ASR9k-BNG as proxy DHCP and DHCP serveur in different vrf with ABF between vrf having problem
stany aymon
Problem overview
BNG is configured as DHCP proxy and a lot of DHCP discover and DHCP offer are exchanged between the DHCP server and the proxy before the client is able to have set the correct IP. This could take a variable time from few minutes to 20 minutes.
I have the feeling that the BNG behaviour or routing is the problem.
Environment:
-two ASR 9001 in cluster with version 4.3.2
-default global vrf for public IP addresses with access to internet with the bundle interface BE1.1103 as interface for the IPoE clients
-interface BE1.1099 in vrf <Ftth> where the different servers are located in to provide radius and dhcp services
-BNG is used to provide HighSpeedInternet (HSI) IP addresses to the clients (interface router on a fiber-modem)
-ABF on both interfaces BE1.1103 and BE1.1099 to permit to route some IPs between the global and the Ftth vrf
-radius server in the BE1.1099 that allow the client to receive an IP through the DHCP proxy on the BNG
Configuration on BNG:
dhcp ipv4
profile DHCP_B1103_PF proxy
  lease proxy client-lease-time 600
  helper-address vrf Ftth a.a.a.21 giaddr x.x.x.1
  relay information option
  relay information policy keep
  relay information option allow-untrusted
interface Bundle-Ether1.1103 proxy profile DHCP_B1103_PF
duplicate-mac-allowed
interface Bundle-Ether1.1099
description Serveur interface
vrf Ftth
ipv4 address a.a.a.1 255.255.255.0
encapsulation dot1q 1099
ipv4 access-group Abf1 ingress hardware-count
ipv4 access-list Abf1
50 permit ipv4 any x.x.x.0/24 nexthop1
51 permit icmp any x.x.x.0 0.0.0.255 nexthop1
60 permit ipv4 any any
description HSI Clients
ipv4 point-to-point
ipv4 unnumbered Loopback1
arp learning disable
service-policy type control subscriber IPOE_POLICY
encapsulation dot1q 1103
ipsubscriber ipv4 l2-connected
  initiator dhcp
ipv4 access-group Abf2 ingress hardware-count
ipv4 access-list Abf2
10 permit ipv4 x.x.x.0/24 a.a.a.0/24 nexthop1 vrf Ftth
30 permit icmp x.x.x.0/24 a.a.a.0/24 nexthop1 vrf Ftth
Problem description:
-the radius is working perfectly and allow the different clients to receive an IP from the DHCP
-from the DHCP server I can ping an IP subscriber so the routing between ABF seams to work
-the fiber modem is also receiving an IP address but it take a lot of offer and sometimes a long time before the ack is coming. Like here the dhcp.log
Nov 11 17:26:41 NcSrvFtth02 dhcpd: DHCPDISCOVER from 00:0f:5d:ad:7a:70 via x.x.x.1
Nov 11 17:26:42 NcSrvFtth02 dhcpd: DHCPOFFER on x.x.x.250 to 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:44 NcSrvFtth02 dhcpd: DHCPDISCOVER from 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:44 NcSrvFtth02 dhcpd: DHCPOFFER on x.x.x.250 to 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:47 NcSrvFtth02 dhcpd: DHCPDISCOVER from 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:47 NcSrvFtth02 dhcpd: DHCPOFFER on x.x.x.250 to 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:50 NcSrvFtth02 dhcpd: DHCPDISCOVER from 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:50 NcSrvFtth02 dhcpd: DHCPOFFER on x.x.x.250 to 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:53 NcSrvFtth02 dhcpd: DHCPDISCOVER from 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:53 NcSrvFtth02 dhcpd: DHCPOFFER on x.x.x.250 to 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:56 NcSrvFtth02 dhcpd: DHCPDISCOVER from 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:56 NcSrvFtth02 dhcpd: DHCPOFFER on x.x.x.250 to 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:59 NcSrvFtth02 dhcpd: DHCPDISCOVER from 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:59 NcSrvFtth02 dhcpd: DHCPOFFER on x.x.x.250 to 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:59 NcSrvFtth02 dhcpd: DHCPREQUEST for x.x.x.250 (10.126.0.3) from 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:26:59 NcSrvFtth02 dhcpd: DHCPACK on x.x.x.250 to 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:27:02 NcSrvFtth02 dhcpd: DHCPREQUEST for x.x.x.250 (10.126.0.3) from 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:27:02 NcSrvFtth02 dhcpd: DHCPACK on x.x.x.250 to 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:27:05 NcSrvFtth02 dhcpd: DHCPREQUEST for x.x.x.250 (10.126.0.3) from 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
Nov 11 17:27:05 NcSrvFtth02 dhcpd: DHCPACK on x.x.x.250 to 00:0f:5d:ad:7a:70 (drgos) via x.x.x.1
I took a tcpdump on the dhcpserver and I have the following error 3 times before the ack is coming:
source x.x.x.1 (interface BNG BE1.1103) destination a.a.a.3 (dhcp server) dhcp discover
source a.a.a.3(dhcp server) destination x.x.x.1 dhcp offer
source a.a.a.1(interface BNG BE1.1099) destination a.a.a.3 icmp destination unreachable (port unreachable)
I really have the feeling that it's a BNG routing problem with the ASR and BNG
Could you help me with this issue?
0 Replies 0
