BGP RR
Ratheesh mv
Hi friends ,
What is the necessity of retain route-target all command on BGP RR? (IOS XR)
When I tried with and without this did not notice any difference in sh bgp vpn4 unicast table .
Thanks in advance.
tkarnani
Hi Ratheesh,
when a bgp speaker in vpnv4 receives a route it will only keep those that it has a route-target locally imported for.
if it doesn't it will drop
"retain route-target all " forces the router to keep all routes received in the table regardless of having a route-target import configured locally
thanks
randreetta
I believe you dont' need to configure it in a route-reflector, it's already enabled by default. You probably would need to configure it on a PE, for example in case you configure an eBgp vpnv4 session
