12-17-2012 08:49 AM
Hi all
I see that the following LC are an option for the ICL with the host A9K
The Cisco ASR 9000v satellite shelf has 44 gigabit ethernet SFP ports and four 10 gigabit ethernet SFP+ ports which can be connected to the following line cards that support 10 gigabit ethernet interfaces:
•the 24-port 10GE SE or 24-port 10GE TR line card
•the 36-Port 10GE SE or 36-Port 10GE TR line card
•the 80 Gigabyte modular line card when populated with 4-port 10GE Modular Port Adapters (MPA) or 2-port 10GE MPAs
•the 160 Gigabyte modular line card when populated with 4-port 10GE MPAs or 2-port 10GE MPAs
(source:
since none of the above mentioned cards are available for me at this time
i was wondering if for test purpose it is possible to connect the ICL to the SFP+ ports on the RSP440G (that I gathered are used for ICL in cluster mode)
or to a 1GE port on a 20X1GE MPA
Thanks in advance
LiorB
12-17-2012 01:03 PM
Hello Lior,
Unfortunately that is not possible.
The uplinks on 9000v are 10G, so we need to connect them to 10G LC on the host (ASR9k).
SPF+ ports on RSP440 are for a cluster inter-rack management only. They don’t support anything else.
/A
04-24-2014 08:53 AM
LiorB
Did you ever get anything to come about this? Did you ever get the ICL to go over 1GB connection back to in my case a ASR-9001 cluster?
Danny
04-24-2014 09:02 AM
Hay Danny
As you can see there is an answer below
for ASR9Kv only SFP+/XFP 10GB ports and not the SFP+ ports on the RSP as they are meant for cluster Mgmt function (nV satellite is nV but not a cluster...)
LB
BTW - there is at least 1 device that would connect via 1GB as satellite - this is the ASR901
04-24-2014 01:18 PM
The 9000v can now do 1G ICL, as of 5.1.1, on 1/45 and 1/46.
In cluster we have IRL (data) and EOBC (internal control).
Satellite has ICL (data/control).
Sam
04-24-2014 01:28 PM
Sam,
Thank you. I have read that also but I just cant get it to work. Still working on it and have a TAC case open. But nothing yet. I am running 5.1.1. When I set it up using 10 GB it works so I know the config is correct. Just need to figure out why its not working with the 1GB might just be the 1 GB SFP is not working. I have tried to different ones. Still nothing.
Danny
04-24-2014 01:39 PM
I will look for your case and also try this in my lab.
I'll get back to you with what I find.
Sam
04-24-2014 01:44 PM
I didn't open up the case. My associate did. Here is the case number SR 630038423.
Thank you!
04-25-2014 07:14 AM
Worked like a charm for me.
Satellite 65533
Status: Connected (Stable)
Type: asr9000v
MAC address: 6c9c.ed52.5424
IPv4 address: 192.168.100.254 (VRF: nv_mgmt)
Serial Number: CAT1635U13P
Remote version: Compatible (latest version)
ROMMON: 126.0 (Latest)
FPGA: 1.13 (Latest)
IOS: 322.6 (Latest)
Configured satellite fabric links:
GigabitEthernet0/0/0/0
Status: Satellite Ready
Remote ports: GigabitEthernet0/0/0-43
Port 45 IDPROM Data:
Product Id : GLC-SX-MMD
Product Name : 1GE
Version ID : V01
CLEI Code : WOTRB9VBAA
Top Assembly Part No. : 10-2626-01V01
Serial Number : FNS1722089F
PCB Revision : A
Vendor Name : CISCO
I looked at the optic from the case notes, Part number: QFBR-5766LP, and I am not familiar with that one. The SN does not show in the DB either. Given the operational state is 'down (reason: module is not supported)' tells me that this is some optic we don't support.
Here is the list of supported optics: http://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/data_sheet_c78-624747.html
Also please make sure that the satellite is up to date on rommon, fpga, and ios.
I'll keep my setup up until I hear back.
HTH,
Sam
04-25-2014 07:57 AM
Sam,
We switched our SFP to 1GB GLC-SX-MMD since the 1GB GLC-SX-MM isn't supported. Still didn't work. We connected back up with the 10GB connection and the satellite came right up again.
Satellite 100
Type: asr9000v
Description: Satelite 100
MAC address: 501c.bf10.d914
IPv4 address: 10.0.0.100 (VRF: default)
Serial Number: CAT1808U05J
Remote version: Compatibility Unknown (no local version)
ROMMON: 126.0
FPGA: 1.13
IOS: 202.0
TenGigE1/0/0/3
Remote ports: GigabitEthernet0/0/0-5
We noticed the IOS is only on 202.00 and yours was on IOS: 322.6. Do you have a document that shows us how to upgrade the satellite. When we do a install nv satellite 100 activate progress . It fails. We are currently running 5.1.1 on our 9001 cluster so do we just need to upgrade the satellite? .
Fri Apr 25 06:53:34.071 UTC
Cisco IOS XR Software, Version 5.1.1[Default]
Copyright (c) 2014 by Cisco Systems, Inc.
ROM: System Bootstrap, Version 2.03(20131022:110718) [ASR9K ROMMON],
atl11-expe-rtr01 uptime is 1 hour, 24 minutes
System image file is "bootflash:disk0/asr9k-os-mbi-5.1.1/0x100000/mbiasr9k-rp.vm"
cisco ASR9K Series (P4040) processor with 8388608K bytes of memory.
P4040 processor at 1500MHz, Revision 2.0
ASR-9001 Chassis
4 Management Ethernet
16 TenGigE
16 DWDM controller(s)
16 WANPHY controller(s)
20 GigabitEthernet
6 GigabitEthernet/IEEE 802.3 interface(s)
219k bytes of non-volatile configuration memory.
2880M bytes of hard disk.
3932144k bytes of disk0: (Sector size 512 bytes).
04-25-2014 08:02 AM
Def upgrade, 202 is from 4.2.1.
Try without the progress keyword.
Also, make sure that MPP is not blocking TFTP and you do not have a tftp homedir setup.
Sam
04-25-2014 08:37 AM
Sam,
Thank You! We got it all working after upgrading it.
Satellite 100
Type: asr9000v
FPGA: 1.13 (Latest)
IOS: 322.6 (Latest)
GigabitEthernet1/0/1/18
I appreciate all your help!
Danny
10-04-2019 01:02 PM
Hi Sam!
despite the response time, could you tell me how to remove tftp's home dir setting for default vrf? I have already enabled tftp on the port that is connected to satellite and etc. Thank you very much in advance!
10-05-2019 11:26 AM
It is only an issue if you have explicitly set the homedir, you can find whether it is configured or not by running 'show run | i tftp'.
Sam
10-05-2019 01:24 PM
thank you for the answer. I will check this on Monday morning because I don't have access to the router now. I will return here with the answer as soon as I can. best regards!
@smilstea wrote:It is only an issue if you have explicitly set the homedir, you can find whether it is configured or not by running 'show run | i tftp'.
Sam
