05-06-2014 09:34 PM
Hi I am trying to get my 2xASR9010 to be as one virtual node. when i Try to do that according to the cisco website.
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-3/interfaces/configuration/guide/hc43xasr9kbook/hc43clst.html#wp1154602
it didnt work.. after some research i found out I need to upgrade the FPD that requred upgred using PIE files
RP/0/RSP0/CPU0:ios(admin)#sh hw-module fpd l al
Tue May 6 21:24:07.388 UTC
Existing Field Programmable Devices
HW Current SW Upg/
Location Card Type Version Type Subtype Inst Version Dng?
0/RSP0/CPU0 A9K-RSP440-TR 1.0 lc cbc 0 16.115 No
lc fpga1 0 0.10 No
lc fpga3 0 4.09 No
lc fpga2 0 1.06 No
lc rommon 0 0.71 No
0/FT0/SP ASR-9010-FAN-V2 1.0 ft cbc 7 29.11 No
0/FT1/SP ASR-9010-FAN-V2 1.0 ft cbc 8 29.11 No
0/BPID0/SP ASR-9010-BPID2 1.0 N/A cbc 11 7.103 Yes
0/RSP1/CPU0 A9K-RSP440-TR 1.0 lc cbc 0 16.115 No
lc fpga2 0 1.06 No
lc fpga3 0 4.09 No
lc fpga1 0 0.10 No
lc rommon 0 0.71 No
0/0/CPU0 A9K-MOD80-SE 1.0 lc cbc 0 20.117 Yes
lc fpga2 0 1.04 No
lc fpga4 0 1.05 No
lc rommon 0 2.00 No
0/0/0 A9K-MPA-20X1GE 1.102 spa fpga3 0 0.08 No
0/0/1 A9K-MPA-4X10GE 1.102 spa fpga6 1 1.06 No
0/1/CPU0 A9K-MOD80-SE 1.0 lc cbc 0 20.117 Yes
lc fpga2 0 1.04 No
lc fpga4 0 1.05 No
lc rommon 0 2.00 No
0/1/0 A9K-MPA-4X10GE 1.102 spa fpga6 0 1.06 No
NOTES:
1. One or more FPD needs an upgrade or a downgrade. This can be accomplished
using the "admin> upgrade hw-module fpd <fpd> location <loc>" CLI.
I have tried to upgrade these using "install activate "without much luck can you advise where i can find these PIE files to get this done,, I have to say the documents with relate to this is not good.
RP/0/RSP0/CPU0:ios(admin)#sh install log verbose
Tue May 6 21:29:57.176 UTC
Install operation 1 started by user 'root' via CLI at 09:47:00 UTC Sat Mar 01
2014.
(admin) install add /tftp://10.1.1.1/asr9k-fpd-px.pie-5.1.1 activate
synchronous
Install operation 1 completed successfully at 09:50:41 UTC Sat Mar 01 2014.
Install logs:
Install operation 1 '(admin) install add
/tftp://10.1.1.1/asr9k-fpd-px.pie-5.1.1 activate synchronous' started by
user 'root' via CLI at 09:47:00 UTC Sat Mar 01 2014.
Part 1 of 2 (add software): Started
Info: The following package is now available to be activated:
Info:
Info: disk0:asr9k-fpd-px-5.1.1
Info:
Info: The package can be activated across the entire router.
Info:
Part 1 of 2 (add software): Completed successfully
Part 2 of 2 (activate software): Started
Info: Install Method: Parallel Process Restart
Info: The changes made to software configurations will not be
Info: persistent across system reloads. Use the command '(admin)
Info: install commit' to make changes persistent.
