ASR9k: SMART_LIC-7-DAILY_JOB_TIMER_RESET:Daily job timer reset
Yuliya S
Hi guys.
Do you know what is mean this log message for ASR9010 Router:
licmgr[312]: SMART_LIC-7-DAILY_JOB_TIMER_RESET:Daily job timer reset
smilstea
This message is related to the smart license feature which was introduced in 5.2. As you can see, this is a "level 7" bug which means it is purely cosmetic and does not indicate any problems with the router.
See:
http://www.cisco.com/c/en/us/products/abt_sw.html
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r5-2/system_management
/command/reference/b-sysman-cr52xasr/b-sysman-cr52xasr_chapter_010000.html#wp3971794868
Sam
Is it a KI? What is the bug number?
We have many ASR9922 in the network and just two have this alarm, curious to understand why.
Thank you!
Hello Sam,
Do we have any bug number for this issue? My client have ASR9010, and this logs are reuccuring.
Please advise. Thank you very much. We cannot pursue the deployment because if this logs.
uastac2011
Hello Yuliya, do you already resolve this issue? What did you do? Please advise. Thank you. We are also facing the same issue.
