ASR9000 MVPN Finite Resources
dfranjoso
Hello all,
Which are the ASR9000 MVPN Finite Resources ?
Number of mVPN Routes
Number of mVPNs
Number of MDTs
And which max values for each parameter ? Are them differente among XR versions ?
Thank you!
Alexei Kiritchenko
Hi David,
these are currently supported values:
mVPNv4 Routes     16k
mVPNs             200
MDTs              200
for the moment they are the same across the versions.
Alex.
9 Replies 9
Alexei Kiritchenko
Hi David,
mVPNv4 Routes     16k
mVPNs             200
MDTs              200
Alex.
dfranjoso
Thanks Alexei!
dfranjoso
I forgot one thing,
The MDT (default and data)  entries will reside on the Global Mroute table. Which are the finite values for it ?
Hi David,
it is 16k Multicast Routes per system.
/A
dfranjoso
Thanks (again) Alexei. We can assume that the 200 MDTs are Default MDTs right ? Or does it englobes the Data MDTs too ?
200 is the total amount of tunnels: default + data.
/A
If 1 Customer Group = 1 Data MDT, that's not much ..
Onde again many thanks Akiritich ! This forum is an amazing tool !
Fresh numbers for 4.2.0
  • mVPN routes – 32K
  • mVPN VFR - 350
  • MDTs – 256/VRF
Hi Alexei,
do you have the currently supported values for 4.2.3?
Thanks!