Info: Please verify that the system is consistent following the
Info: software change using the following commands:
Info: show system verify
Info: install verify packages
Part 2 of 2 (activate software): Completed successfully
Summary:
Sub-operation 1:
Started at: 09:50:06 UTC Sat Mar 01 2014
Install method: Parallel Process Restart
Summary of changes on nodes 0/RSP0/CPU0, 0/RSP1/CPU0:
Activated: asr9k-fpd-5.1.1
Impacted: iosxr-infra-5.1.1
1 iosxr-infra processes affected (0 updated, 0 added, 0 removed, 1
impacted)
Summary of changes on nodes 0/0/CPU0, 0/1/CPU0:
No processes affected
Installation changes:
Sub-operation 1:
Installation changes on nodes 0/RSP0/CPU0, 0/RSP1/CPU0:
Adding file: RomleyX64.bin.gz
Adding file: amcc2035.bin.fpg.gz
Adding file: blackwidow.fpg.gz
Adding file: bridge3_maintenance.fpg.gz
Adding file: cbc_15_x.flash.gz
Adding file: cbc_16_x.flash.gz
Adding file: cbc_17_x.flash.gz
Adding file: cbc_18_x.flash.gz
Adding file: cbc_19_x.flash.gz
Adding file: cbc_1_x.flash.gz
Adding file: cbc_20_x.flash.gz
Adding file: cbc_21_x.flash.gz
Adding file: cbc_22_x.flash.gz
Adding file: cbc_23_x.flash.gz
Adding file: cbc_24_x.flash.gz
Adding file: cbc_25_x.flash.gz
Adding file: cbc_26_x.flash.gz
Adding file: cbc_28_x.flash.gz
Adding file: cbc_29_x.flash.gz
Adding file: cbc_2_x.flash.gz
Adding file: cbc_31_x.flash.gz
Adding file: cbc_32_x.flash.gz
Adding file: cbc_33_x.flash.gz
Adding file: cbc_3_x.flash.gz
Adding file: cbc_4_x.flash.gz
Adding file: cbc_5_x.flash.gz
Adding file: cbc_7_x.flash.gz
Adding file: cbc_odin_6_x.flash.gz
Adding file: cbc_valhalla_6_x.flash.gz
Adding file: ceop-icecube-br.fpd
Adding file: ceop-icecube-vh.gz
Adding file: ceop-icecube-wr.gz
Adding file: ceop-rommon-br.fpd
Adding file: ceop-rommon-vh.gz
Adding file: ceop-rommon-wr.gz
Adding file: ceop-snowball-br.fpd
Adding file: ceop-snowball-vh.gz
Adding file: ceop-snowball-wr.gz
Adding file: cgmac.fpg.gz
Adding file: cgmac_cb.fpg.gz
Adding file: chopper-comanche-vtwin-C.xsvf
Adding file: chopper-rom.fpd.gz.v2.2
Adding file: chopper-thumper_core_A.xsvf
Adding file: chopper-trex-bourget-C.xsvf
Adding file: chopper-trex-multistrada-6.jbc
Adding file: chopper-trex-vtwin-C.xsvf
Adding file: comp-asr9k-micro.vm
Adding file: delta_ac_primary_mcu.bin.gz
Adding file: delta_ac_sec54v_mcu.bin.gz
Adding file: delta_ac_sec5v_mcu.bin.gz
Adding file: delta_dc_primary_mcu.bin.gz
Adding file: delta_dc_sec54v_mcu.bin.gz
Adding file: delta_dc_sec5v_mcu.bin.gz
Adding file: emerson_ac_sec54v_mcu.bin.gz
Adding file: emerson_ac_sec5v_mcu.bin.gz
Adding file: emerson_dc_primary_mcu.bin.gz
Adding file: emerson_dc_sec54v_mcu.bin.gz
Adding file: emerson_dc_sec5v_mcu.bin.gz
Adding file: emux.fpg.gz
Adding file: firmimg.bin.gz
Adding file: forge_cupola.fpg.gz
Adding file: fpga_damselfly_hw39_sw1.7.xsvf
Adding file: fpga_gladiator_sw1.0.xsvf
Adding file: fpga_iguana48_hw3.0_sw1.101.xsvf
Adding file: fpga_iguanalite_hw1.2_sw1.2.xsvf
Adding file: fpga_iguanalite_hw3.0_sw1.101.xsvf
Adding file: fpga_ninja_hw1.0_sw1.0.xsvf
Adding file: fpga_scorpion_hw39_sw1.7.xsvf
Adding file: gambit.fpg.gz
Adding file: grindr.fpg.gz
Adding file: halberd.xsvf
Adding file: illugi.fpg.gz
Adding file: imio.fpg.gz
Adding file: imux.fpg.gz
Adding file: imux_cb.fpg.gz
Adding file: javelin-atlas_fpga_hw0.0_sw1.0.gz
Adding file: javelin-e3_fpga_hw0.0_sw1.4.gz
Adding file: javelin-rom_hw0.0_sw2.12.gz
Adding file: javelin-t3_fpga_hw0.0_sw1.4.gz
Adding file: lambi.fpg.gz
Adding file: lance2.jbc
Adding file: lc_amistad.fpg.gz
Adding file: lc_amistad_365T.fpg.gz
Adding file: lc_atli.fpg.gz
Adding file: lc_banki.fpg.gz
Adding file: lc_bridge3.fpg.gz
Adding file: lc_bridge4.fpg.gz
Adding file: lc_catapult3.fpg.gz
Adding file: lc_catapult4.fpg.gz
Adding file: lc_chariot3.fpg.gz
Adding file: lc_currus3.fpg.gz
Adding file: lc_currus4.fpg.gz
Adding file: lc_drakar.fpg.gz
Adding file: lc_emux.fpg.gz
Adding file: lc_emux_cb.fpg.gz
