
RP/0/RP0/CPU0:CRS4A#show access-lists ipv4 ACL
Thu Jan 27 11:16:18.552 PST
ipv4 access-list ACL
10 permit icmp any host 10.1.1.2
20 permit ipv4 any any
RP/0/RP0/CPU0:CRS4A#ping 10.1.1.2
Thu Jan 27 11:12:27.749 PST
Sending 5, 100-byte ICMP Echos to 10.1.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 2/3/8 ms
RP/0/RP0/CPU0:CRS4A#show access-lists ipv4 ACL hardware egress interface gigabitEthernet 0/1/0/3 location 0/1/cpu0
Thu Jan 27 11:18:45.104 PST
10 permit icmp any host 10.1.1.2 (5 hw matches)
20 permit ipv4 any any (2 hw matches)
rivalino
Rivalino Tamaela
Hello Dmitry,
HTH,
Rivalino
Rivalino Tamaela
cdp
rivalino
hello Rivalino,
what can I tell you...  THANK YOU VERY MUCH!!!
