ASR9000 - IPSLA + Tracking
Pedro Morais
I'm trying to install a static route when an IP address is not reachable, using IPSLA (ICMP echo) + tracking. I've found all the documentation  and know how to configure it, however I'm strugling to configure the IPSLA operation. For some reason it doesn't start, and returns the following message:
RP/0/RSP0/CPU0:A9K-AGR1#sh ipsla statistics 1000
Tue Jul 23 11:25:21.203 WEST
No information available. Specified operation is not configured or operation may have aged out
The configuration is pretty straightforward and I believe it is correct:
ipsla
operation 1000
  type icmp echo
   vrf iub
   source address 10.187.253.137
   destination address 10.187.253.138
   frequency 5
ipsla
schedule operation 1000
  start-time now
  life forever
Could anyone help me find out what am I doing wrong?
Thanks.
Cheers,
Pedro
7 Replies 7
Hi Hu,
I'm aware of the tracking configuration. My issue is with the IPLSA probe that doesn't start.
Thanks.
Cheers,
Pedro
Hello Pedro,
There should be a problem with configuration vrf or OID typos, or the XR Version you are running doesnt support SLA.
You can verify the process status for ipsla using admin show proc | in sla
I have tried the above configuration you have - on IOX4.2.3
RP/0/RSP0/CPU0:EQUINOX-A9k#show run ipsla
Mon Jul 29 05:35:31.670 UTC
ipsla
operation 1000
  type icmp echo
   vrf A
   source address 192.168.1.7
   destination address 192.168.1.1
   frequency 5
  start-time now
  life forever
RP/0/RSP0/CPU0:EQUINOX-A9k#show ipsla statistics  1000
Mon Jul 29 05:35:53.130 UTC
Entry number: 1000
    Modification time: 05:30:29.383 UTC Mon Jul 29 2013
    Start time       : 05:30:29.387 UTC Mon Jul 29 2013
    Number of operations attempted: 65
    Number of operations skipped  : 0
    Current seconds left in Life  : Forever
    Operational state of entry    : Active
    Operational frequency(seconds): 5
    Connection loss occurred      : FALSE
    Timeout occurred              : FALSE
    Latest RTT (milliseconds)     : 1
    Latest operation start time   : 05:35:49.593 UTC Mon Jul 29 2013
    Next operation start time     : 05:35:54.593 UTC Mon Jul 29 2013
    Latest operation return code  : OK
    RTT Values:
      RTTAvg  : 1          RTTMin: 1          RTTMax : 1
      NumOfRTT: 1          RTTSum: 1          RTTSum2: 1
It shows no issues.
Thank You
Ahmed Moshref
Hi Ahmed,
That's strange, I'm also running 4.2.3. Could you share the SMUs you have installed?
Pedro
Check the
disk0:asr9k-mgbl-px-4.2.3
Thank You
Ahmed Moshref
Hi Ahmed,
I have that package installed:
RP/0/RSP0/CPU0:ASR-LAB01#sh install active summary
Tue Jul 30 10:34:29.775 WEST
  Active Packages:
    disk0:asr9k-p-4.2.3.CSCud37351-1.0.0
    disk0:asr9k-p-4.2.3.CSCud29892-1.0.0
    disk0:asr9k-mini-p-4.2.3
    disk0:asr9k-doc-p-4.2.3
    disk0:asr9k-p-4.2.3.CSCub22596-1.0.0
    disk0:asr9k-k9sec-p-4.2.3
    disk0:asr9k-p-4.2.3.CSCuc17410-1.0.0
    disk0:asr9k-mpls-p-4.2.3
    disk0:asr9k-mgbl-p-4.2.3
    disk0:asr9k-mcast-p-4.2.3
    disk0:asr9k-p-4.2.3.CSCud07536-1.0.0
    disk0:asr9k-p-4.2.3.CSCub74517-1.0.0
    disk0:asr9k-p-4.2.3.CSCub96985-1.0.0
    disk0:asr9k-p-4.2.3.CSCud54093-1.0.0
I strongly believe that this might be a SMU related issue.
Pedro
Hello Pedro,
On my lab , I dont have any SMUs installed- I still suspect the configuration.
Otherwise the only difference is the Card Type , I see yours are Trident cards, however it should be supported unless there is a missing SMU that solves a certain issue on that.
Thank You
Ahmed Moshref