Adding file: lc_horse.fpg.gz
Adding file: lc_hytop.fpg.gz
Adding file: lc_mace3.fpg.gz
Adding file: lc_magnus.fpg.gz
Adding file: lc_p4080_iofpga.fpg.gz
Adding file: lc_phyctrl_8x10lr.fpg.gz
Adding file: lc_portctrl_8x10lr.fpg.gz
Adding file: lc_raven.fpg.gz
Adding file: lc_runa.fpg.gz
Adding file: lc_rxmux.fpg.gz
Adding file: lc_rxmux4.fpg.gz
Adding file: lc_serpent.fpg.gz
Adding file: lc_smith.fpg.gz
Adding file: lc_sparkplug.fpg.gz
Adding file: lc_super_atli.fpg.gz
Adding file: lc_super_banki.fpg.gz
Adding file: lc_super_runa.fpg.gz
Adding file: lc_tomcat.fpg.gz
Adding file: lc_valkyrie.fpg.gz
Adding file: lc_wolfe.fpg.gz
Adding file: longbow3.jbc
Adding file: maverick-atlas_fpga.gz
Adding file: maverick-rom.gz
Adding file: maverick_v2-codex.fpd.gz
Adding file: maverick_v2-rom.fpd.gz
Adding file: mtron_fc_oakland.fpg.gz
Adding file: mtron_rp_dti.fpg.gz
Adding file: mtron_rp_newport.fpg.gz
Adding file: mtron_rp_redondo.fpg.gz
Adding file: mtron_rp_rodimus.fpg.gz
Adding file: mtron_rp_scimitar.fpg.gz
Adding file: mtron_rp_timex.fpg.gz
Adding file: mtron_rp_x86rmon.bin.gz
Adding file: patriot-atlas_fpga.gz_hw0.100_sw2.4.gz
Adding file: patriot-rom_hw0.100_sw2.12.gz
Adding file: patriot-t3_fpga_hw0.100_sw0.11.gz
Adding file: patriot-t3_fpga_hw0.200_sw1.4.gz
Adding file: pixie.fpg.gz
Adding file: prowler-atlas_fpga.gz
Adding file: prowler-et3_fpga.gz
Adding file: prowler-rom.gz
Adding file: ragnar.fpg.gz
Adding file: rogue.fpg.gz
Adding file: rommon-ironmanlc-ironmanlc-B.bin.gz
Adding file: rommon-ironmanrp-ironmanrp-A.bin.gz
Adding file: rommon-ironmanrp-ironmanrp-B.bin.gz
Adding file: rommon-jugg-p40xx-lc4-B.bin.gz
Adding file: rommon-scol-p40xx-lc4-B.bin.gz
Adding file: rommon-viking-8641d-lc2-A.bin.gz
Adding file: rommon-viking-8641d-lc2-B.bin.gz
Adding file: rommon-viking-8641d-lc3-A.bin.gz
Adding file: rommon-viking-8641d-lc3-B.bin.gz
Adding file: rommon-viking-8641d-lc5-A.bin.gz
Adding file: rommon-viking-8641d-lc5-B.bin.gz
Adding file: rommon-viking-8641d-lc5_8G-B.bin.gz
Adding file: rommon-viking-8641d-lc6-A.bin.gz
Adding file: rommon-viking-8641d-lc6-B.bin.gz
Adding file: rommon-viking-8641d-rsp2-A.bin.gz
Adding file: rommon-viking-8641d-rsp2-B.bin.gz
Adding file: rommon-viking-p40xx-eval-B.bin.gz
Adding file: rommon-viking-p40xx-lc4-A.bin.gz
Adding file: rommon-viking-p40xx-lc4-B.bin.gz
Adding file: rsp3_dao.fpg.gz
Adding file: rsp3_dti.fpg.gz
Adding file: rsp3_laguna.fpg.gz
Adding file: rsp3_x86rmon.bin.gz
Adding file: rsp_lb3.fpg.gz
Adding file: rsp_punt.fpg.gz
Adding file: rsp_uti.fpg.gz
Adding file: sage.fpg.gz
Adding file: ss_fc_oakland.fpg.gz
Adding file: starkad.fpg.gz
Adding file: tempo.rbf.fpg.gz
Adding file: whiplash.fpg.gz
Replacing DLL: libplmgr_pi_accounting_supp.dll
Replacing DLL: libplmgr_pi_subscriber_control_supp.dll
Installation changes on nodes 0/0/CPU0, 0/1/CPU0:
Installation impact details:
Sub-operation 1:
Output format:
<Level> (<Impact>:<Note>) <Name> <Type>[package:component]
Level : the distance from the process along the DLL dependency chain
Impact : a one character indication of how this server or DLL is
impacted:
C modified; A added; R removed; I impacted by its dependencies
Note : blank, or one of these annotations:
d duplicate (this DLL has already been listed previously for this
process)
s self-managing (this server self-manages changes in its dependencies
Name : the name of this server or DLL
Type : "server" or "DLL"
Package : the Package containing this server or DLL
Component: the source code component containing this server or DLL
Node class: CRS-RP-X86
2 nodes: 0/RSP0/CPU0, 0/RSP1/CPU0
1 Changed or Impacted Servers that will be restarted
0 (I: ) policymgr_rp server
[iosxr-infra:policymgr.x86e]
1 (C: ) libplmgr_pi_accounting_supp.dll DLL
1 (C: ) libplmgr_pi_subscriber_control_supp.dll DLL
Node class: NP200-MOD-SMEM
2 nodes: 0/0/CPU0, 0/1/CPU0
Install operation 2 started by user 'root' via CLI at 09:50:44 UTC Sat Mar 01
2014.
