01-10-2023 08:35 PM - edited 01-10-2023 08:37 PM
we're in the process of installing several SMUs on our 9906 chassis running 7.3.2. We've already upgraded several and, the process went without a hitch. Tonight, however after upgrading a note 2 interfaces didn't come back up. Trying to shut down the controller, the interface or, reconfiguring it altogether didn't help.
With the "show controllers internal" CLI the error reported is the following:
H/W Link Defects : (0x0000000000000800) FIA_SHUTDOWN H/W Raw Link Defects : (0x0000000000000800) FIA_SHUTDOWN |
In the PFM alarms, the LC (A9k-48x10GE-1G-SE) raises the following ones:
node: node0_0_CPU0 --------------------- CURRENT TIME: Jan 11 05:32:22 2023 PFM TOTAL: 4 EMERGENCY/ALERT(E/A): 4 CRITICAL(CR): 0 ERROR(ER): 0 ------------------------------------------------------------------------------------------------- Raised Time |S#|Fault Name |Sev|Proc_ID|Dev/Path Name |Handle --------------------+--+------------+---+-------+--------------+---------- Jan 11 03:36:24 2023|2 |RX_LINK_ERR |E/A|4852 |Fabric Arbiter|0x1001001 Jan 11 03:36:24 2023|2 |SYNC_ERR |E/A|4852 |Fabric Arbiter|0x1001001 Jan 11 03:36:24 2023|2 |RX_LINK_ERR |E/A|4852 |Fabric Arbiter|0x1001000 Jan 11 03:36:24 2023|2 |SYNC_ERR |E/A|4852 |Fabric Arbiter|0x1001000 |
Can anyone advise what are the best practices to troubleshoot this further?
Solved! Go to Solution.
01-11-2023 10:19 AM
From the outputs you have shared it seems like the FIA is shutdown. If you check show controller np ports all loc 0/0/cpu0 you should see the ports sharing a fia.
This could be hardware / software / or transient. When an ASIC like a FIA is shutdown there will be corresponding syslogs and logs in show tech fabric. I would need to see those to know what kind of fault it is. You can try to reload the LC to recover if its transient. But again without logs I cannot tell you which of those 3 problem types it is.
Sam
01-11-2023 10:19 AM
Sam
01-11-2023 01:20 PM
Hi @smilstea
after troubleshooting the issue further, we ended up opening SR694880116 where we shared all the evidences we've gathered. Reloading the LC, did fix the issue.
