ASR 9001 missing 1GB on harddisk:
pschueck
Hi all,
I´m missing approx 1GB free space on my harddisk:
Directory of harddisk:
3019898880 bytes total (834121728 bytes free)
I did a     dir /recurcive harddisk:   and add all file-sizes  the sum is  1096513392 bytes
3019898880 bytes - 1096513392 bytes   =  1923385488 bytes  and not 834121728  bytes
I ´ve a couple of ASR9k, but I see that behavior only on one!!!!
cu, Peter
Rivalino Tamaela
Hi Peter,
Can you check this command: show filesystem, and see if free space is same.
thanks,
rivalino
Hi Rivalino,
It ´s a miracle
Today the space is free again.
3019898880 bytes total (1923181568 bytes free)
I found no hint in the log.
Thanks for your help.
Peter