(admin) install commit
Install operation 2 completed successfully at 09:50:45 UTC Sat Mar 01 2014.
Install logs:
Install operation 2 '(admin) install commit' started by user 'root' via CLI
at 09:50:44 UTC Sat Mar 01 2014.
Install operation 3 started by user 'root' via CLI at 10:02:36 UTC Sat Mar 01
2014.
(admin) install deactivate disk0:asr9k-fpd-px-5.1.1
Install operation 3 completed successfully at 10:03:26 UTC Sat Mar 01 2014.
Install logs:
Install operation 3 '(admin) install deactivate disk0:asr9k-fpd-px-5.1.1'
started by user 'root' via CLI at 10:02:36 UTC Sat Mar 01 2014.
Summary:
Sub-operation 1:
Started at: 10:02:54 UTC Sat Mar 01 2014
Deactivated: asr9k-fpd-5.1.1
Sub-operation 1:
Removing file: RomleyX64.bin.gz
Removing file: amcc2035.bin.fpg.gz
Removing file: blackwidow.fpg.gz
Removing file: bridge3_maintenance.fpg.gz
Removing file: cbc_15_x.flash.gz
Removing file: cbc_16_x.flash.gz
Removing file: cbc_17_x.flash.gz
Removing file: cbc_18_x.flash.gz
Removing file: cbc_19_x.flash.gz
Removing file: cbc_1_x.flash.gz
Removing file: cbc_20_x.flash.gz
Removing file: cbc_21_x.flash.gz
Removing file: cbc_22_x.flash.gz
Removing file: cbc_23_x.flash.gz
Removing file: cbc_24_x.flash.gz
Removing file: cbc_25_x.flash.gz
Removing file: cbc_26_x.flash.gz
Removing file: cbc_28_x.flash.gz
Removing file: cbc_29_x.flash.gz
Removing file: cbc_2_x.flash.gz
Removing file: cbc_31_x.flash.gz
Removing file: cbc_32_x.flash.gz
Removing file: cbc_33_x.flash.gz
Removing file: cbc_3_x.flash.gz
Removing file: cbc_4_x.flash.gz
Removing file: cbc_5_x.flash.gz
Removing file: cbc_7_x.flash.gz
Removing file: cbc_odin_6_x.flash.gz
Removing file: cbc_valhalla_6_x.flash.gz
Removing file: ceop-icecube-br.fpd
Removing file: ceop-icecube-vh.gz
Removing file: ceop-icecube-wr.gz
Removing file: ceop-rommon-br.fpd
Removing file: ceop-rommon-vh.gz
Removing file: ceop-rommon-wr.gz
Removing file: ceop-snowball-br.fpd
Removing file: ceop-snowball-vh.gz
Removing file: ceop-snowball-wr.gz
Removing file: cgmac.fpg.gz
Removing file: cgmac_cb.fpg.gz
Removing file: chopper-comanche-vtwin-C.xsvf
Removing file: chopper-rom.fpd.gz.v2.2
Removing file: chopper-thumper_core_A.xsvf
Removing file: chopper-trex-bourget-C.xsvf
Removing file: chopper-trex-multistrada-6.jbc
Removing file: chopper-trex-vtwin-C.xsvf
Removing file: comp-asr9k-micro.vm
Removing file: delta_ac_primary_mcu.bin.gz
Removing file: delta_ac_sec54v_mcu.bin.gz
Removing file: delta_ac_sec5v_mcu.bin.gz
Removing file: delta_dc_primary_mcu.bin.gz
Removing file: delta_dc_sec54v_mcu.bin.gz
Removing file: delta_dc_sec5v_mcu.bin.gz
Removing file: emerson_ac_sec54v_mcu.bin.gz
Removing file: emerson_ac_sec5v_mcu.bin.gz
Removing file: emerson_dc_primary_mcu.bin.gz
Removing file: emerson_dc_sec54v_mcu.bin.gz
Removing file: emerson_dc_sec5v_mcu.bin.gz
Removing file: emux.fpg.gz
Removing file: firmimg.bin.gz
Removing file: forge_cupola.fpg.gz
Removing file: fpga_damselfly_hw39_sw1.7.xsvf
Removing file: fpga_gladiator_sw1.0.xsvf
Removing file: fpga_iguana48_hw3.0_sw1.101.xsvf
Removing file: fpga_iguanalite_hw1.2_sw1.2.xsvf
Removing file: fpga_iguanalite_hw3.0_sw1.101.xsvf
Removing file: fpga_ninja_hw1.0_sw1.0.xsvf
Removing file: fpga_scorpion_hw39_sw1.7.xsvf
Removing file: gambit.fpg.gz
Removing file: grindr.fpg.gz
Removing file: halberd.xsvf
Removing file: illugi.fpg.gz
Removing file: imio.fpg.gz
Removing file: imux.fpg.gz
Removing file: imux_cb.fpg.gz
Removing file: javelin-atlas_fpga_hw0.0_sw1.0.gz
Removing file: javelin-e3_fpga_hw0.0_sw1.4.gz
Removing file: javelin-rom_hw0.0_sw2.12.gz
