ASR9006V2 Fan Tray ASR-9006-FAN-V2 Not All Fans Spinning
philclemens1835
It's interesting that on our FT1 tray in this chassis only two fans are spinning, as opposed to all of them on FT0.  After looking around our network, I see a few more similar situations in other chassis.  At first I assumed it was a power saving feature, but it's not looking that way on further inspection.  There are no alarms, so is a fan tray considered "OK" until all fans are dead?
RP/0/RSP0/CPU0:#admin show env fan
Thu Feb 16 09:02:44.617 CST
Fan speed (rpm) and run time (in hours) :
FAN0 FAN1 FAN2 FAN3 FAN4 FAN5
0/FT0/* (Speed)
12990 13020 12960 12960 12990 12960
0/FT0/* (Run Time)
N/A N/A N/A N/A N/A N/A
0/FT1/* (Speed)
14220 0 14160 0 0 0
0/FT1/* (Run Time)
RP/0/RSP0/CPU0:#
smilstea
No, that is not great. There is supposed to be a syslog when the fan speed drops. You can try to reseat the fantray but more than likely you will need to RMA the fantray, individual fans are not field replaceable.
Sam
smilstea
Sam
Thanks Sam.  You're right, I can see that when we installed this router we received those messages.  They were likely ignored at the time due to the other hundred messages that scroll across during the boot process.  Thanks for the help.
RP/0/RSP0/CPU0:#show logg | i FAN
Thu Feb 16 12:27:48.285 CST
RP/0/RSP0/CPU0:Oct 1 16:34:49.280 UTC: shelfmgr[430]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/FT1/SP ASR-9006-FAN-V2 state:PRESENT
RP/0/RSP0/CPU0:2022 Oct 1 11:35:56 : envmon[214]: %PLATFORM-ENVMON-3-FANTRAY_ALARM : Fan tray alarm on slot 0/FT1/SP
RP/0/RSP0/CPU0:2022 Oct 1 11:36:19 : envmon[214]: %PLATFORM-ENVMON-2-FANTRAY_FAIL : Fan tray failure on slot 0/FT1/SP
RP/0/RSP0/CPU0:2022 Oct 1 11:36:19 : envmon[214]: %PLATFORM-ENVMON-2-FAN_FAIL : Fan failure on slot 0/FT1/SP, fan 1, RPM 0
RP/0/RSP0/CPU0:2022 Oct 1 11:36:40 : envmon[214]: %PLATFORM-ENVMON-2-FAN_FAIL : Fan failure on slot 0/FT1/SP, fan 3, RPM 0
RP/0/RSP0/CPU0:2022 Oct 1 11:36:41 : envmon[214]: %PLATFORM-ENVMON-2-FAN_FAIL : Fan failure on slot 0/FT1/SP, fan 4, RPM 0
RP/0/RSP0/CPU0:#
Ghost_90
Hi Everyone,
I Have the Same issue, RMA  with another Fantry did solve the issue:
shelfmgr[419]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/FT0/SP ASR-9006-FAN state:BRINGDOWN
invmgr[260]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/FT0/SP, state: BRINGDOWN
shelfmgr[419]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/FT0/SP ASR-9006-FAN state:NOT-PRESENT
invmgr[260]: %PLATFORM-INV-6-OIROUT : OIR: Node 0/FT0/SP Sn: FOX1527XG5U removed
envmon[212]: %PLATFORM-ENVMON-2-FANTRAY_CLEAR : Fan tray failure cleared on slot 0/FT0/SP
envmon[212]: %PLATFORM-ENVMON-3-FANTRAY_ALARM_CLEAR : Fan tray alarm cleared on slot 0/FT0/SP
shelfmgr[419]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/FT0/SP ASR-9006-FAN state:PRESENT
invmgr[260]: %PLATFORM-INV-6-OIRIN : OIR: Node 0/FT0/SP Sn: FOX1527XG5U inserted
envmon[212]: %PLATFORM-ENVMON-3-FANTRAY_ALARM : Fan tray alarm on slot 0/FT0/SP
envmon[212]: %PLATFORM-ENVMON-2-FANTRAY_FAIL : Fan tray failure on slot 0/FT0/SP
envmon[212]: %PLATFORM-ENVMON-2-FAN_FAIL : Fan failure on slot 0/FT0/SP, fan 1, RPM 0
envmon[212]: %PLATFORM-ENVMON-2-FAN_FAIL : Fan failure on slot 0/FT0/SP, fan 4, RPM 0
envmon[212]: %PLATFORM-ENVMON-2-FAN_FAIL : Fan failure on slot 0/FT0/SP, fan 5, RPM 0
