BGP VRF Route issue
feroz syed
Level 3
Level 3
Hello
Both CE received routers each other, but routes not reachable, they can access the next hop(PE) but in core routers somewhere the traffic getting blocked. Attached configs and topology
Harold Ritter
Hi @feroz syed ,
You need to enable LDP between the two PEs.
I know little about XR but I dont see MPLS config between both PE??
Thanks both of you for your help...Very hard to work with Xr routers, sometimes the cmd not accept sometime it work.. it like usb connect to pc, you have give try twice third time it get work.
Yes, I was use Laptop with i5 and ram 8 gb and it nightmare,
now I order new PC with ryzen 9 5900x and 32 gb to run more advance lab include CSR1000v.
Harold Ritter
Hi @feroz syed ,