Removing file: javelin-t3_fpga_hw0.0_sw1.4.gz
Removing file: lambi.fpg.gz
Removing file: lance2.jbc
Removing file: lc_amistad.fpg.gz
Removing file: lc_amistad_365T.fpg.gz
Removing file: lc_atli.fpg.gz
Removing file: lc_banki.fpg.gz
Removing file: lc_bridge3.fpg.gz
Removing file: lc_bridge4.fpg.gz
Removing file: lc_catapult3.fpg.gz
Removing file: lc_catapult4.fpg.gz
Removing file: lc_chariot3.fpg.gz
Removing file: lc_currus3.fpg.gz
Removing file: lc_currus4.fpg.gz
Removing file: lc_drakar.fpg.gz
Removing file: lc_emux.fpg.gz
Removing file: lc_emux_cb.fpg.gz
Removing file: lc_horse.fpg.gz
Removing file: lc_hytop.fpg.gz
Removing file: lc_mace3.fpg.gz
Removing file: lc_magnus.fpg.gz
Removing file: lc_p4080_iofpga.fpg.gz
Removing file: lc_phyctrl_8x10lr.fpg.gz
Removing file: lc_portctrl_8x10lr.fpg.gz
Removing file: lc_raven.fpg.gz
Removing file: lc_runa.fpg.gz
Removing file: lc_rxmux.fpg.gz
Removing file: lc_rxmux4.fpg.gz
Removing file: lc_serpent.fpg.gz
Removing file: lc_smith.fpg.gz
Removing file: lc_sparkplug.fpg.gz
Removing file: lc_super_atli.fpg.gz
Removing file: lc_super_banki.fpg.gz
Removing file: lc_super_runa.fpg.gz
Removing file: lc_tomcat.fpg.gz
Removing file: lc_valkyrie.fpg.gz
Removing file: lc_wolfe.fpg.gz
Removing file: longbow3.jbc
Removing file: maverick-atlas_fpga.gz
Removing file: maverick-rom.gz
Removing file: maverick_v2-codex.fpd.gz
Removing file: maverick_v2-rom.fpd.gz
Removing file: mtron_fc_oakland.fpg.gz
Removing file: mtron_rp_dti.fpg.gz
Removing file: mtron_rp_newport.fpg.gz
Removing file: mtron_rp_redondo.fpg.gz
Removing file: mtron_rp_rodimus.fpg.gz
Removing file: mtron_rp_scimitar.fpg.gz
Removing file: mtron_rp_timex.fpg.gz
Removing file: mtron_rp_x86rmon.bin.gz
Removing file: patriot-atlas_fpga.gz_hw0.100_sw2.4.gz
Removing file: patriot-rom_hw0.100_sw2.12.gz
Removing file: patriot-t3_fpga_hw0.100_sw0.11.gz
Removing file: patriot-t3_fpga_hw0.200_sw1.4.gz
Removing file: pixie.fpg.gz
Removing file: prowler-atlas_fpga.gz
Removing file: prowler-et3_fpga.gz
Removing file: prowler-rom.gz
Removing file: ragnar.fpg.gz
Removing file: rogue.fpg.gz
Removing file: rommon-ironmanlc-ironmanlc-B.bin.gz
Removing file: rommon-ironmanrp-ironmanrp-A.bin.gz
Removing file: rommon-ironmanrp-ironmanrp-B.bin.gz
Removing file: rommon-jugg-p40xx-lc4-B.bin.gz
Removing file: rommon-scol-p40xx-lc4-B.bin.gz
Removing file: rommon-viking-8641d-lc2-A.bin.gz
Removing file: rommon-viking-8641d-lc2-B.bin.gz
Removing file: rommon-viking-8641d-lc3-A.bin.gz
Removing file: rommon-viking-8641d-lc3-B.bin.gz
Removing file: rommon-viking-8641d-lc5-A.bin.gz
Removing file: rommon-viking-8641d-lc5-B.bin.gz
Removing file: rommon-viking-8641d-lc5_8G-B.bin.gz
Removing file: rommon-viking-8641d-lc6-A.bin.gz
Removing file: rommon-viking-8641d-lc6-B.bin.gz
Removing file: rommon-viking-8641d-rsp2-A.bin.gz
Removing file: rommon-viking-8641d-rsp2-B.bin.gz
Removing file: rommon-viking-p40xx-eval-B.bin.gz
Removing file: rommon-viking-p40xx-lc4-A.bin.gz
Removing file: rommon-viking-p40xx-lc4-B.bin.gz
Removing file: rsp3_dao.fpg.gz
Removing file: rsp3_dti.fpg.gz
Removing file: rsp3_laguna.fpg.gz
Removing file: rsp3_x86rmon.bin.gz
Removing file: rsp_lb3.fpg.gz
Removing file: rsp_punt.fpg.gz
Removing file: rsp_uti.fpg.gz
Removing file: sage.fpg.gz
Removing file: ss_fc_oakland.fpg.gz
Removing file: starkad.fpg.gz
Removing file: tempo.rbf.fpg.gz
Removing file: whiplash.fpg.gz
Sub-operation 1:
Output format:
impacted:
process)
Install operation 4 started by user 'root' via CLI at 10:05:40 UTC Sat Mar 01
2014.
