ASR9k BNG Radius issue
Yury Kamiakou
Hi folks.
I'm deploying BNG at ASR9k with IOS XR 4.3.1 and have some problems with RADIUS exchange. My current config is:
radius source-interface Loopback220 vrf default
radius-server host x.y.z.198 auth-port 1812 acct-port 1813
key test
aaa attribute format USERNAME
format-string length 253 "%s" outer-vlan-id
aaa attribute format NAS_PORT_FORMAT
circuit-id plus remote-id separator .
aaa radius attribute nas-port format e SSSSAAPPPPPVVVVVVVVVVVVVVVVVVVVV
aaa radius attribute nas-port-id format NAS_PORT_FORMAT
aaa group server radius BNG
server x.y.z.198 auth-port 1812 acct-port 1813
aaa accounting subscriber default group BNG
aaa authorization subscriber default group BNG
aaa authentication subscriber default group BNG
aaa authentication ppp default group BNG
dhcp ipv4
vrf INTERNET proxy profile IPV4_GROUP
profile IPV4_GROUP proxy
  class INTERNET
   match vrf INTERNET
   helper-address vrf INTERNET x1.y1.z1.77 giaddr x2.y2.z2.129
  limit lease per-remote-id 150
  relay information option vpn
  relay information policy keep
  relay information option allow-untrusted
interface TenGigE0/1/0/0.1 proxy profile IPV4_GROUP
Radius server is reachable from BNG with loopback220 source IP address.
ipv4 point-to-point
ipv4 unnumbered Loopback200
service-policy type control subscriber IP_POLICY_BASIC
encapsulation dot1q 145 second-dot1q 1960
ipsubscriber ipv4 l2-connected
  initiator dhcp
dynamic-template
type ipsubscriber IP_BASIC
class-map type control subscriber match-any DHCP
match protocol dhcpv4
end-class-map
policy-map type control subscriber IP_POLICY_BASIC
event session-start match-first
  class type control subscriber DHCP do-until-failure
   10 activate dynamic-template IP_BASIC
   20 authorize aaa list default format USERNAME password test
end-policy-map
Radius debug info:
LC/0/1/CPU0:Aug  1 00:19:41.493 FET: radiusd[322]: ENTERING 'handle_nas_req'
LC/0/1/CPU0:Aug  1 00:19:41.493 FET: radiusd[322]: ENTERING 'radiusd_get_nas_identifier'
LC/0/1/CPU0:Aug  1 00:19:41.493 FET: radiusd[322]: ENTERING 'build_radius_pkt'
LC/0/1/CPU0:Aug  1 00:19:41.493 FET: radiusd[322]: EXITTING 'radiusd_get_nas_identifier'
LC/0/1/CPU0:Aug  1 00:19:41.493 FET: radiusd[322]: ENTERING 'build_radius_pkt_from_list'
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: ENTERING 'radiusd_get_prepend_nas_id_to_session_id'
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: EXITTING 'radiusd_get_prepend_nas_id_to_session_id'
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: EXITTING 'build_radius_pkt_from_list'
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: EXITTING 'build_radius_pkt'
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: ENTERING 'radius_send_request_message'
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: ENTERING 'radius_get_next_server'
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: Server x.y.z.198/1812/1813 is UP  & Quarantined: NO
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: radius_get_next_server: Setting the preferred server handle to NULL
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: Sending request to x.y.z.198:1812, with retry_limit: 3 and delay: 5
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: EXITTING 'radius_get_next_server'
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: ENTERING 'radius_set_ident_sock'
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: EXITTING 'radius_set_ident_sock'
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: ENTERING 'radius_ctx_db_insert_rctx'
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: EXITTING (value 1) 'radius_ctx_db_insert_rctx'
LC/0/1/CPU0:Aug  1 00:19:41.494 FET: radiusd[322]: Sending request with id : 14/1347259508
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: ENTERING 'send_radius_packet'
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: ENTERING 'radius_add_mand_attrs'
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: EXITTING 'radius_add_mand_attrs'
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: ENTERING 'radius_get_nas_ip_address'
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: Calling best local address using daemon address=x.y.z.198
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: ENTERING 'get_ip_addr_from_fib'
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: Address x.y.z.198 does not have a source address
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: Got IP address: 0.0.0.0
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: IP source address aaa util format: 0.0.0.0
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: EXITTING 'get_ip_addr_from_fib'
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: NAS best local address = 0.0.0.0
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: EXITTING 'radius_get_nas_ip_address'
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: Reencoding NAS-IP prev 0.0.0.0 new 0.0.0.0
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: ENTERING 'radius_get_next_server'
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: Server x.y.z.198/1812/1813 is UP  & Quarantined: NO
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: Failed aaa_sg_server_get_next_server with error 'qos-ea' detected the 'fatal' condition 'set exp imposition in egress is not permitted' rc = AFDF1600
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: EXITTING 'radius_get_next_server' with error [A247C800] 'Subsystem(1167)' detected the 'fatal' condition 'Code(36)'
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: NAS-IP-Address not found, Moving to next server in the server group
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: Nas-IP-Address not found, dropping request
LC/0/1/CPU0:Aug  1 00:19:41.495 FET: radiusd[322]: Failed to send the request
Any workaround or recommendation to solve the issue?
