BGP flaps between IOS and XR
I see there are random BGP session flaps that occur between an IOS running and XR running router. It is a VPNv4 session and both routers have different uplinking MTU and are connected through IGP.
some errors that were logged in during the flap are
BGP-5-ADJCHANGE
BGP_SESSION-5-ADJCHANGE
BGP-3-NOTIFICATION
Has anyone experienced similar issues on their network and have any solution to this?
Hi Ramya,
That is bit challenging to look at the information as it comes in parts with a bit un-matching time and some substituted details.
From the output we can see:
  Last reset 02:06:08, due to Peer closing down the session
  Peer reset reason: Remote closed the session (Connection timed out)
So it was 2 hours 6 min back and should be around 16:22, but we have no logs for this in the provided details. The session was closed by the peer “Foreign host: x.x.x.x,”
6 hours 6 min ago we sent notification too
  Time since last notification sent to neighbor: 06:06:22
  Error Code: hold time expired
Matching log:
RP/0/5/CPU0::Dec 12 12:21:54.039 IST: bgp[139]: %ROUTING-BGP-5-ADJCHANGE : neighbor x.x.x.xDown - BGP Notification sent, hold time expired (VRF: default)
So the last session went down due to missed bgp keepalives. The keepalive hold timer is 180 sec (3min). what took my attention is that before the session reset we start getting Invalid MD5 just 3 min before the reset.  So the XR didn’t like MD5 digest coming from IOS but after a flap the session was restored.
There is one bug on IOS “CSCsx33622   Fix MSS calcuation issue in TCP” making IOS sending segments with incorrect MD5 at some conditions. You may want to look into it.
/A
10 Replies 10
Alexei Kiritchenko
Hi Ramya,
There could be many different reasons for the session to close.
Complete ‘show log’ output and ‘show bgp vpnv4 unicast neighbors x.x.x.x detail’ may help you to get details on why the session was terminated.
/A
Some logs during the flap are
001359: Dec 12 12:18:43.229 IST: %BGP-5-ADJCHANGE: neighbor x.x.x.x Down BGP protocol initialization
001360: Dec 12 12:18:43.229 IST: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x VPNv4 Unicast topology base removed from session  BGP protocol initialization
001361: Dec 12 12:18:43.229 IST: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x IPv4 MDT topology base removed from session  BGP protocol initialization
001362: Dec 12 12:18:43.733 IST: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x VPNv4 Unicast topology base removed from session  Unknown path error
001363: Dec 12 12:18:43.733 IST: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x IPv4 MDT topology base removed from session  Unknown path error
001364: Dec 12 12:18:43.733 IST: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x IPv4 Unicast topology base removed from session  Unknown path error
001365: Dec 12 12:18:51.981 IST: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x IPv4 Unicast topology base removed from session  Capability changed
001366: Dec 12 12:18:51.981 IST: %BGP-5-ADJCHANGE: neighbor x.x.x.x Up
001367: Dec 12 12:21:54.183 IST: %BGP-3-NOTIFICATION: received from neighbor x.x.x.x 4/0 (hold time expired) 0 bytes
001368: Dec 12 12:21:54.183 IST: %BGP-5-ADJCHANGE: neighbor x.x.x.x Down BGP protocol initialization
001369: Dec 12 12:21:54.347 IST: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x VPNv4 Unicast topology base removed from session  Peer closed the session
001370: Dec 12 12:21:54.347 IST: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x IPv4 MDT topology base removed from session  Peer closed the session
001371: Dec 12 12:21:55.363 IST: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x VPNv4 Unicast topology base removed from session  Unknown path error
001372: Dec 12 12:21:55.363 IST: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x IPv4 MDT topology base removed from session  Unknown path error
001373: Dec 12 12:21:55.363 IST: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x IPv4 Unicast topology base removed from session  Unknown path error
001374: Dec 12 12:22:07.415 IST: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x IPv4 Unicast topology base removed from session  Capability changed
001375: Dec 12 12:22:07.415 IST: %BGP-5-ADJCHANGE: neighbor x.x.x.x Up
may you get as well  ‘show log’ output and ‘show bgp vpnv4 unicast neighbors x.x.x.x detail’ from the XR side?
