ASR9K - Number of policy-map limit and how to check current stats?
Won Lee
I need to add COS policy-map profiles for ethernet service on top of existing ones. we have quite a lot already and would like to know the maximum number the ASR supports, as well as the command to check the current number of policy-maps in the node. Any Cisco doc/link?
the platform spec : ASR9010, A9K-RSP-8G, XR 4.2.3
Thanks in advance.
intopian
Cisco networker
narvenka
Hi Intopian,
The maximum number of policy-map supported is 2000 and show policy-map list should show the current number of policies in the node.
This is documented in CCO.
Venkat
From CCO, found two different conflicting information though for same release 3.7.2. confusing..
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.2/qos/command/reference/b_qos_cr42asr9k_chapter_011.html#wp966352593
"The maximum number of policy maps supported is 2000."
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.0/qos/command/reference/qr40asr9k_chapter1.html#wp915159151
"The maximum number of policy maps supported is 1000."
Thanks for your reply!
Actually both are 2 different releases. 42x supports 2000.
Venkat
