asr 9006 bgp network advertisement problem null0 routes
Umit AYDINLI
I want to ask a question cisco experts. I have couple of cisco asr 9006. I have to reload with cef problem after then reload I saw didn't advertise ip blocks my router.
I checked the configuration then I saw 2a02:ac80::/32 Null0 240 the configs are correct.
I could remove the config no 2a02:ac80::/32 Null0 240 after that wrote config again 2a02:ac80::/32 2a02:ac80::1 after then start to advertisement.
What can I wrong?
I know IOS bgp advertisement. Have to ip blocks per null0 routes. What different IOS and XR?
Rivalino Tamaela
Looks like you redistribute static route into BGP. Do you have other static routes other than the route you mentioned above? If yes, did they have same problem too? In term of BGP advertisement, there is no difference between IOS and XR.
thanks,
rivalino
Hi, yes I have.
I'm using Cisco IOS XR Software, Version 4.1.2[Default]
My bgp conf are below.
prefix-set IPV6_Dist
2a02:ac80::/32
end-set
route-policy Dist_IPV6
  if destination in IPV6_Dist then
    pass
  else
    drop
  endif
  end-policy
router static
address-family ipv6 unicast
neighbor
  remote-as xxxx
  password encrypted
  description
  update-source TenGigE0/1/0/0.103
   route-policy Accept-All in
   maximum-prefix 512000 95
   route-policy IPV6 out
   soft-reconfiguration inbound always
RP/0/RSP1/CPU0:#sh bgp ipv6 unicast summary
Neighbor        Spk    AS MsgRcvd MsgSent   TblVer  InQ OutQ  Up/Down  St/PfxRcd
                  0  79181    9108   197216    0    0    1d17h      16447
RP/0/RSP1/CPU0:#sh bgp ipv6 unicast advertised summary
Wed Mar  5 09:13:13.516 GMT
Wed Mar  5 09:13:15.754 GMT
RP/0/RSP1/CPU0:#
