Interfaces move to preconfigure state
I'm experiencing behavior on the NCS540 whereby interfaces which physically exist are being moved to preconfigured interfaces once configuration is added.  Interfaces now "missing are ten0/0/0/2, ten0/0/0/3, ten0/0/0/17
Example
RP/0/RP0/CPU0:VFWR_NCS540(config)#int ten0/0/0/17
RP/0/RP0/CPU0:VFWR_NCS540(config-if)#description nopreconfigureplease
RP/0/RP0/CPU0:VFWR_NCS540(config-if)#commit
Tue Oct 20 17:53:19.034 UTC
RP/0/RP0/CPU0:Oct 20 17:53:20.866 UTC: config[69402]: %MGBL-CONFIG-6-INT_UNRESOLVED : Some of the interface configuration was moved to pre configuration automatically as these interfaces do not exist or could not be mapped to any nodes
I have several of these same routers and have not experienced this same behavior.  IN addition, there are some interfaces which had been configured at an earlier date on this same device are working correctly.  Thoughts?
Tue Oct 20 18:22:15.320 UTC
Cisco IOS XR Software, Version 6.5.3
Copyright (c) 2013-2019 by Cisco Systems, Inc.
Build Information:
Built By : ahoang
Built On : Tue Mar 26 06:43:53 PDT 2019
Built Host : iox-ucs-026
Workspace : /auto/srcarchive13/prod/6.5.3/ncs540/ws
Version : 6.5.3
cisco NCS-540 () processor
System uptime is 1 hour 20 minutes
RP/0/RP0/CPU0:VFWR_NCS540#show inventory
Tue Oct 20 18:23:00.505 UTC
NAME: "0/RP0", DESCR: "Cisco NCS 540 16G Series Fixed Router 24x10G,8x25G,2x100G"
RP/0/RP0/CPU0:VFWR_NCS540#show int bri
Tue Oct 20 18:23:39.262 UTC
Intf Intf LineP Encap MTU BW
Name State State Type (byte) (Kbps)
BE50 down down ARPA 9216 0
BE50.85 down down 802.1Q 9220 0
BE50.307 down down 802.1Q 9220 0
BE50.407 down down 802.1Q 9220 0
BE50.707 down down 802.1Q 9220 0
BE50.1014 down down 802.1Q 9220 0
Lo0 up up Loopback 1500 0
Lo2 up up Loopback 1500 0
Nu0 up up Null 1500 0
Gi0/0/0/2 admin-down admin-down ARPA 1514 1000000
Gi0/0/0/3 admin-down admin-down ARPA 1514 1000000
Gi0/0/0/17 admin-down admin-down ARPA 1514 1000000
Te0/0/0/0 admin-down admin-down ARPA 1514 10000000
Te0/0/0/1 down down ARPA 9220 10000000
Te0/0/0/4 admin-down admin-down ARPA 1514 10000000
Te0/0/0/5 admin-down admin-down ARPA 1514 10000000
Te0/0/0/6 admin-down admin-down ARPA 1514 10000000
Te0/0/0/7 admin-down admin-down ARPA 1514 10000000
Te0/0/0/8 admin-down admin-down ARPA 1514 10000000
Te0/0/0/9 admin-down admin-down ARPA 1514 10000000
Te0/0/0/10 admin-down admin-down ARPA 1514 10000000
Te0/0/0/11 admin-down admin-down ARPA 1514 10000000
Te0/0/0/12 admin-down admin-down ARPA 1514 10000000
Te0/0/0/13 admin-down admin-down ARPA 1514 10000000
Te0/0/0/14 admin-down admin-down ARPA 1514 10000000
Te0/0/0/15 admin-down admin-down ARPA 1514 10000000
Te0/0/0/16 admin-down admin-down ARPA 9220 10000000
Te0/0/0/18 admin-down admin-down ARPA 1514 10000000
Te0/0/0/19 admin-down admin-down ARPA 1514 10000000
Te0/0/0/20 admin-down admin-down ARPA 1514 10000000
Te0/0/0/21 admin-down admin-down ARPA 1514 10000000
Te0/0/0/22 up up ARPA 9216 10000000
Te0/0/0/22.1720 up up 802.1Q 9220 10000000
Te0/0/0/22.1740 up up 802.1Q 9220 10000000
Te0/0/0/23 up up ARPA 9216 10000000
Te0/0/0/23.1720 up up 802.1Q 9220 10000000
Te0/0/0/23.1740 up up 802.1Q 9220 10000000
TF0/0/0/24 admin-down admin-down ARPA 1514 25000000
TF0/0/0/25 admin-down admin-down ARPA 1514 25000000
TF0/0/0/26 admin-down admin-down ARPA 1514 25000000
TF0/0/0/27 admin-down admin-down ARPA 1514 25000000
TF0/0/0/28 admin-down admin-down ARPA 1514 25000000
TF0/0/0/29 admin-down admin-down ARPA 1514 25000000
TF0/0/0/30 admin-down admin-down ARPA 1514 25000000
TF0/0/0/31 admin-down admin-down ARPA 1514 25000000
Hu0/0/1/0 admin-down admin-down ARPA 1514 100000000
Hu0/0/1/1 admin-down admin-down ARPA 1514 100000000
Mg0/RP0/CPU0/0 admin-down admin-down ARPA 1514
tkarnani
Hi Tony,
do you have a gigabit optic in port 17?
from the output it is displaying as a gig interface.
once you plug in a 10G optic it should change the port speed and name. then your configuration should apply correctly
tkarnani
Hi Tony,
Good eye my friend!   Totally overlooked that!
