ASR9000 BNG pppoe prepaid
the radius will send to the BNG a Quote for the subscriber and once the subscriber finish this quote the BNG report this to the aaa radius server, is that doable on the ASR9000 BNG??
In other hand does ASR9000 support the prepaid feature with Radius??
Best Regards,
Khalil abdelkarim
Anyone can help?
Aleksandar Vidakovic
prepaid is supported with Diameter. See https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-4/bng/configuration/guide/b-bng-cg-asr9000-64x/b-bng-cg-asr9000-64x_chapter_01001.html
For radius implementations you have to go for an off box solution that pushes down a CoA to BNG when quota is exceeded.