/A
RP/0/5/CPU0::Dec 12 12:15:43.496 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:15:59.965 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:16:18.789 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:16:37.619 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:16:56.410 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:17:15.227 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:17:34.054 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:17:52.879 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:18:11.683 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:18:30.499 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:18:42.915 IST: bgp[139]: %ROUTING-BGP-5-ADJCHANGE : neighbor x.x.x.xDown - BGP Notification sent, hold time expired (VRF: default)
RP/0/5/CPU0::Dec 12 12:18:49.364 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:18:52.272 IST: bgp[139]: %ROUTING-BGP-5-ADJCHANGE : neighbor x.x.x.xUp (VRF: default)
RP/0/5/CPU0::Dec 12 12:19:01.433 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x38341 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:19:21.680 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x38341 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:19:45.766 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:20:04.584 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:20:23.402 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:20:42.215 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:21:01.029 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:21:19.863 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:21:36.635 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x38341 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:21:57.519 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:22:07.728 IST: bgp[139]: %ROUTING-BGP-5-ADJCHANGE : neighbor x.x.x.xUp (VRF: default)
RP/0/5/CPU0::Dec 12 12:22:16.309 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x37416 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:22:30.616 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x38341 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:23:24.615 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x38341 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:24:18.581 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x38341 to 192.168.207.229:179
RP/0/5/CPU0::Dec 12 12:25:12.566 IST: tcp[443]: %IP-TCP-3-BADAUTH : Invalid MD5 digest from x.x.x.x38341 to 192.168.207.229:179
RP/0/5/CPU0:hostname#   sh bgp vpnv4 unicast neighbors x.x.x.x detai$
Mon Dec 12 18:28:16.091 IST
BGP neighbor is x.x.x.x
Remote AS aaaa, local AS aaaa, internal link
Description:
Remote router ID x.x.x.x
Cluster ID zz.zz.zz.zz
  BGP state = Established, up for 02:05:52
  Last read 00:00:18, Last read before reset 02:06:47
  Hold time is 180, keepalive interval is 60 seconds
  Configured hold time: 180, keepalive: 60, min acceptable hold time: 3
  Last write 00:00:00, attempted 110, written 110
  Second last write 00:00:00, attempted 110, written 110
  Last write before reset 02:06:08, attempted 124, written 124
  Second last write before reset 02:06:08, attempted 187, written 187
  Last write pulse rcvd  Dec 12 18:28:16.034 last full Dec 12 16:25:34.364 pulse count 13423732
  Last write pulse rcvd before reset 02:06:08
  Socket not armed for io, armed for read, armed for write
  Last write thread event before reset 02:06:08, second last 02:06:08
  Last KA expiry before reset 00:00:00, second last 00:00:00
  Last KA error before reset 00:00:00, KA not sent 00:00:00
  Last KA start before reset 02:06:08, second last 02:06:08
  Precedence: internet
  Neighbor capabilities:            Adv         Rcvd
    Route refresh:                  Yes         Yes
    4-byte AS:                      Yes         No
    Address family VPNv4 Unicast:   Yes         Yes
    Address family IPv4 MDT:        Yes         Yes
  Message stats:
    InQ depth: 0, OutQ depth: 0
                    Last_Sent               Sent  Last_Rcvd               Rcvd
    Open:           Dec 12 16:22:23.625       66  Dec 12 16:22:23.624       66
    Notification:   Dec 12 12:21:54.648       58  ---                        0
    Update:         Dec 12 18:28:16.369 56505846  Dec 12 18:14:26.334   653688
    Keepalive:      Dec 12 16:22:29.953      192  Dec 12 18:27:57.836    46465
    Route_Refresh:  ---                        0  Dec  8 11:57:08.021       22
    Total:                              56506162                        700241
  Minimum time between advertisement runs is 0 secs
For Address Family: VPNv4 Unicast
  BGP neighbor version 129938542
  Update group: 0.1
  Route-Reflector Client
  Route refresh request: received 22, sent 0
  2871 accepted prefixes, 2871 are bestpaths
  Cumulative no. of prefixes denied: 0.
  Prefix advertised 376981, suppressed 0, withdrawn 39560
  Maximum prefixes allowed 524288
  Threshold for warning message 75%, restart interval 0 min
  An EoR was received during read-only mode
  Last ack version 129938526, Last synced ack version 0
  Outstanding version objects: current 463, max 476
For Address Family: IPv4 MDT
  BGP neighbor version 10353
  Update group: 0.1
  Route refresh request: received 0, sent 0
  0 accepted prefixes, 0 are bestpaths
  Prefix advertised 811, suppressed 0, withdrawn 0
  Maximum prefixes allowed 131072
  Last ack version 10353, Last synced ack version 0
  Outstanding version objects: current 0, max 6
  Connections established 66; dropped 65
  Local host: zz.zz.zz.zz, Local port: 179
  Foreign host: x.x.x.x, Foreign port: 25768
  Notification data sent:
    None
Hi Ramya,
It seems you configured MD5 protection for the TCP session but the pwd is not the same on both peers. Please remove it first on both side to check the seesion comes UP correctly and is stable. Then add the pwd on both side back and be careful with the syntax. Be sure there is no space left at the end for example.
Laurent.
Laurent
I dont think it is MD5 issue becos this is set among my other routers with the same XR router and the sessions dont flap or show MD5 bad.
Hi Ramya,
Matching log:
/A
akiritch
that was bang on the bug......all the symptoms and workaround worked exactly the same way on my routers. Thankyou so much.
Hi Ramya,
a few things to look at:
the pattern for these flaps seems to be every 3 minute, i.e. hold-down interval:
so I belive indeed the MD5 hash is correct.
What does it tell us on the other side of this peering? I would need to have a look at the same outputs requested by Alex but from the other side.
Also you mentioned in the very beginning that the MTU size is different. I recommend to either equalize it on both sides, or to set the TCP mss size to a common value, which could make it through the MTU.
HTH,
Ivan.
vinit shah
Dear All,
Can anyone assist to resolve the below issue.........
Oct 26 07:55:49: %BGP-5-ADJCHANGE: neighbor x.x.x.x Down BFD adjacency down
Oct 26 07:55:49: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.xIPv4 Unicast topology base removed from session  BFD adjacency down
Oct 26 07:55:49: %BGP_SESSION-5-ADJCHANGE: neighbor x.x.x.x IPv4 Unicast topology base removed from session  BFD adjacency down
Oct 26 07:55:49: %BGP-5-ADJCHANGE: neighbor x.x.x.xDown BFD adjacency down
What needs to be done to resolve the above issue........
