ASR 9010 Temperature Threshold
hsien-ping tang
I would like to find the temperature threshold value of ASR9010.
admin show environment temperature, it shows only current temp value.
admin show environment table will only have critical value, no minor and major value.
Could anyone provide me this value?
Tom
23 Replies 23
The alarm is reported for the Inlet sensor, but this is obviously a SW bug because the threshold cannot be negative (-50.0C). Which XR release are you running and with which SMUs/SP?
/Aleksandar
Hi Aleksandar
Thanks for your comments .the device have IOS XR version 5.1.3 and V 1.0.0[SMU]
Cisco IOS XR Software, Version 5.1.3[Default]
Configuration register on node 0/RSP0/CPU0 is 0x2102
Boot device on node 0/RSP0/CPU0 is disk0:
Package active on node 0/RSP0/CPU0:
iosxr-infra-5.1.3.CSCut30136, V 1.0.0[SMU], Cisco Systems, at disk0:iosxr-infra-5.1.3.CSCut30136-1.0.0
Built on Tue Apr 14 16:23:49 CDT 2015
By iox-lnx-008 in /san1/smu/EFR/smu_r51x_5_1_3/workspace for pie
Regards, oscar
hi Oscar,
it would be the best to upgrade to a more recent IOS XR release, that will surely get rid of that error. See https://community.cisco.com/t5/service-providers-documents/ios-xr-release-strategy-and-deployment-recommendation/ta-p/3165422 for suggested releases.
/Aleksandar
hi Aleksandar
Thanks for your suggestions
Regards, Oscar
Line card will be shutdown 24 hours after any of the sensors hits critical temperature threshold. Critical threshold values can be checked through "admin show environment table" command output.
When major threshold is hit, fan's will be automatically run faster to cool down the line card. this is why you see major alarm getting cleared.
-Phadke
Hi, I'm review the enviroment temperatures, I saw some modules are in 65.1 and 63 degree, Are these in the range? What's the maximum value?
(admin)#show environment temperatures
Thu Jan 25 16:05:41.033 UTC
R/S/I   Modules Sensor                  (deg C)
0/0/*
        ep0     Inlet0                  33.0
        ep0     Hotspot0                43.9
        ep1     Inlet0                  29.7
        ep1     Hotspot0                36.7
        host    die_NP0                 61.5
        host    die_NP1                 58.0
        host    die_NP2                 53.5
        host    die_NP3                 57.0
        host    die_FIA0                63.5
        host    die_FIA1                58.0
        host    die_FIA2                57.0
        host    die_FIA3                53.0
        host    die_FabSwitch           63.0
        host    Inlet0                  30.3
        host    Hotspot0                50.5
0/1/*
        host    die_NP0                 50.0
        host    die_FIA0                47.0
        host    die_FabSwitch           47.0
        host    bb_hotspot1             41.3
        host    bb_outlet0              32.3
        host    bb_outlet1              38.4
        host    db_inlet                27.6
        host    db_outlet               30.4
        host    Inlet0                  30.0
        host    Hotspot0                37.9
0/2/*
        host    Inlet0                  29.7
        host    Hotspot0                50.0
0/3/*
        host    Inlet0                  29.6
        host    Hotspot0                50.0
0/RSP0/*
        host    die_CPU                 36.0
        host    die_FabArbiter0         37.0
        host    die_FIA                 40.0
        host    die_PCH                 43.0
        host    die_DIMM0               32.0
        host    die_DIMM1               32.0
        host    die_DIMM2               30.0
        host    die_DIMM3               30.0
        host    die_FabSwitch0          36.0
        host    die_FabSwitch1          36.0
        host    air_inlet               26.6
        host    sm15_0_downstream       36.8
        host    sm15_0_inlet            30.2
        host    sm15_1_upstream         29.1
        host    air_outlet              40.6
        host    Inlet0                  27.3
        host    Hotspot0                37.8
0/RSP1/*
        host    die_CPU                 34.5
        host    die_FabArbiter0         39.0
        host    die_FIA                 40.5
        host    die_PCH                 43.0
        host    die_DIMM0               33.0
        host    die_DIMM1               33.0
        host    die_DIMM2               31.5
        host    die_DIMM3               32.0
        host    air_inlet               26.0
        host    sm15_0_downstream       36.9
        host    sm15_0_inlet            30.5
        host    sm15_1_upstream         29.6
        host    air_outlet              39.5
        host    Inlet0                  27.1
        host    Hotspot0                37.7
0/FT0/*
        host    Inlet0                  27.1
        host    Hotspot0                31.3
0/FT1/*
        host    Inlet0                  28.2
        host    Hotspot0                34.6
please remove the air filter and check the temperature after a few minutes. Cisco recommends to clean or replace the air filter on a regular basis.
Ok Tom, thanks for reply, so this is a new equipment I'll review the filter also verified the temperature inside the site.
mahendranbalu
thanks TOm your answer was helpfull , it sorted ,
using ADMIN to get those fan details
