05-15-2019 05:35 AM
I have been beating head against wall, I cant figure out problem. I have ### numbers for obvious reasons. What I do know is I have 100% connectivity over p2p's. From what I can tell I am set up correct, please can someone help.
BGP router identifier #.#.#.#, local AS number #####
BGP generic scan interval 60 secs
Non-stop routing is enabled
BGP table state: Active
Table ID: 0xe0000000 RD version: 14
BGP main routing table version 14
BGP NSR Initial initsync version 5 (Reached)
BGP NSR/ISSU Sync-Group versions 0/0
BGP scan interval 60 secs
BGP is operating in STANDALONE mode.
Process RcvTblVer bRIB/RIB LabelVer ImportVer SendTblVer StandbyVer
Speaker 14 14 14 14 14 0
Neighbor Spk AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down St/PfxRcd
#.#.37.201 0 ###15 0 0 0 0 0 00:00:00 Active
RP/0/RSP0/CPU0:May 15 08:27:20.887 ETC: bgp[1058]: [default-event] (ip6u): Scanning IPv6 Unicast routing table
RP/0/RSP0/CPU0:May 15 08:27:20.887 ETC: bgp[1058]: [default-event] (ip6u): Garbage collection for table TBL:default (2/1) prefix tree - Target version 5
RP/0/RSP0/CPU0:May 15 08:27:20.887 ETC: bgp[1058]: [default-event] (ip6u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:27:20.887 ETC: bgp[1058]: [default-event] (ip6u): Finished scanning IPv6 Unicast routing table
RP/0/RSP1/CPU0:May 15 08:27:22.751 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:27:25.132 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:27:37.753 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:27:40.134 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:27:43.684 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP0/CPU0:May 15 08:27:43.685 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:27:43.685 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:27:43.685 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
RP/0/RSP0/CPU0:May 15 08:27:43.689 ETC: bgp[1058]: [default-event] (vpn4u): Scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:27:43.689 ETC: bgp[1058]: [default-event] (vpn4u): Prefix count 0, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:27:43.689 ETC: bgp[1058]: [default-event] (vpn4u): Finished scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:27:43.693 ETC: bgp[1058]: [default-event] (ip4u): Scanning IPv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:27:43.693 ETC: bgp[1058]: [default-event] (ip4u): Garbage collection for table TBL:default (1/1) prefix tree - Target version 14
RP/0/RSP0/CPU0:May 15 08:27:43.693 ETC: bgp[1058]: [default-event] (ip4u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:27:43.693 ETC: bgp[1058]: [default-event] (ip4u): Finished scanning IPv4 unicast routing table
RP/0/RSP1/CPU0:May 15 08:27:46.566 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP1/CPU0:May 15 08:27:46.566 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:27:46.567 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:27:46.567 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:27:46.567 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
RP/0/RSP1/CPU0:May 15 08:27:52.755 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:27:55.135 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:28:07.756 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:28:08.057 ETC: bgp[1058]: [default-crit]: IDB: Tmr expired: 'BG'
RP/0/RSP1/CPU0:May 15 08:28:08.057 ETC: bgp[1058]: [default-crit]: IDB: Tmr started: 'BG', 60 sec
RP/0/RSP0/CPU0:May 15 08:28:10.137 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:28:10.404 ETC: bgp[1058]: [default-crit]: IDB: Tmr expired: 'BG'
RP/0/RSP0/CPU0:May 15 08:28:10.404 ETC: bgp[1058]: [default-crit]: IDB: Tmr started: 'BG', 60 sec
RP/0/RSP0/CPU0:May 15 08:28:20.889 ETC: bgp[1058]: [default-event] (ip6u): Scanning IPv6 Unicast routing table
RP/0/RSP0/CPU0:May 15 08:28:20.889 ETC: bgp[1058]: [default-event] (ip6u): Garbage collection for table TBL:default (2/1) prefix tree - Target version 5
RP/0/RSP0/CPU0:May 15 08:28:20.889 ETC: bgp[1058]: [default-event] (ip6u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:28:20.889 ETC: bgp[1058]: [default-event] (ip6u): Finished scanning IPv6 Unicast routing table
RP/0/RSP1/CPU0:May 15 08:28:22.758 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:28:25.139 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:28:37.760 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:28:40.141 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:28:43.687 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP0/CPU0:May 15 08:28:43.687 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:28:43.688 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:28:43.688 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:28:43.688 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