Install operation 4 completed successfully at 10:05:42 UTC Sat Mar 01 2014.
Install logs:
Install operation 4 '(admin) install commit' started by user 'root' via CLI
at 10:05:40 UTC Sat Mar 01 2014.
Install operation 5 started by user 'root' via CLI at 02:16:31 UTC Sat Mar 01
2014.
(admin) install add tar /harddisk:/ASR9K-iosxr-px-5.1.1_BUN.tar synchronous
Install operation 5 completed successfully at 02:21:49 UTC Sat Mar 01 2014.
Install logs:
Install operation 5 '(admin) install add tar
/harddisk:/ASR9K-iosxr-px-5.1.1_BUN.tar synchronous' started by user 'root'
via CLI at 02:16:31 UTC Sat Mar 01 2014.
Info: The following files were extracted from the tar file
Info: '/harddisk:/ASR9K-iosxr-px-5.1.1_BUN.tar' and will be added to
Info: the entire router:
Info:
Info: asr9k-bng-px.pie-5.1.1
Info: asr9k-doc-px.pie-5.1.1
Info: asr9k-fpd-px.pie-5.1.1
Info: asr9k-mcast-px.pie-5.1.1
Info: asr9k-mgbl-px.pie-5.1.1
Info: asr9k-mpls-px.pie-5.1.1
Info: asr9k-services-px.pie-5.1.1
Info: asr9k-video-px.pie-5.1.1
Info:
Warning: Skipped adding the following package as it was already present:
Warning: disk0:asr9k-fpd-px-5.1.1
Warning: Please check:
Warning: - the set of active packages using '(admin) show install
Warning: active'.
Warning: - the set of inactive packages using '(admin) show install
Warning: inactive'.
Info: The following packages are now available to be activated:
Info:
Info: disk0:asr9k-bng-px-5.1.1
Info: disk0:asr9k-doc-px-5.1.1
Info: disk0:asr9k-mcast-px-5.1.1
Info: disk0:asr9k-mgbl-px-5.1.1
Info: disk0:asr9k-mpls-px-5.1.1
Info: disk0:asr9k-services-px-5.1.1
Info: disk0:asr9k-video-px-5.1.1
Info:
Info: The packages can be activated across the entire router.
Info:
Install operation 6 started by user 'root' via CLI at 02:21:51 UTC Sat Mar 01
2014.
Install operation 6 completed successfully at 02:21:53 UTC Sat Mar 01 2014.
Install logs:
Install operation 6 '(admin) install commit' started by user 'root' via CLI
at 02:21:51 UTC Sat Mar 01 2014.
Install operation 7 started by user 'root' via CLI at 02:22:05 UTC Sat Mar 01
2014.
(admin) install add /tftp://10.1.1.1/asr9k-k9sec-px.pie-5.1.1 activate
synchronous
Install operation 7 completed successfully at 02:23:12 UTC Sat Mar 01 2014.
Install logs:
Install operation 7 '(admin) install add
/tftp://10.1.1.1/asr9k-k9sec-px.pie-5.1.1 activate synchronous' started by
user 'root' via CLI at 02:22:05 UTC Sat Mar 01 2014.
Info:
Info: disk0:asr9k-k9sec-px-5.1.1
Info:
Info:
Summary:
Sub-operation 1:
Started at: 02:22:40 UTC Sat Mar 01 2014
Activated: asr9k-k9sec-supp-5.1.1
iosxr-security-5.1.1
1 asr9k-k9sec-supp processes affected (0 updated, 1 added, 0
removed, 0 impacted)
9 iosxr-security processes affected (0 updated, 9 added, 0 removed,
0 impacted)
Sub-operation 1:
Adding executable: ce_cmd
Adding and starting process: cepki
Adding executable: clear_ssh_session
Adding executable: cof_trace_show
Adding and starting process: crypto_edm
Adding executable: crypto_engine_cmd
Adding executable: crypto_ipsec_show_tech
Adding executable: crypto_isakmp_show_tech
Adding and starting process: crypto_monitor
Adding executable: crypto_session_show_tech
Adding and starting process: ike
Adding executable: ike_cmd
Adding executable: ike_show_ltrace
Adding executable: ike_test
Adding executable: ikev2_cmd
Adding executable: ipsec_cmd
Adding and starting process: ipsec_mp
Adding and starting process: ipsec_pp
Adding executable: ipsec_show_ltrace
Adding and starting process: ipsec_simp
Adding executable: ipsec_test
Adding and starting process: of_agent
Adding executable: ofa_action
Adding executable: ofa_show
Adding executable: pki_cmd
Adding executable: pki_get_cert
Adding executable: scp
Adding executable: scp_server
Adding executable: sdna_show_techsupport
Adding executable: sftp
