Conditional advertisement in eBGP based on ISIS status
allalamine
Hello networkers,
In MPLS L3VPN, can we advertise a route to eBGP neighbor only if there is at least one ISIS neighbor up ? (ISIS is the IGP and running in GRT). PE is an ASR 9010.
The neighbor is dual-homed and the advertised route from PE to neighbor is a default generated using default-generate.
Thank you
Thank you
To use this, I need to create as many IP SLA objects as ISIS neighbors. each IP SLA will ping a neighbor.
Gonna be hard to maintain as we should update config whenever we add/remove neighbors .. also convergence will be longer ..
Thanks Sam
if rib-has-route would work with a prefix-list containing hosts like RR or NMS which are always up