RP/0/RSP0/CPU0:May 15 08:28:43.692 ETC: bgp[1058]: [default-event] (vpn4u): Scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:28:43.692 ETC: bgp[1058]: [default-event] (vpn4u): Prefix count 0, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:28:43.692 ETC: bgp[1058]: [default-event] (vpn4u): Finished scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:28:43.696 ETC: bgp[1058]: [default-event] (ip4u): Scanning IPv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:28:43.696 ETC: bgp[1058]: [default-event] (ip4u): Garbage collection for table TBL:default (1/1) prefix tree - Target version 14
RP/0/RSP0/CPU0:May 15 08:28:43.696 ETC: bgp[1058]: [default-event] (ip4u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:28:43.696 ETC: bgp[1058]: [default-event] (ip4u): Finished scanning IPv4 unicast routing table
RP/0/RSP1/CPU0:May 15 08:28:46.569 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP1/CPU0:May 15 08:28:46.570 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:28:46.570 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:28:46.570 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
RP/0/RSP1/CPU0:May 15 08:28:52.762 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:28:55.142 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:29:07.763 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:29:08.059 ETC: bgp[1058]: [default-crit]: IDB: Tmr expired: 'BG'
RP/0/RSP1/CPU0:May 15 08:29:08.059 ETC: bgp[1058]: [default-crit]: IDB: Tmr started: 'BG', 60 sec
RP/0/RSP0/CPU0:May 15 08:29:10.144 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:29:10.406 ETC: bgp[1058]: [default-crit]: IDB: Tmr expired: 'BG'
RP/0/RSP0/CPU0:May 15 08:29:10.406 ETC: bgp[1058]: [default-crit]: IDB: Tmr started: 'BG', 60 sec
RP/0/RSP0/CPU0:May 15 08:29:20.891 ETC: bgp[1058]: [default-event] (ip6u): Scanning IPv6 Unicast routing table
RP/0/RSP0/CPU0:May 15 08:29:20.891 ETC: bgp[1058]: [default-event] (ip6u): Garbage collection for table TBL:default (2/1) prefix tree - Target version 5
RP/0/RSP0/CPU0:May 15 08:29:20.891 ETC: bgp[1058]: [default-event] (ip6u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:29:20.891 ETC: bgp[1058]: [default-event] (ip6u): Finished scanning IPv6 Unicast routing table
RP/0/RSP1/CPU0:May 15 08:29:22.765 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:29:25.146 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:29:37.767 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:29:40.148 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:29:43.690 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP0/CPU0:May 15 08:29:43.691 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:29:43.691 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:29:43.691 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
RP/0/RSP0/CPU0:May 15 08:29:43.695 ETC: bgp[1058]: [default-event] (vpn4u): Scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:29:43.695 ETC: bgp[1058]: [default-event] (vpn4u): Prefix count 0, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:29:43.695 ETC: bgp[1058]: [default-event] (vpn4u): Finished scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:29:43.699 ETC: bgp[1058]: [default-event] (ip4u): Scanning IPv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:29:43.699 ETC: bgp[1058]: [default-event] (ip4u): Garbage collection for table TBL:default (1/1) prefix tree - Target version 14
RP/0/RSP0/CPU0:May 15 08:29:43.699 ETC: bgp[1058]: [default-event] (ip4u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:29:43.699 ETC: bgp[1058]: [default-event] (ip4u): Finished scanning IPv4 unicast routing table
RP/0/RSP1/CPU0:May 15 08:29:46.572 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP1/CPU0:May 15 08:29:46.573 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:29:46.573 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:29:46.573 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
RP/0/RSP1/CPU0:May 15 08:29:52.769 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:29:55.149 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:30:07.770 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:30:08.061 ETC: bgp[1058]: [default-crit]: IDB: Tmr expired: 'BG'
RP/0/RSP1/CPU0:May 15 08:30:08.061 ETC: bgp[1058]: [default-crit]: IDB: Tmr started: 'BG', 60 sec
RP/0/RSP0/CPU0:May 15 08:30:10.151 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:30:10.408 ETC: bgp[1058]: [default-crit]: IDB: Tmr expired: 'BG'
RP/0/RSP0/CPU0:May 15 08:30:10.408 ETC: bgp[1058]: [default-crit]: IDB: Tmr started: 'BG', 60 sec
