at CRS-1,how can i use show command with pipe | ?
jiang-hui
HI,ALL
when I use show command with pipe on the CRS-1,the command invalid
RP/0/RP0/CPU0:JA-DL-CR-1.MAN.CRS-1#show interfaces | include line |errors
% Invalid input detected at '^' marker.
But Previously on the cisco 7609,I can use the show command
GZ-DM-SR-1.MAN.7609#show int | include line |err
Vlan1 is down, line protocol is down
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 interface resets
Vlan11 is administratively down, line protocol is down
Vlan99 is down, line protocol is down
eduardopozo56
This is how multipipe works on IOS-XR:
(extract from: http://www.cisco.com/c/en/us/td/docs/routers/crs/software/crs_r4-1/getting_started/configuration/guide/gs41crs/gs41cli.html#wp1289885)
Multipipe Support
The multipipe feature supports the multiple pipes on the CLI. With this feature, the output can be processed by an enhanced utility set. Using various combination of utilities, it is possible to gather, filter, and format the output of any show command. An arbitrary limit of eight pipes is supported on CLI with this limit superseded by the limit of characters that can be typed on the single line (1024) if the individual commands specified with pipes are long enough.
In addition, if you want to give pipe character (|) as a pattern, you must give it in double quotes. For example:
RP/0/RP1/CPU0:single8-hfr# show running-config|include "bgp|ospf"|file disk0:/usr/a.log
Refer to this document for more detailed help:
https://www.cisco.com/c/en/us/td/docs/routers/crs/software/crs_r4-1/getting_started/configuration/guide/gs41crs/gs41cli.pdf
jiang-hui
RP/0/RP0/CPU0:JA-DL-CR-1.MAN.CRS-1#show interfaces | include line |?
RP/0/RP0/CPU0:JA-DL-CR-1.MAN.CRS-1#show interfaces | include line | |?
RP/0/RP0/CPU0:JA-DL-CR-1.MAN.CRS-1#show interfaces | include line | ?
  begin    Begin with the line that matches
  exclude  Exclude lines that match
  file     Save the configuration
  include  Include lines that match
  utility  A set of common unix utilities
  <cr>
% Incomplete command.
  <cr>
RP/0/RP0/CPU0:JA-DL-CR-1.MAN.CRS-1#show interfaces | include line | include er$
Thu Jan 15 22:36:24.120 GMT
Thu Jan 15 22:37:05.013 GMT
Loopback0 is up, line protocol is up
Loopback1 is up, line protocol is up
Loopback6 is up, line protocol is up
Null0 is up, line protocol is up
POS0/0/0/0 is up, line protocol is up  (APS not Configured )
POS0/0/1/0 is up, line protocol is up  (APS not Configured )
TenGigE0/0/4/0 is up, line protocol is up
eduardopozo56
Multipipe Support
thanks very mutch,I got it!!!
RP/0/RP0/CPU0:JA-DL-CR-1.MAN.CRS-1#show interfaces | include "line|err"
Thu Jan 15 23:02:41.682 GMT
     476875542 input errors, 4128386 CRC, 14396 frame, 0 overrun, 0 ignored, 0 abort
     0 output errors, 0 underruns, 0 applique, 0 resets
     84286 input errors, 22518 CRC, 44 frame, 0 overrun, 0 ignored, 0 abort
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
