ASR9K MAC filter
Mapxaa
Hi All,
How to check whether L2VPN is forwarding MAC and L2 traffic on ASR9K.
My topology : BRAS <-> ASR9K <-> OLTs
In my case, ASR9K has learnt a mac from OLT but BRAS couldn't receive any traffic and MAC from ASR9K.
l2vpn bridge group 3400 bridge-domain 3400
mac
  limit
    maximum 128000
interface Bundle-Ether7.3401   <--OLT interface
split-horizon group
interface Bundle-Ether201.3400    <-- BRAS interface
I need to confirm whether ASR9K forward MAC or not?
Thanks.
BR
nkarpysh
As far as i have understood. Packets coming to ASR9k on BE7.3401 and should be sent as Unknown unicast to BE201.3400.
You can try putting egress ethernet-services ACL on egress interface filtering for your MAC in question to see if that is leaving the router:
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-3/lxvpn/configuration/guide/lesc43xbook/lesc43esal.html
Also command
show l2vpn forwarding bridge-domain 3400:3400 hardware ingress detail loc <>
should show you the rate of traffic on each corresponding AC interface to see if l2vpn packets are exchanged correctly within BD.
Niko
HTH,
Niko
Mapxaa
