ASR9000/XR - BNG - L3 sub-interface limit for trunk (4096) error - what is the work around?
Andy Erickson
Level 4
Level 4
We currently have 7,500 broadband subscribers that we will be terminating on our ASR 9001.
Each one of our customers will be terminating on a sub-interface on a bundle.
On the 9k, there will be a QoS policy applied to rate-limit their broadband connection (see example below).
The challenge that we are running into right now is scaling beyond 4096 L3 sub-interfaces. When running through this in our lab, we receive the following fail message:
RP/0/RSP0/CPU0:BNG(config-subif)#show config failed
Tue Mar 10 18:32:07.552 UTC
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
interface Bundle-Ether10.6941171
!!% The L3 sub-interface limit for the trunk interface has been reached: Trunk limit for L3 subinterfaces on Bundle-Ether10 is 4096
We have added the following on to each of the sub-interfaces to "fake" out the NPU, but even with SPD configured, we are receiving the max 4096 message:
service-policy output <POLICY> subscriber-parent resource-id 0
service-policy output <POLICY> subscriber-parent resource-id 1
service-policy output <POLICY> subscriber-parent resource-id 2
service-policy output <POLICY> subscriber-parent resource-id 3
It is my understanding that we have a total of 4 resource ID's to use (0-3) and the ASR 9001 will support up to 32,000 sub-interfaces (system wide or 8,000 sub interfaces per resource-id).
See attached image for reference this design.
Main question to the community is what is the work around to scale beyond 4096 L3 sub-interfaces??
In our case it is not feasible to bring in additional bundles and spread the customers out.
Look forward to your responses.
Below is a sample configuration:
policy-map 10M_D
 class class-default
  shape average 10100000 bps
 end-policy-map
policy-map 10M_U
 class class-default
  police rate 10300000 bps
   exceed-action drop
 end-policy-map
interface Bundle-Ether10.650102
 description ---INT: GigabitEthernet0/0/1.650102 NAME: TEST #1---
 service-policy input 10M_U
 service-policy output 10M_D subscriber-parent resource-id 0
 ipv4 point-to-point
 local-proxy-arp
 ipv4 unnumbered Loopback10
 encapsulation dot1q 650 second-dot1q 102
interface Bundle-Ether10.650103
 description ---GigabitEthernet0/0/1.650103 NAME: TEST #2
 service-policy output 10M_D subscriber-parent resource-id 1
 ipv4 point-to-point
 local-proxy-arp
 encapsulation dot1q 650 second-dot1q 103
interface Bundle-Ether10.650104
 description ---INT: GigabitEthernet0/0/1.650104 NAME: TEST #3---
 service-policy output 10M_D subscriber-parent resource-id 2
 ipv4 point-to-point
 local-proxy-arp
 encapsulation dot1q 650 second-dot1q 104
interface Bundle-Ether10.650105
 description ---INT: GigabitEthernet0/0/1.650105 NAME: TEST #4---
 service-policy output 10M_D subscriber-parent resource-id 3
 ipv4 point-to-point
 local-proxy-arp
 encapsulation dot1q 650 second-dot1q 105
interface Bundle-Ether10.650106
 description ---INT: GigabitEthernet0/0/1.650106
 ipv4 point-to-point
 local-proxy-arp
 encapsulation dot1q 650 second-dot1q 106
interface Bundle-Ether10.650107
 description ---INT: GigabitEthernet0/0/1.650107
 ipv4 point-to-point
 local-proxy-arp
 encapsulation dot1q 650 second-dot1q 107
interface Bundle-Ether10.650108
 description ---INT: GigabitEthernet0/0/1.650108
 ipv4 point-to-point
 local-proxy-arp
 encapsulation dot1q 650 second-dot1q 108
interface Bundle-Ether10.650109
 description ---INT: GigabitEthernet0/0/1.650109
 ipv4 point-to-point
 local-proxy-arp
 encapsulation dot1q 650 second-dot1q 109
22 Replies 22
xander,
Thanks for sharing the QinQ username, works perfectly.
couple of design questions for you.
#1 - If i have >7500 subscribers that will be terminating on this bundle, would this be the best design to ensure that i can scale up to 32,000 subscribers on the BE <leveraging the subscriber-parent resource-id (0-4)>
EXAMPLE
interface Bundle-Ether10.100
 description BE10.100 – Area 1 - BNG customers - QinQ
 ipv4 point-to-point
 ipv4 unnumbered Loopback0
 service-policy type control subscriber IP_PM
 ipsubscriber ipv4 l2-connected
  initiator dhcp
 encapsulation ambiguous dot1q 100 second-dot1q any
interface Bundle-Ether10.200
 description BE10.200 – Area 2 - BNG customers - QinQ
 ipv4 point-to-point
  initiator dhcp
 encapsulation ambiguous dot1q 200 second-dot1q any
interface Bundle-Ether10.300
 description BE10.300 – Area 3 - BNG customers - QinQ
 ipv4 point-to-point
  initiator dhcp
 encapsulation ambiguous dot1q 300 second-dot1q any
interface Bundle-Ether10.400
 description BE10.400 – Area 4 - BNG customers - QinQ
 ipv4 point-to-point
 service-policy output <POLICY> subscriber-parent resource-id 4
  initiator dhcp
 encapsulation ambiguous dot1q 400 second-dot1q any
#2 - How do I verify in XR the CoA speed profile that is pushed down from RADIUS to a given subscriber?
