ASR9001 LC 0/0/CPU0 Booting Loop
Anycast
Hello everyone
   Please suggest me about logging and how can I fix it.I boot ASR9001 version 6.1.4 (I stock this unit about 1 year in cargo before install in customer site and first time turn on). During booting I see logging as below and I see at LC LED is Red and about 10 minutes is Green and then is red again (Cycle loop). I'm observe "admin show platform" LC 0/0/CPU0
state is  MBI-BOOTING -->MBI-RUNNING-->MBI-IOS XR PREP-->IOS XR RUN and about 10 minutes state looping again.
Please see logging below
LC/0/0/CPU0:Oct 3 22:24:07.023 : dumper[56]: %OS-DUMPER-4-SIGSEGV : Thread 1 received SIGSEGV - Segmentation Fault
LC/0/0/CPU0:Oct 3 22:24:07.024 : dumper[56]: %OS-DUMPER-4-SIGSEGV_INFO : Accessed BadAddr 0x2c8 at PC 0x4ba9fbec. Signal code 1 - SEGV_MAPPER. Address not mapped.
LC/0/0/CPU0:Oct 3 22:24:07.024 : dumper[56]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 741452 (pkg/bin/fab_arb)
LC/0/0/CPU0:Oct 3 22:25:03.537 : sysmgr[92]: %OS-SYSMGR-3-ERROR : fab_arb(1) (jid 181) exited, will be respawned with a delay (slow-restart)
LC/0/0/CPU0:Oct 3 22:25:03.538 : sysmgr[92]: %OS-SYSMGR-3-ERROR : fab_arb(181) (fail count 3) will be respawned in 10 seconds
RP/0/RSP0/CPU0:ios(admin)# LC/0/0/CPU0:Oct 3 22:25:13.652 : dumper[56]: %OS-DUMPER-4-SIGSEGV : Thread 1 received SIGSEGV - Segmentation Fault
LC/0/0/CPU0:Oct 3 22:25:13.652 : dumper[56]: %OS-DUMPER-4-SIGSEGV_INFO : Accessed BadAddr 0x2c8 at PC 0x4ba9fbec. Signal code 1 - SEGV_MAPPER. Address not mapped.
LC/0/0/CPU0:Oct 3 22:25:13.652 : dumper[56]: %OS-DUMPER-4-CRASH_INFO : Crashed pid = 745548 (pkg/bin/fab_arb)
RP/0/RSP0/CPU0:ios(admin)#dir harddisk:LC/0/0/CPU0:Oct 3 22:26:03.173 : fab_si[182]: %PLATFORM-STATS_INFRA-3-ERR_STR_1 : ErrStr:Unable to map stats infra shared mem
LC/0/0/CPU0:Oct 3 22:26:04.270 : sysmgr[92]: %OS-SYSMGR-3-ERROR : fab_arb(1) (jid 181) exited, will be respawned with a delay (slow-restart)
LC/0/0/CPU0:Oct 3 22:26:04.271 : sysmgr[92]: %OS-SYSMGR-3-ERROR : fab_arb(181) (fail count 4) will be respawned in 10 seconds
LC/0/0/CPU0:Oct 3 22:26:59.042 : sysmgr[92]: %OS-SYSMGR-3-ERROR : sysmgr_shutdown_cleanup_handler: shutdown script execution timed-out! Node will reset
LC/0/0/CPU0:Oct 3 22:26:59.043 : sysmgr[92]: %OS-SYSMGR-3-ERROR : sysmgr_shutdown_cleanup_handler: shutdown triggered by (fab_arb) did not complete in 45 seconds, shutting down
I have same issue with ASR 9010 LC 4T16GE-SE after reload LC The LC state MBI-BOOTING -->MBI-RUNNING-->MBI-IOS XR PREP-->IOS XR RUN and loop reboot after about 5 minutes
 I checked this LC by command: admin show hw-module fpd location all The LC show: fpga2,fpga3, fpga4 and rommon change original version firmware to 255.255. According the document and some cisco technician in this forum, the LC maybe hw LC fault
1 year ago, i had the same problem but I try to downgrade the fpd LC firmware to compatibilty with the IOS XR version and it go back OK
But now I do again but when I try to downgrade, the LC loop reboot so the progress can't continous to working
Can anybody help me Thanks
manmp
There seems to be some crashes seen, please open a TAC case, needs to be looked into details.
Manjunath M P