Adding executable: sftp_server
Adding executable: sftp_test
Adding executable: show_ssh_alginfo
Adding executable: show_ssh_session
Adding executable: show_ssl
Adding executable: ssh
Adding executable: ssh1
Adding and starting process: ssh_conf_verifier
Adding and starting process: ssh_server
Adding executable: sshd1
Adding executable: sshd_child_handler
Adding file: lo_ipsec_ns_cfg__api.configinfo
Adding file: sh_cepki_1_ns_cfg__api.configinfo
Adding file: sh_cepki_2_ns_cfg__api.configinfo
Adding file: sh_crypto_mibs_ns_cfg__api.configinfo
Adding file: sh_ike_ns_cfg__api.configinfo
Adding file: sh_ipsec_ns_cfg__api.configinfo
Adding file: sh_sdna_ns_cfg__api.configinfo
Adding file: sh_ssh_ns_cfg__api.configinfo
Adding DLL: libcepki_utils.dll
Adding DLL: libconddbgdb.dll
Adding DLL: libcrypto.dll
Adding DLL: libcrypto_client.dll
Adding DLL: libcrypto_engine_bag_desc.dll
Adding DLL: libcrypto_engine_edm_server.dll
Adding DLL: libcrypto_ike_bag_desc.dll
Adding DLL: libcrypto_ike_internal_bag_desc.dll
Adding DLL: libcrypto_ipsec_bag_desc.dll
Adding DLL: libikeclient.dll
Adding DLL: libikecommon.dll
Adding DLL: libikeparse.dll
Adding DLL: libikepubkey.dll
Adding DLL: libikev2_core.dll
Adding DLL: libikev2_osal.dll
Adding DLL: libipp_client.dll
Adding DLL: libipsec_cf.dll
Adding DLL: libipsec_client.dll
Adding DLL: libipsec_cmd.dll
Adding DLL: libipsec_ss.dll
Adding DLL: libipsec_sw_ce.dll
Adding DLL: libpki.dll
Adding DLL: libpki_client.dll
Adding DLL: libsdna_debug.dll
Adding DLL: libsdna_parser.dll
Adding DLL: libsdna_show_bag_desc.dll
Adding DLL: libsftp.dll
Adding DLL: libssh_xml_bag_desc.dll
Adding DLL: libssl.dll
Adding DLL: libssl_session_bag_desc.dll
Adding DLL: libcrypto_error.dll
Adding DLL: libikeerror.dll
Adding DLL: libimp_error.dll
Adding DLL: libpki_error.dll
Adding DLL: libipsecflowmonmib.dll
Adding DLL: libipsecmib.dll
Adding DLL: libipsecpolmapmib.dll
Adding file: ipsec.mib
Adding file: ipsecflowmon.mib
Adding file: ipsecpolmap.mib
Adding file: cepki_cmds.parser
Adding file: cond_debug_cmds.parser
Adding file: crypto_engine_cmds.parser
Adding file: ike.parser
Adding file: ipsec_cmds.parser
Adding file: ipsecflowmonmib_cmds.parser
Adding file: ipsecmib_cmds.parser
Adding file: ipsecpolmapmib_cmds.parser
Adding file: ofa.parser
Adding file: ssh.parser
Adding file: ssl.parser
Adding file: lo_k9sec_ns_cfg__api.partitioninfo
Adding file: sh_k9sec_ns_cfg__api.partitioninfo
Adding file: ipsec.caps
Adding file: ipsec.intf
Adding file: crypto_cepki_cfg.schema
Adding file: crypto_cepki_cfg.xsd
Adding file: crypto_cepki_oper.schema
Adding file: crypto_cepki_oper.xsd
Adding file: crypto_engine.xsd
Adding file: crypto_engine_oper.schema
Adding file: crypto_engine_oper.xsd
Adding file: crypto_ike.xsd
Adding file: crypto_ike_action.schema
Adding file: crypto_ike_action.xsd
Adding file: crypto_ike_cfg.schema
Adding file: crypto_ike_cfg.xsd
Adding file: crypto_ike_oper.schema
Adding file: crypto_ike_oper.xsd
Adding file: crypto_ipsec.xsd
Adding file: crypto_ipsec_action.schema
Adding file: crypto_ipsec_action.xsd
Adding file: crypto_ipsec_cfg.schema
Adding file: crypto_ipsec_cfg.xsd
Adding file: crypto_ipsec_cfg_if.schema
Adding file: crypto_ipsec_cfg_if.xsd
Adding file: crypto_ipsec_common.schema
Adding file: crypto_ipsec_common.xsd
Adding file: crypto_ipsec_imp_oper.schema
Adding file: crypto_ipsec_imp_oper.xsd
Adding file: crypto_ipsec_ipp_oper.schema
Adding file: crypto_ipsec_ipp_oper.xsd
Adding file: crypto_ipsec_simp_oper.schema
Adding file: crypto_ipsec_simp_oper.xsd
Adding file: crypto_ssh_cfg.schema
Adding file: crypto_ssh_cfg.xsd
Adding file: crypto_ssh_oper.schema
Adding file: crypto_ssh_oper.xsd
Adding file: crypto_ssl_oper.schema
Adding file: crypto_ssl_oper.xsd
