ASR 9001 BNG IPoE problems
Goergi Genov
I have read and try these guides
https://supportforums.cisco.com/docs/DOC-23170
https://supportforums.cisco.com/docs/DOC-19702
https://supportforums.cisco.com/docs/DOC-19726
But have some problems , here is my config ( almost same like the guides )
radius-server host xxx.xxx.xxx.46 auth-port 1812 acct-port 1813
aaa server radius dynamic-author
port 3799
client yyy.yyy.yyy.102 vrf default
client xxx.xxx.xxx.46 vrf default
aaa attribute format MY_AUTH
mac-address
aaa attribute format NAS_PORT_FORMAT
circuit-id plus remote-id separator .
aaa radius attribute nas-port format e SSAAPPPPQQQQQQQQQQVVVVVVVVVVUUUU type 32
aaa radius attribute nas-port-id format NAS_PORT_FORMAT
aaa group server radius RADIUS_GR
server xxx.xxx.xxx.46 auth-port 1812 acct-port 1813
source-interface Loopback0
aaa authorization network default group RADIUS_GR
aaa accounting subscriber default group RADIUS_GR
aaa authorization subscriber AUTH_GR group RADIUS_GR
aaa authorization subscriber default group RADIUS_GR
aaa authorization subscriber RADIUS_GR group RADIUS_GR
aaa authentication subscriber default group RADIUS_GR
aaa accounting update periodic 10
dhcp ipv4
profile IP_DEFAULT proxy
  class IP_DEFAULT
   helper-address vrf default yyy.yyy.yyy.102 giaddr zzz.zzz.zzz.1
  relay information option
  relay information policy keep
  relay information option allow-untrusted
   interface Bundle-Ether100.361 proxy profile IP_DEFAULT
ipv4 access-list PERM_ALL
10 permit ipv4 any any
20 permit icmp any any
30 permit ipv4 any any
bundle load-balancing hash dst-ip
ipv4 point-to-point
ipv4 unnumbered Loopback100
service-policy type control subscriber IP_PM
encapsulation dot1q 361
ipsubscriber ipv4 l2-connected
  initiator dhcp
interface Loopback0
ipv4 address ccc.ccc.ccc.174 255.255.255.255
interface Loopback100
description 4dhcp
ipv4 address zzz.zzz.zzz.1 255.255.255.0
interface TenGigE0/0/2/0
bundle id 100 mode on
interface TenGigE0/0/2/1
dynamic-template
type ipsubscriber IPSUB_TPL
  ipv4 access-group PERM_ALL ingress
  ipv4 access-group PERM_ALL egress
class-map type control subscriber match-any DHCP
match protocol dhcpv4
end-class-map
policy-map type control subscriber IP_PM
event session-start match-first
  class type control subscriber DHCP do-until-failure
   5 activate dynamic-template IPSUB_TPL
   10 authorize aaa list AUTH_GR format MY_AUTH password cisco
end-policy-map
Without  service-policy type control subscriber IP_PM on the interface , CPE gets ip address and all works.
