06-12-2013 07:06 AM
How do I change the license location?
This router has the following error in the log:
LC/0/1/CPU0:Jun 12 11:59:12.171 : rsi_agent[313]: %LICENSE-ASR9K_LICENSE-2-INFRA_VRF_NEEDED : 2 VRF(s) are configured without a valid license / license configuration for A9K-iVRF-LIC in violation of the Software Right To Use Agreement. This feature may be disabled by the system without the appropriate license. Contact Cisco to purchase the license immediately to avoid potential service interruption.
(admin)#show license udi
Wed Jun 12 14:58:26.415 UTC
Local Chassis UDI Information:
PID : ASR-9006-AC-V2
S/N : FOX1648GFW3
Operation ID: 1
RP/0/RSP0/CPU0:wlr-msc-ppe1(admin)#sh license chassis
Wed Jun 12 14:58:46.030 UTC
FeatureID: A9K-MOD80-AIP-SE (Slot based, Permanent)
Total licenses 1
Available for use 0
Allocated to location 0
Active 1
Store name Permanent
Store index 1
Pool: Owner
Total licenses in pool: 1
Status: Available 0 Operational: 1
Locations with licenses: (Active/Allocated) [SDR]
0/0/CPU0 (1/0) [Owner]
S/N Information:
S/N FOX1648GFW3: 1 licenses [Valid]
Looking at this indicates I have a valid licence, but that it is in the wrong location, on 0/0/CPU0, not 0/1/CPU0 which is where the SE card is located.
How do I change this? Have tried through admin-config, no joy.
Andy
Solved! Go to Solution.
06-12-2013 01:34 PM
Hi Andy,
Please see the below from
Feature licenses are allocated to router slots and not cards. Therefore, if a card is replaced, the existing license is applied to the newly inserted card. For example, if you have eight licenses for Layer 3 VPN in the system, you can configure Layer 3 VPN features on any eight cards in the router, and the licenses are allocated to the slots within which the cards are installed. If a card is removed from one of these licensed slots, say slot 3, and entered into an empty slot with no license, say slot 5, the license remains with slot 3 and the feature cannot be activated on slot 5 with the permanent license entered earlier by the user. In this case, you can release the license to the appropriate license pool by removing the configuration of the card (while it is inserted), or by using the license move slot command. When you configure the feature on slot 5, the license is checked out.
Also see this link for the command usage
Licenses can be moved only if they are in the available state. In other words, you have to clear the feature configuration before a license can be released back to the appropriate license pool.
As the license is not currently available 'license move' will not work. This is because you are using features required by the license on 0/0/CPU0
Let me know if the 'license move slot' command does not work along with the syslog saying why it failed.
HTH,
Sam
06-12-2013 01:34 PM
Hi Andy,
HTH,
Sam
06-13-2013 04:32 AM
Hi Sam,
Thanks, that worked for me.
I have another question about licencies. if I have a router that has a management VRF configured, and this vrf is only appled to a loopback interface, not a physical interface do I need a licence?
Andy
06-14-2013 05:08 AM
Hi Andy,
TODAY: The LIC MGR will not query the system for a license when there is a vrf configured on virtual interfaces such as a BVI, loopback, or bundle interface.
This may change in the future.
HTH,
Sam