RP/0/RSP0/CPU0:May 15 08:30:20.893 ETC: bgp[1058]: [default-event] (ip6u): Scanning IPv6 Unicast routing table
RP/0/RSP0/CPU0:May 15 08:30:20.893 ETC: bgp[1058]: [default-event] (ip6u): Garbage collection for table TBL:default (2/1) prefix tree - Target version 5
RP/0/RSP0/CPU0:May 15 08:30:20.893 ETC: bgp[1058]: [default-event] (ip6u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:30:20.893 ETC: bgp[1058]: [default-event] (ip6u): Finished scanning IPv6 Unicast routing table
RP/0/RSP1/CPU0:May 15 08:30:22.772 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:30:25.153 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:30:37.774 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:30:40.155 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:30:43.693 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP0/CPU0:May 15 08:30:43.694 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:30:43.694 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:30:43.694 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
RP/0/RSP0/CPU0:May 15 08:30:43.698 ETC: bgp[1058]: [default-event] (vpn4u): Scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:30:43.698 ETC: bgp[1058]: [default-event] (vpn4u): Prefix count 0, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:30:43.698 ETC: bgp[1058]: [default-event] (vpn4u): Finished scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:30:43.702 ETC: bgp[1058]: [default-event] (ip4u): Scanning IPv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:30:43.702 ETC: bgp[1058]: [default-event] (ip4u): Garbage collection for table TBL:default (1/1) prefix tree - Target version 14
RP/0/RSP0/CPU0:May 15 08:30:43.702 ETC: bgp[1058]: [default-event] (ip4u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:30:43.702 ETC: bgp[1058]: [default-event] (ip4u): Finished scanning IPv4 unicast routing table
RP/0/RSP1/CPU0:May 15 08:30:46.575 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP1/CPU0:May 15 08:30:46.576 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:30:46.576 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:30:46.576 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
RP/0/RSP1/CPU0:May 15 08:30:52.776 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:30:55.156 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:31:07.777 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:31:08.063 ETC: bgp[1058]: [default-crit]: IDB: Tmr expired: 'BG'
RP/0/RSP1/CPU0:May 15 08:31:08.063 ETC: bgp[1058]: [default-crit]: IDB: Tmr started: 'BG', 60 sec
RP/0/RSP0/CPU0:May 15 08:31:10.158 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:31:10.410 ETC: bgp[1058]: [default-crit]: IDB: Tmr expired: 'BG'
RP/0/RSP0/CPU0:May 15 08:31:10.410 ETC: bgp[1058]: [default-crit]: IDB: Tmr started: 'BG', 60 sec
RP/0/RSP0/CPU0:May 15 08:31:20.895 ETC: bgp[1058]: [default-event] (ip6u): Scanning IPv6 Unicast routing table
RP/0/RSP0/CPU0:May 15 08:31:20.895 ETC: bgp[1058]: [default-event] (ip6u): Garbage collection for table TBL:default (2/1) prefix tree - Target version 5
RP/0/RSP0/CPU0:May 15 08:31:20.895 ETC: bgp[1058]: [default-event] (ip6u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:31:20.895 ETC: bgp[1058]: [default-event] (ip6u): Finished scanning IPv6 Unicast routing table
RP/0/RSP1/CPU0:May 15 08:31:22.779 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:31:25.160 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:31:37.781 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:31:40.162 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:31:43.696 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP0/CPU0:May 15 08:31:43.697 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:31:43.697 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:31:43.697 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
RP/0/RSP0/CPU0:May 15 08:31:43.701 ETC: bgp[1058]: [default-event] (vpn4u): Scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:31:43.701 ETC: bgp[1058]: [default-event] (vpn4u): Prefix count 0, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:31:43.701 ETC: bgp[1058]: [default-event] (vpn4u): Finished scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:31:43.705 ETC: bgp[1058]: [default-event] (ip4u): Scanning IPv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:31:43.705 ETC: bgp[1058]: [default-event] (ip4u): Garbage collection for table TBL:default (1/1) prefix tree - Target version 14
RP/0/RSP0/CPU0:May 15 08:31:43.705 ETC: bgp[1058]: [default-event] (ip4u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:31:43.705 ETC: bgp[1058]: [default-event] (ip4u): Finished scanning IPv4 unicast routing table
