ASR9K and 7609 l2 loop
mirkolobina
hi all, i am studying an integration in the following scenario:
7609_1 ----- 7609_2
ASR9K        ASR9K
        ASR920
In the specific:
1) in the ASR920 i have configured a l2vpn vpls + bridge-domain (i have several devices attached to access switch ASR920):
l2vpn vfi context management100
 vpn id 100
 autodiscovery bgp signaling bgp
  ve id 1
  rd 1111:100
  route-target export 1111:100
  route-target import 1111:100
  no auto-route-target
bridge-domain 100
 member vfi management100
2) the ASR9K (i paste the config of one ASR, the other is the same):
l2vpn
 bridge group management100
  bridge-domain management100
   interface TenGigE0/0/0/16.100
   vfi management100
    vpn-id 100
    autodiscovery bgp
     rd 1111:100
     signaling-protocol bgp
      ve-id 3
spanning-tree pvrst management100
 vlan 100
where TenGigE is the uplink to 7609_1 or _2. this interface is configured this way:
interface TenGigE0/0/0/16.100 l2transport
 encapsulation dot1q 100
 rewrite ingress tag pop 1 symmetric
3)  the two 7609s are running rapid-pvrst in the cross between them and to the ASRs. the first 7609 is root bridge.
what is happening is a loop. i am a newbie of vpls in asr, so any idea/suggestions/clarifications welcome!!!
br and tnx advance, mirko
xthuijs
hi mirko,
you dont need to run stp in your vpls core between 7600 and a9k.
the stp runs from your edge devices a9k's to the switch 920.
vpls/pw's in teh core between your PE nodes.
if you want to run stp in the core, you can, not recommended, but then dont use PW's but use the EFP/sufinterfaces between a9k and 7600.
also have a look at this one:
https://supportforums.cisco.com/document/11935841/asr9000xr-using-pvstag-cluster-and-satellite-example
and this:
https://supportforums.cisco.com/document/61401/asr9000xr-using-mst-ag-mst-access-gateway-mst-and-vpls
that describe the Acess gateway functionality and the concepts of vpls/pw's and all that.
cheers!
xander
tnx very much for your prompt reply: i am trying a config with psvrtag. i will post findings in the next hours. tnx again mirko
all solved. i have used first approach from the first link.
tnx mirko
hey mirko, thanks for confirming! great to see the option worked!
cheers!
xander
