ASR 9K IOX XR Turboboot
netops044
Hi Experts,
Im trying to downgrade XR image in ASR9K from 4.3.1 to 4.2.3. The VM file size is about 330Mb. TFTP operation is getting terminated  after some point of time. Im using 3Cdeamon server and has configured  max timeout and retries already. Is there anything Im missing here.
rommon B40 > set
PS1=rommon ! >
ReloadReason=0
ACTIVE_FCD=1
IOX_ADMIN_CONFIG_FILE=
IML=1
BSI=0
CLUSTER_NO_BOOT=
BOOT_DEV_SEQ_CONF=
IP_ADDRESS=202.144.113.7
IP_SUBNET_MASK=255.255.255.192
DEFAULT_GATEWAY=202.144.113.1
TURBOBOOT=on,disk0,format
TFTP_RETRY_COUNT=8
TFTP_TIMEOUT=10000
TFTP_SERVER=202.144.113.60
TFTP_BLKSIZE=1450
TFTP_VERBOSE=1
TFTP_MGMT_INTF=1
TFTP_FILE=/asr9k-mini-p.vm-4.2.3
TFTP_CHECKSUM=1
?=0
I have tried changing MGMT_INTF, CHECKSUM=0, BLKSIZE=1400 etc.
TFTP gets terminated after copying about 150Mb. Total VM size is 330Mb
Appreciate your quick response.
Darshak
netops044
Hi all,
I was able to complete the tftp operation using Solar Winds. I have completed the downgrade successfully.
Darshak
If you have RSP440, next time use USB directly connected in the RSP, it will be faster and easier than TFTP.
Cassio
