ASR9000 and IOS XR Questions
3alee
Hello
I'm new to ASR9000 and would like to ask the following:
1. What's the difference between EXEC mode and admin EXEC mode?  Or simply, when will I need use admin EXEC mode?
2. Is there a way to clear the configuration of an ASR9000 (something like "erase startup-config" in IOS)?
3. Is there any reference link or document which describes in detail about builit-in user groups?  e.g. what commands the "operator" group can issue?
4. My client is trying to migrate a Cisco 7609 to an ASR9K, what commands do the same things as the statement "mls qos aggregate-policer"?
Thanks.
Bryan Garland
Here are some answers to you questions:
The following URL gives some info about the exec modes.
http://www.cisco.com/en/US/docs/ios_xr_sw/iosxr_r3.8/general/command/reference/cm38mode.html
In short, Admin mode gets you to the admin plane.  This has access to SDRs and chassis info, like fabric cards, etc.
This has been asked may times in the forums.  Here is an example.  In short, you do a commit replace with a blank config.
https://supportforums.cisco.com/message/828839#828839
Here is a URL which breaks down commands and task-groups needed.
http://www.cisco.com/en/US/partner/docs/ios_xr_sw/iosxr_r3.9/task_ids/reference/guide/td39tid.html
There isn't the equivalent of an aggregate policer that applies to the chassis.  You can do policing via MQC on a per interface basis.
http://www.cisco.com/en/US/docs/routers/asr9000/software/qos/configuration/guide/qcasr9kover.html
Hope that helps,
Bryan
A million thanks!
