asr9k lacp/bundle with nexus 3k and vpc
hello,
i have a problem in establish a lacp bundle from asr9k to 2x nexus 3k in vpc.
when i try to esatblish the channel without vpc everithing work correctly when i enable for example vpc 3 on port-channel on nexus the link go down and nexus say that there is a vpc mismatch.
i read that on ver 7 there is layer3 peer command in vpc domain submenu, it will solve my problem or not?
please advice.
BR
i was able to solve this problem also, the stp cannot carry the vlans because of the port type network, after changing this the lacp works correctly. now i must upgrade the nx-os to 7.x to let the routing protocols works on vpc from nexus to asr.
thanks a lot for help.
balaji.bandi
check the  VLAN Allowed in the vPC Peer link.
if still issue post both the side configuration. and error logs here.
BB
hello,
thanks for reply, i was able to establish the lag with vpc, i miss the configuration on other node, my fault, but testing the conf with only one link active i was not able to forward the test vlan. to be clear here the snippet of nexus and asr:
asr:
interface Bundle-Ether3
 lacp system mac fa16.3efd.75ee
 mac-address fa16.3efd.75ee
 bundle load-balancing hash dst-ip
 bundle maximum-active links 1 hot-standby
 bundle minimum-active links 1
interface Bundle-Ether3.807
 ipv4 address 2.2.2.2 255.255.255.252
 encapsulation dot1q 807
interface TenGigE0/1/0/2
 bundle id 3 mode active
nexus:
interface port-channel3
  speed 10000
  switchport mode trunk
  spanning-tree port type network
  vpc 3
interface port-channel10
  no negotiate auto
  vpc peer-link
vpc domain 1
  role priority 2000
  system-priority 4000
  peer-keepalive destination 1.1.1.1 source 1.1.1.2
  auto-recovery
when i show the status of trunk on nexus on one side here is the output:
Po2           1       trunking      --
Po3           1       trunking      --
Po10          1       trunking      --
Port          STP Forwarding
Po2           1,101,112,114,116,131-132,150,157,160,187-188,200-202,501-506,508,701,801,803-807,900,999-1000
Po3           none
Po10          1,101,112,114,116,131-132,150,157,160,187-188,200-202,501-506,508,701,801,803-807,900,999-1000
as you can see the po3(the channel with asr) no vlan in forwarding
now the other nexus:
Po2           1       trunking      --
Po3           1       not-trunking  --
Po10          1       trunking      --
Port          STP Forwarding
Po3           none
the two nexus are configured the same, but on the second nexus the link is down. what i want to understand is: when a link go down the channel stop to work as expected? or i miss something?
thanks a lot for your advices.
BR
Could you describe more detail on this ? maybe the config of port type network. in which side you set it ?
Thank you in advance
