ASR 9001 Licensing
Jordi Benet
Beginner
Beginner
I want to use the nV feature to cluster 2 ASR 9001.
For that I will need to add the A9K-NV-CLUSTR-LIC license.
What would the A9K-NVSAT5-LIC do for me? (nV Host License for up to 5 nV clients) I would need it to cluster my 2 ASR 9001?
I would also like to know if I would require the L-A9K-9001OPT-LIC= (ASR 9001 Advanced Optical License) in order to use 10Gbps fiber connections. What does this license provide to my ASR 9001?
Thanks a lot for the help.
J
Hi.
Let me answer your questions. I wrote an article about licensing on ASR 9000 - http://blog.netfi.co/cisco-asr-9000-licensing/
1. nV Licensing
A9K-NV-CLUSTR-LIC is for nV Edge
A9K-NVSAT5-LIC allows you to connect 5 satellites (9000v, 901 or 903).
Additionaly you need appropriate license on ASR 901 or ASR 903. ASR 9000v doesn't require any additional license. More about it in my article.
2. L-A9K-9001OPT-LIC=
You don't need this license to use 10G links. It allows you to configure G.709/ONT on 10G interfaces.
Hi.
1. nV Licensing
Thanks a lot Miroslaw. Now it is clear I will only need the A9K-NV-CLUSTR-LIC license
I read your article and now I have a new doubt. I see that there is a license for VRF in L3VPN. If I use VRF-Lite I will require any VRF license for 2 ASR9001?
Thanks a lot.
J
You need AIP or IVRF. You won't be able to commit vrf configuration.
For nV Edge you need only A9K-NV-CLUSTR-LIC.
Thanks a lot Miroslaw for the clarification.
J
Recognize Your Peers