narvenka
Looks like the request itself not getting out of the box because of unreachablity or the
source-interface Loopback220 not exist. Can you check on that ?
a have same problem on 5.1.1 software
aaa accounting system default start-stop group BNG
server-private XX.XXX.XXX.8 auth-port 1812 acct-port 1813
  key 7 000500140D551F031D324D5A490D000406
source-interface Loopback1
aaa authentication login default local
dynamic-template
type ppp PPP_TPL
  ppp authentication chap
  ppp ipcp dns 8.8.8.8
interface Loopback1
ipv4 address 10.254.254.254 255.255.255.255
interface Loopback2
ipv4 address 10.254.254.253 255.255.255.255
interface MgmtEth0/RSP0/CPU0/0
ipv4 address 10.252.0.90 255.255.255.0
interface MgmtEth0/RSP0/CPU0/1
shutdown
interface TenGigE0/0/2/1.556
ipv4 address 10.56.0.1 255.255.255.0
service-policy type control subscriber PPP_PM
pppoe enable bba-group pppoe
encapsulation dot1q 556
aaa radius attribute nas-port format e SSAAPPPPQQQQQQQQQQVVVVVVVVVVUUUU type 32
pppoe bba-group pppoe
service selection disable
class-map type control subscriber match-any PPP
match protocol ppp
end-class-map
policy-map type control subscriber PPP_PM
  class type control subscriber PPP do-until-failure
   1 activate dynamic-template PPP_TPL
event session-activate match-first
   1 authenticate aaa list default
end-policy-map
Radius -server sends Access-Accept  but on its router it isn't visible
LC/0/0/CPU0:Mar  6 15:48:32.499 : radiusd[327]:  RADIUS: Send Access-Request to XX.XXX.XXX.8:1812 id 169, len 220
LC/0/0/CPU0:Mar  6 15:48:32.499 : radiusd[327]:  RADIUS:  authenticator D3 8C BA E1 87 32 81 3C - E7 47 78 79 20 C1 AC 57
LC/0/0/CPU0:Mar  6 15:48:32.499 : radiusd[327]:  RADIUS:  Vendor,Cisco        [26]    41
LC/0/0/CPU0:Mar  6 15:48:32.499 : radiusd[327]:  RADIUS:   Cisco AVpair        [1]    35      client-mac-address=000e.0c75.b6d9
LC/0/0/CPU0:Mar  6 15:48:32.499 : radiusd[327]:  RADIUS:  Acct-Session-Id     [44]    10      0400003b
LC/0/0/CPU0:Mar  6 15:48:32.499 : radiusd[327]:  RADIUS:  NAS-Port            [5]     6       2701140681
LC/0/0/CPU0:Mar  6 15:48:32.499 : radiusd[327]:  RADIUS:  NAS-Port-Id         [87]    3       .
LC/0/0/CPU0:Mar  6 15:48:32.499 : radiusd[327]:  RADIUS:  Vendor,Cisco        [26]    9
LC/0/0/CPU0:Mar  6 15:48:32.499 : radiusd[327]:  RADIUS:   cisco-nas-port      [2]    3       .
