ASR 9902 Interface numbering
brian.holmes
This is a fixed port router with a mix of SFP+, SFP28, QSFP28 and QSFP-DD ports
The install guide says they are split between slice 0 and slice 1 with 24 ports per slice
How does this translate into the rack/slot/instance/port schema ?  is the slice the instance?
is it ...
0/0/0/0-0/0/0/7 - SFP28
0/0/0/8-0/0/0/10 - QSFP28
0/0/0/11 - QSFP-DD
0/0/0/12-0/0/0/23 SFP+
and
0/0/1/0-0/0/1/7 - SFP28
0/0/1/8-0/0/1/10 - QSFP28
0/0/1/11 - QSFP-DD
0/0/1/12-0/0/1/23 SFP+
Brian Holmes
you can map the picture with the lab output hope it helps, unfortunately its not as straight forward depending on the breakout configuration you use. slide 88 will show you combinations of used/unused
RP/0/RP0/CPU0:ASR-9902-A#show controllers np ports all location 0/0/CPU0
Mon Apr  1 13:43:38.534 UTC
                Node: 0/0/CPU0:
NP Bridge Fia                       Ports
0  --     0   HundredGigE0/0/0/11, HundredGigE0/0/0/10, TwentyFiveGigE0/0/0/4 - TwentyFiveGigE0/0/0/7, TenGigE0/0/0/12 - TenGigE0/0/0/21
1  --     1   HundredGigE0/0/0/37, HundredGigE0/0/0/36, TenGigE0/0/0/40 - TenGigE0/0/0/47, TenGigE0/0/0/24 - TenGigE0/0/0/35
6 Replies 6
tkarnani
Hi Brian,
please check this output on your device
RP/0/RP0/CPU0:ASR-9902-C#show controllers np ports all location 0/0/CPU0
Fri Mar 29 16:12:42.556 UTC
                Node: 0/0/CPU0:
NP Bridge Fia                       Ports
0  --     0   HundredGigE0/0/0/11, HundredGigE0/0/0/10, TenGigE0/0/0/0 - TenGigE0/0/0/7, TenGigE0/0/0/22 - TenGigE0/0/0/23, TenGigE0/0/0/12, GigabitEthernet0/0/0/13, TenGigE0/0/0/14, GigabitEthernet0/0/0/15, TenGigE0/0/0/16, GigabitEthernet0/0/0/17, TenGigE0/0/0/18, GigabitEthernet0/0/0/19, TenGigE0/0/0/20, GigabitEthernet0/0/0/21
1  --     1   FortyGigE0/0/0/37/0, FortyGigE0/0/0/36/0, HundredGigE0/0/0/39, FortyGigE0/0/0/38/0
brian.holmes
Unfortunately I do not have one of these in my possession but am trying to put together a solution based on them ( a drawing of which circuits goto which port numbers )
Brian Holmes
brian.holmes
Based on the output you showed it looks like it might be the following but it is a little hard to tell:
0/0/0/11 - QSFP-DD
0/0/0/12-0/0/0/35 SFP+
0/0/0/36-0/0/0/38 QSPF28
0/0/0/39 QSFP-DD
0/0/0/40-0/0/0/47 SFP28
Brian Holmes
                Node: 0/0/CPU0:
NP Bridge Fia                       Ports
Thank you, this helps very much.   So the Port numbering does not change as in slide 88...but which are active depends on the breakout configuration you configure.
Brian Holmes