RP/0/RSP1/CPU0:May 15 08:31:46.578 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP1/CPU0:May 15 08:31:46.579 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:31:46.579 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:31:46.579 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
RP/0/RSP1/CPU0:May 15 08:31:52.783 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:31:55.163 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:32:07.784 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:32:08.065 ETC: bgp[1058]: [default-crit]: IDB: Tmr expired: 'BG'
RP/0/RSP1/CPU0:May 15 08:32:08.065 ETC: bgp[1058]: [default-crit]: IDB: Tmr started: 'BG', 60 sec
RP/0/RSP0/CPU0:May 15 08:32:10.165 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:32:10.412 ETC: bgp[1058]: [default-crit]: IDB: Tmr expired: 'BG'
RP/0/RSP0/CPU0:May 15 08:32:10.412 ETC: bgp[1058]: [default-crit]: IDB: Tmr started: 'BG', 60 sec
RP/0/RSP0/CPU0:May 15 08:32:20.897 ETC: bgp[1058]: [default-event] (ip6u): Scanning IPv6 Unicast routing table
RP/0/RSP0/CPU0:May 15 08:32:20.897 ETC: bgp[1058]: [default-event] (ip6u): Garbage collection for table TBL:default (2/1) prefix tree - Target version 5
RP/0/RSP0/CPU0:May 15 08:32:20.897 ETC: bgp[1058]: [default-event] (ip6u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:32:20.897 ETC: bgp[1058]: [default-event] (ip6u): Finished scanning IPv6 Unicast routing table
RP/0/RSP1/CPU0:May 15 08:32:22.786 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:32:25.167 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:32:37.788 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:32:40.169 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:32:43.699 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP0/CPU0:May 15 08:32:43.700 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:32:43.700 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:32:43.700 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
RP/0/RSP0/CPU0:May 15 08:32:43.704 ETC: bgp[1058]: [default-event] (vpn4u): Scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:32:43.704 ETC: bgp[1058]: [default-event] (vpn4u): Prefix count 0, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:32:43.704 ETC: bgp[1058]: [default-event] (vpn4u): Finished scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:32:43.708 ETC: bgp[1058]: [default-event] (ip4u): Scanning IPv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:32:43.708 ETC: bgp[1058]: [default-event] (ip4u): Garbage collection for table TBL:default (1/1) prefix tree - Target version 14
RP/0/RSP0/CPU0:May 15 08:32:43.708 ETC: bgp[1058]: [default-event] (ip4u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:32:43.708 ETC: bgp[1058]: [default-event] (ip4u): Finished scanning IPv4 unicast routing table
RP/0/RSP1/CPU0:May 15 08:32:46.581 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP1/CPU0:May 15 08:32:46.581 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:32:46.582 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:32:46.582 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:32:46.582 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
RP/0/RSP1/CPU0:May 15 08:32:52.790 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:32:55.170 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:33:07.791 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:33:08.067 ETC: bgp[1058]: [default-crit]: IDB: Tmr expired: 'BG'
RP/0/RSP1/CPU0:May 15 08:33:08.067 ETC: bgp[1058]: [default-crit]: IDB: Tmr started: 'BG', 60 sec
RP/0/RSP0/CPU0:May 15 08:33:10.172 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:33:10.414 ETC: bgp[1058]: [default-crit]: IDB: Tmr expired: 'BG'
RP/0/RSP0/CPU0:May 15 08:33:10.414 ETC: bgp[1058]: [default-crit]: IDB: Tmr started: 'BG', 60 sec
RP/0/RSP0/CPU0:May 15 08:33:20.899 ETC: bgp[1058]: [default-event] (ip6u): Scanning IPv6 Unicast routing table
RP/0/RSP0/CPU0:May 15 08:33:20.899 ETC: bgp[1058]: [default-event] (ip6u): Garbage collection for table TBL:default (2/1) prefix tree - Target version 5
RP/0/RSP0/CPU0:May 15 08:33:20.899 ETC: bgp[1058]: [default-event] (ip6u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:33:20.899 ETC: bgp[1058]: [default-event] (ip6u): Finished scanning IPv6 Unicast routing table
RP/0/RSP1/CPU0:May 15 08:33:22.793 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:33:25.174 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP1/CPU0:May 15 08:33:37.795 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:33:40.176 ETC: bgp[1058]: [default-iowt]: bgp_io_write_nbr_ver_timer_process: nbr_ver_timer handler: Empty ilist!! : Returning...