LC/0/0/CPU0:Mar  6 15:48:32.499 : radiusd[327]:  RADIUS:  User-Name           [1]     11      user1
LC/0/0/CPU0:Mar  6 15:48:32.499 : radiusd[327]:  RADIUS:  Service-Type        [6]     6       Framed[0]
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]:  RADIUS:  CHAP-Password       [3]     19      *
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]:  RADIUS:  CHAP-Challenge      [60]    18      r^K d ^BZ-^E^B^_^S^Xd^U)
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]: Unsuppoted attribute.
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]:  RADIUS:  Vendor,Cisco        [26]    33
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]:  RADIUS:   Cisco AVpair        [1]    27      connect-progress=LCP Open
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]:  RADIUS:  Framed-Protocol     [7]     6       PPP[0]
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]:  RADIUS:  NAS-Port-Type       [61]    6       PPPoEoVLAN[0]
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]:  RADIUS:  Event-Timestamp     [55]    6       1394102897
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]:  RADIUS:  Nas-Identifier      [32]    14      asr9k_pppoe
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]:  RADIUS:  NAS-IP-Address      [4]     6       XX.XXX.XXX.9
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]: Updating last used server
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]: EXITTING 'send_radius_packet'
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]: Got global deadtime 0
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]: Using global deadtime = 0 sec
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]: ENTERING 'start_dead_detect_timer'
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]: EXITTING 'start_dead_detect_timer'
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]: ENTERING 'radius_timer_update'
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]: EXITTING 'radius_timer_update'
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]: Updated timer thread rad_ident 169 remote_port 1812 remote_addr 0x30fb908c, socket 1342480676 rctx 0x5015b530
LC/0/0/CPU0:Mar  6 15:48:32.500 : radiusd[327]: ENTERING 'radius_timer_set_addl_context'
LC/0/0/CPU0:Mar  6 15:48:32.501 : radiusd[327]: EXITTING 'radius_timer_set_addl_context'
LC/0/0/CPU0:Mar  6 15:48:32.501 : radiusd[327]: ENTERING 'radius_timer_set_addl_context'
LC/0/0/CPU0:Mar  6 15:48:32.501 : radiusd[327]: Successfully sent packet and started timeout handler for rctx 0x5015b530
LC/0/0/CPU0:Mar  6 15:48:32.501 : radiusd[327]: EXITTING 'radius_send_request_message'
LC/0/0/CPU0:Mar  6 15:48:32.501 : radiusd[327]: EXITTING 'radius_timeout_handler'
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: ENTERING 'radius_timeout_handler'
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: ENTERING 'radius_timer_get_addl_context'
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: Timeout happened for req rad_ident 169 remote_port 1812 remote_addr 0x50 socket 1342480676 rctx 5015b530
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: ENTERING 'radius_ctx_db_get_and_remove_rctx'
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: rctx found is 0x5015b530
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: EXITTING 'radius_ctx_db_get_and_remove_rctx'
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: ENTERING 'radius_send_request_message'
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: Reached retry count for the server 3,Trying to move to next server
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: ENTERING 'radius_get_next_server'
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: Server XX.XXX.XXX28/1812/1813 is UP  & Quarantined: NO
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: EXITTING 'radius_get_next_server' with error [A247C800] 'Subsystem(1167)' detected the 'fatal' condition 'Code(36)'
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: EXITTING 'radius_send_request_message' with error [A247C800] 'Subsystem(1167)' detected the 'fatal' condition 'Code(36)'
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: ENTERING 'rad_nas_reply_to_client'
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: rad_nas_reply_to_client: Received response from id : 169,packet type 1
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: rad_nas_reply_to_client: Sending failover message to client
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: EXITTING 'rad_nas_reply_to_client'
LC/0/0/CPU0:Mar  6 15:48:37.508 : radiusd[327]: EXITTING 'radius_timeout_handler'
I tried with group of radius and without it and different source-interface interfaces doesn't help
There are thoughts where to look?
Try to create a bundle and bind service-policy to bundle subinterface, not to physical subinterface.
Creation sessions from physical interface is possible from 5.1.1 and may be some features don't works.
On bundle interfaces all works fine.