Adding file: ipsecflowmonmib_cfg.schema
Adding file: ipsecflowmonmib_cfg.xsd
Adding file: ssh_xml.xsd
Adding file: ssl_session.xsd
Adding file: cepki.startup
Adding file: crypto_edm.startup
Adding file: crypto_monitor.startup
Adding file: ike.startup
Adding file: imp.startup
Adding file: ipp.startup
Adding file: ofa.startup
Adding file: simp.startup
Adding file: ssh_conf_verifier.startup
Adding file: sshd.startup
Sub-operation 1:
Output format:
impacted:
process)
10 New Servers to be started
0 (A: ) cepki server
[iosxr-security:crypto-cepki.x86e]
0 (A: ) crypto_edm server
[iosxr-security:crypto-ssl.x86e]
0 (A: ) crypto_monitor server
[iosxr-security:crypto-debug.x86e]
0 (A: ) ike server
[iosxr-security:crypto-ike.x86e]
0 (A: ) ipsec_mp server
[iosxr-security:crypto-ipsec.x86e]
0 (A: ) ipsec_pp server
0 (A: ) ipsec_simp server
0 (A: ) of_agent server
[asr9k-k9sec-supp:infra-openflow.x86e]
0 (A: ) ssh_conf_verifier server
[iosxr-security:crypto-ssh.x86e]
0 (A: ) ssh_server server
Install operation 8 started by user 'root' via CLI at 02:23:16 UTC Sat Mar 01
2014.
Install operation 8 completed successfully at 02:23:18 UTC Sat Mar 01 2014.
Install logs:
Install operation 8 '(admin) install commit' started by user 'root' via CLI
at 02:23:16 UTC Sat Mar 01 2014.
Install operation 9 started by user 'admin' via CLI at 03:12:42 UTC Tue Apr 15
2014.
(admin) install add /disk0:asr9k-mpls-px-5.1.1
Install operation 9 failed at 03:12:43 UTC Tue Apr 15 2014.
Install logs:
Install operation 9 '(admin) install add /disk0:asr9k-mpls-px-5.1.1'
started by user 'admin' via CLI at 03:12:42 UTC Tue Apr 15 2014.
Error: Cannot proceed with the add operation because the pie
Error: '/disk0:/asr9k-mpls-px-5.1.1' is a directory.
Error: Suggested steps to resolve this:
Error: - check the name of the pie.
Error: - check the location of the pie.
Install operation 10 started by user 'admin' via CLI at 03:14:02 UTC Tue Apr 15
2014.
(admin) install add /disk0:asr9k-mpls-px-5.1.1/iosxr-mpls-5.1.1
Install operation 10 failed at 03:14:02 UTC Tue Apr 15 2014.
Install logs:
Install operation 10 '(admin) install add
/disk0:asr9k-mpls-px-5.1.1/iosxr-mpls-5.1.1' started by user 'admin' via
CLI at 03:14:02 UTC Tue Apr 15 2014.
Error: '/disk0:/asr9k-mpls-px-5.1.1/iosxr-mpls-5.1.1' could not be
Error: found.
Error: - check the file permissions of the pie.
Error: - check network connectivity of the SDR containing the dSC.
Install operation 11 started by user 'admin' via CLI at 03:17:41 UTC Tue Apr 15
2014.
Install operation 11 failed at 03:17:41 UTC Tue Apr 15 2014.
Install logs:
Install operation 11 '(admin) install add /disk0:asr9k-mpls-px-5.1.1/'
started by user 'admin' via CLI at 03:17:41 UTC Tue Apr 15 2014.
Error: '/disk0:/asr9k-mpls-px-5.1.1/' is a directory.
Install operation 12 started by user 'admin' via CLI at 21:13:31 UTC Tue May 06
2014.
(admin) install activate disk0:asr9k-fpd-px-5.1.1
Install operation 12 completed successfully at 21:14:25 UTC Tue May 06 2014.
Install logs:
Install operation 12 '(admin) install activate disk0:asr9k-fpd-px-5.1.1'
started by user 'admin' via CLI at 21:13:31 UTC Tue May 06 2014.
2014.
Summary:
Sub-operation 1:
Started at: 21:13:53 UTC Tue May 06 2014
Sub-operation 1:
Sub-operation 1:
Output format:
impacted:
process)
Install operation 13 started by user 'admin' via CLI at 21:15:04 UTC Tue May 06
2014.
Install operation 13 completed successfully at 21:15:06 UTC Tue May 06 2014.
Install logs:
Install operation 13 '(admin) install commit' started by user 'admin' via
CLI at 21:15:04 UTC Tue May 06 2014.
2014.
13 entries shown
RP/0/RSP0/CPU0:ios(admin)#$
05-08-2014 03:25 AM
the answer is in here to make a nV edge system out of 2 ASR 9010 routers
https://supportforums.cisco.com/document/145436/asr9k-nv-edge-deployment-guide