RP/0/RSP0/CPU0:May 15 08:33:43.702 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP0/CPU0:May 15 08:33:43.703 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:33:43.703 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP0/CPU0:May 15 08:33:43.703 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
RP/0/RSP0/CPU0:May 15 08:33:43.707 ETC: bgp[1058]: [default-event] (vpn4u): Scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:33:43.707 ETC: bgp[1058]: [default-event] (vpn4u): Prefix count 0, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:33:43.707 ETC: bgp[1058]: [default-event] (vpn4u): Finished scanning VPNv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:33:43.711 ETC: bgp[1058]: [default-event] (ip4u): Scanning IPv4 unicast routing table
RP/0/RSP0/CPU0:May 15 08:33:43.711 ETC: bgp[1058]: [default-event] (ip4u): Garbage collection for table TBL:default (1/1) prefix tree - Target version 14
RP/0/RSP0/CPU0:May 15 08:33:43.711 ETC: bgp[1058]: [default-event] (ip4u): Prefix count 1, Segment count 1, Segment size 100000
RP/0/RSP0/CPU0:May 15 08:33:43.711 ETC: bgp[1058]: [default-event] (ip4u): Finished scanning IPv4 unicast routing table
RP/0/RSP1/CPU0:May 15 08:33:46.584 ETC: bgp[1058]: [default-event]: Performing BGP generic scan
RP/0/RSP1/CPU0:May 15 08:33:46.585 ETC: bgp[1058]: [default-dyn]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:33:46.585 ETC: bgp[1058]: [default-rib2]: bgp_rib_rnh_table_flush called
RP/0/RSP1/CPU0:May 15 08:33:46.585 ETC: bgp[1058]: [default-event]: Finished BGP generic scan
Solved! Go to Solution.
05-15-2019 08:17 AM
This looks like eBGP with an update-source of a loopback but no ebgp-multihop, so your packets are never making it to the peer. Is the peer setup the same way or do they have ebgp-multihop?
Sam
05-15-2019 05:47 AM
Little more info:
BGP neighbor is #.#.#.#
Remote AS ###15, local AS ###82, external link
Description: BGP
Remote router ID 0.0.0.0
BGP state = Active
NSR State: None
Last read 00:00:00, Last read before reset 00:00:00
Hold time is 180, keepalive interval is 60 seconds
Configured hold time: 180, keepalive: 60, min acceptable hold time: 3
Last write 18:26:13, attempted 21, written 0
Second last write 00:00:00, attempted 0, written 0
Last write before reset 00:00:00, attempted 0, written 0
Second last write before reset 00:00:00, attempted 0, written 0
Last write pulse rcvd not set last full not set pulse count 0
Last write pulse rcvd before reset 00:00:00
Socket not armed for io, not armed for read, not armed for write
Last write thread event before reset 00:00:00, second last 00:00:00
Last KA expiry before reset 00:00:00, second last 00:00:00
Last KA error before reset 00:00:00, KA not sent 00:00:00
Last KA start before reset 00:00:00, second last 00:00:00
Precedence: internet
Graceful restart is enabled
Restart time is 120 seconds
Stale path timeout time is 360 seconds
Enforcing first AS is enabled
Multi-protocol capability not received
Received 0 messages, 0 notifications, 0 in queue
Sent 0 messages, 0 notifications, 0 in queue
Minimum time between advertisement runs is 30 secs
Inbound message logging enabled, 3 messages buffered
Outbound message logging enabled, 3 messages buffered
For Address Family: IPv4 Unicast
BGP neighbor version 0
Update group: 0.2 Filter-group: 0.0 No Refresh request being processed
NEXT_HOP is always this router
AF-dependent capabilities:
Graceful Restart capability advertised
Local restart time is 120, RIB purge time is 600 seconds
Maximum stalepath time is 360 seconds
Route refresh request: received 0, sent 0
Policy for incoming advertisements is PASS-ALL
Policy for outgoing advertisements is PASS-ALL
0 accepted prefixes, 0 are bestpaths
Exact no. of prefixes denied : 0.
