ASR9000 No ping response to bundle sub-interface
YEH
I configured an IP address on the bundle sub-interface of the ASR9000 and pinged the IP address, but got no response. I would like to know the cause.
interface Bundle-Ether2000.5
vrf TEST
ipv4 address 1.1.1.1 255.255.255.0
load-interval 30
encapsulation dot1q 5
#ping vrf TEST 1.1.1.1
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
Hello @YEH,
please share your vrf TEST configuration.
Best regards
M02@rt37
Hello @YEH
Check the status of interface BE2000.5
Do #sh ip int brief
-Up/Down ?
Best regards
Hello M02@rt37
The target sub-interface is up/up.
Loopback address and mgmt address had no ping errors.
Interface       IP-Address   Status  Protocol  Vrf-Name
Bundle-Ether2000    unassigned   Up    Up    default
Bundle-Ether2000.5    1.1.1.1      Up    Up    TEST
After checking the routing, the local route was not visible as shown below.
#show route vrf TEST local
Fri Aug 4 09:32:59.685 JST
% No matching routes found
Hello @YEH,
Best regards
Hello M02@rt37
I'm sorry
I have reconfigured it and the ping went through, so please close it. The cause is unknown.