I thought I might see the dynamic policy using the command below, but no luck.
Do you know the correct command?
RP/0/RSP0/CPU0:bng-asr9001#show policy-map inter be10.1.ip5
Wed Apr  1 14:12:06.390 UTC
Bundle-Ether10.1.ip5 input: __sub_55ffffff8b7dffffffad
Class class-default
  Classification statistics          (packets/bytes)     (rate - kbps)
    Matched             :              126959/10831088             14
    Transmitted         : N/A
    Total Dropped       : N/A
  Policy __sub_55ffffff8b7dffffffad_child1 Class class-default
      Transmitted         : N/A
      Total Dropped       :                 325/322582               0
    Policing statistics                (packets/bytes)     (rate - kbps)
      Policed(conform)    :              126634/10508506             14
      Policed(exceed)     :                 325/322582               0
      Policed(violate)    :                   0/0                    0
      Policed and dropped :                 325/322582
      Policed and dropped(parent policer)  : N/A
Bundle-Ether10.1.ip5 output: __sub_6effffff81ffffffbfffffffdb
Class class-default
    Matched             :              199642/280153690            453
    Transmitted         : N/A
    Total Dropped       : N/A
  Policy __sub_6effffff81ffffffbfffffffdb_child1 Class class-default
      Transmitted         : N/A
      Total Dropped       :               26930/38989025             61
      Policed(conform)    :              172712/241164665            392
      Policed(exceed)     :               26930/38989025             61
      Policed and dropped :               26930/38989025
#3 - CoA QoS profile -> I'm using the following avpair for ingress / egress qos.  However when validating against a speed test server, my results are well above the 10Mbps / 10Mbps I have provisioned.  Actual is more of in the ~15Mbps/15Mbps range.
Am I missing additional config in the policing section?
        cisco-avpair = "ip:qos-policy-in=add-class(sub, (class-default,class-default),police(10000))",
        cisco-avpair += "ip:qos-policy-out=add-class(sub, (class-default,class-default),police(10000))"
Appreciate it in advance xander!
-ae
you can use show qos int <bla> to see what is programmed in the hardware.
as for speed, probably have bundle and perfect loadbalancing... gives you member times the bw assigned.
so you want to set the bundle hash dest-ip on your bundle parent interface to hash only on dest-ip which is sub, to tie a sub to a member to prevent that.
qos resource ID is necessary when you have shapers in place and you need more then 8k per interface. (i.e. assign a chunk to a subinterface to give it access to 8k subs per subinterface).
you can't have more then 8k per subif.
xander
Hi Xander
 Is this "subscriber-parent resource-id" command can only manual apply? What's should I do if we assign qos profile from AAA?  My goal is want to reach 32K subscriber and assigned profile from AAA.
And also Is this "subscriber-parent resource-id" command are really apply qos to interface or is it fake?
Thank you
Pichet
hi pichet,
the qos policy you apply via radius is for the subscriber session itself.
the qos policy that is needed to assign the chunk is on the access (sub) interface.
in order to reach 32k subs with qos, you need to have 4 subinterfaces and you can terminate 8k subs per subinterface.
this subinterface can either be a vlan or a vlan range.
cheers
xander
You are always good respond. Thanks very much.
Pichet
The what I call "elephant trap" is done on a per mac bases, so before LPTS sees the discover, the elephant trap is already taking place which puts an abusing MAC/source access interface into the penalty bucket, almost like a super nanny type of approach (the naughty spot!).
You can always apply a policer on the subsciber directly also if you like, but for control plane protection, you don't need to, because it is there already.
I can dig up some info on the elephant trap if you like but it should be part of the docu also, if not, let me know and I'll get you sorted.
cheers!
xander
xander,
can you send the "elephant trap" info.
appreciate it!
-ae
I attached some pics for you from our training deck on BNG for this elephant flow trap.
And this is a ref to the official documentation:
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r5-3/bng/configuration/guide/b-bng-cg53xasr9k/b-bng-cg53xasr9k_chapter_0111.html#concept_60A7D05B2248411BB2DECA90FC2E7ABC
xander