The radius server is configured always to autothenticate with access-accept but there are errors
  Total Deadtime: 0s Last Deadtime: 0s
  Timeout: 5 sec, Retransmit limit: 3
  Quarantined: No
  Authentication:
    468 requests, 1 pending, 154 retransmits
    0 accepts, 0 rejects, 0 challenges
    204 timeouts, 417 bad responses, 417 bad authenticators
    0 unknown types, 417 dropped, 0 ms latest rtt
    Throttled: 0 transactions, 0 timeout, 0 failures
    Estimated Throttled Access Transactions: 0
    Maximum Throttled Access Transactions: 0
  The most strange issue is this
000c.42a8.71e2  0.0.0.0         INIT       57         BE100.361            default    0x0
and
RP/0/RSP0/CPU0:Sep 23 17:08:03.507 : dhcpd[1077]: DHCPD ERROR: TP2468: rib route delete failed, null ifhandle or IPv4 address
Here is the subscriber session info
RP/0/RSP0/CPU0:ASR9001#show subscriber session all
Mon Sep 23 17:08:46.995 EET
Codes: IN - Initialize, CN - Connecting, CD - Connected, AC - Activated,
       ID - Idle, DN - Disconnecting, ED - End
Type         Interface                State     Subscriber IP Addr / Prefix
                                                LNS Address (Vrf)
IP:DHCP      No                       CN        -
RP/0/RSP0/CPU0:ASR9001#show subscriber session all detail
Mon Sep 23 17:08:48.394 EET
Interface:                None
Circuit ID:               000401690107
Remote ID:                0006001ebd7b2f00
Type:                     IP: DHCP-trigger
IPv4 State:               Up Pending, Mon Sep 23 17:08:32 2013
Mac Address:              000c.42a8.71e2
Account-Session Id:       000001e0
Nas-Port:                 67114640
User name:                unknown
Outer VLAN ID:            361
Subscriber Label:         0x0000005f
Created:                  Mon Sep 23 17:08:32 2013
State:                    Connecting
Authentication:           unauthenticated
Access-interface:         Bundle-Ether100.361
Policy Executed:
  event Session-Start match-first [at Mon Sep 23 17:08:32 2013]
    class type control subscriber DHCP do-until-failure [Succeeded]
      5 activate dynamic-template IPSUB_TPL [Succeeded]
Session Accounting: disabled
Last COA request received: unavailable
Pending Callbacks:
  Waiting for Authorization to complete
  Waiting for Authentication response from AAA
20 Replies 20
let me correct that last comment. not exactly the same, but what caught my eye is the version in which is fixed:
https://tools.cisco.com/bugsearch/bug/CSCuj06414
Known Fixed Releases:
(4)
5.1.1.11i.BASE
5.1.2.1i.BASE
5.1.11.4i.BASE
5.2.0.7i.BASE
Hi Carlos,
thank you very much your information. so the version 4.3.4 it seem having bug also ?
Honestly, the best I can tell you is: if you're 100 % sure you don't have a routing or firewall problem and your sniffer captures are correct, i've seen this before on 4.2. The url I sent you is for a bug on 4.2.3 that apparently is fixed on 5.1.1x. Not the exact same problem though.
Like I said, I'm working with 4.3.2 no problem, so maybe you want to try that, but before you do make sure you have everything right one last time.
at last, it is my bad. i never deploy bundle-ether since beginning. we should bring up the ether-bundle to subscriber interface until version 5.1.1.
P/0/RSP0/CPU0:Jan 10 11:14:49.399 : radiusd[1103]:  RADIUS: Received from id 0 202.aaa.bbb.60:1645, Access-Accept, len 20
RP/0/RSP0/CPU0:Jan 10 11:14:49.399 : radiusd[1103]:  RADIUS:  authenticator AA 04 BD 4F 84 E8 8C 85 - 46 00 4E F8 FA 8C C1 8E
Restrictions before 5.1.1:
* On BNG, only dynamic creation of subscribers is supported. Also, the subscriber must be present only on the bundle interfaces.
sh subscriber session all
Fri Jan 10 11:20:19.284 GMT
                                                LNS Address (Vrf)
IP:DHCP      BE100.905.ip1            AC        101.aaa.bbb.2 (default)
thank you carlos and xander.
Never would've thought that would have an effect on radius behavior. Nice catch!
ah of course, I totally missed this line you had in your config earlier:
interface GigabitEthernet0/0/0/0.905 proxy profile DHCPv4
that means you want to terminate on the linecard that we don't support until 511.
the reason for that is, when you have a phy (sub) interface then AAA, the control policy, dhcp and ppp run on the linecard.
When you are using bundle that control is moved to the RSP.
Upto 511 we need to have that control on the RSP, hence that requirement.
If you dont need bundle, you could always create a single member bundle without lacp so that the remote side doesnt even know it is pulled into a bundle on teh 9k side.
cheers!
xander