Cumulative no. of prefixes denied: 0.
Prefix advertised 0, suppressed 0, withdrawn 0
Maximum prefixes allowed 524288
Threshold for warning message 97%, restart interval 0 min
An EoR was not received during read-only mode
Last ack version 1, Last synced ack version 0
Outstanding version objects: current 0, max 0, refresh 0
Additional-paths operation: None
Advertise routes with local-label via Unicast SAFI
Connections established 0; dropped 0
Local host: ##.###.32.225, Local port: 0, IF Handle: 0x00000000
Foreign host: ##.##.37.201, Foreign port: 0
Last reset 18:26:13, due to Admin. shutdown (CEASE notification sent - administrative shutdown)
Time since last notification sent to neighbor: 18:26:13
Error Code: administrative shutdown
Notification data sent:
None
BGP neighbor is ######18::e
Description: X | BGP
BGP state = Active
NSR State: None
Last write 00:00:00, attempted 0, written 0
For Address Family: IPv6 Unicast
Policy for incoming advertisements is IPV6-PASS-ALL
Policy for outgoing advertisements is IPV6-PASS-ALL
Threshold for warning message 75%, restart interval 0 min
Local host: 2604:db40::100, Local port: 0, IF Handle: 0x00000000
Foreign host: 2600:6c18::e, Foreign port: 0
Last reset 00:00:00
PCB VRF-ID Recv-Q Send-Q Local Address Foreign Address State
0x1339cdf4 0x60000000 0 0 #########::100:62529 ###########e:179 CLOSED
0x13359438 0x60000000 0 0 :::22 :::0 LISTEN
0x13355c30 0x00000000 0 0 :::22 :::0 LISTEN
0x1332d280 0x60000000 0 0 :::646 :::0 LISTEN
0x1332d0b0 0x00000000 0 0 :::646 :::0 LISTEN
0x13350734 0x60000000 0 0 :::179 :::0 LISTEN
0x1334cf74 0x00000000 0 0 :::179 :::0 LISTEN
0x1339cc24 0x60000000 0 0 ##########125:22 #######10.34:33262 ESTAB
0x13347ed4 0x60000000 0 0 #######32.225:43047 #######37.201:179 CLOSED
0x13359268 0x60000000 0 0 0.0.0.0:22 0.0.0.0:0 LISTEN
0x13352144 0x00000000 0 0 0.0.0.0:22 0.0.0.0:0 LISTEN
0x13351acc 0x60000000 0 0 0.0.0.0:23 0.0.0.0:0 LISTEN
0x13329230 0x00000000 0 0 0.0.0.0:23 0.0.0.0:0 LISTEN
0x1332caf4 0x60000000 0 0 0.0.0.0:646 0.0.0.0:0 LISTEN
0x13331978 0x00000000 0 0 0.0.0.0:646 0.0.0.0:0 LISTEN
0x1334cb7c 0x60000000 0 0 0.0.0.0:179 0.0.0.0:0 LISTEN
0x13318158 0x00000000 0 0 0.0.0.0:179 0.0.0.0:0 LISTEN
0x13318558 0x00000000 0 0 0.0.0.0:0 0.0.0.0:0 CLOSED
05-15-2019 06:43 AM
Active running config:
route-policy PASS-ALL
pass
end-policy
route-policy IPV6-PASS-ALL
pass
end-policy
#sh run router bgp
router bgp ###82
nsr
bgp router-id ##.###.32.225
bgp graceful-restart restart-time 120
bgp graceful-restart stalepath-time 360
bgp log neighbor changes detail
address-family ipv4 unicast
bgp attribute-download
aggregate-address ##.###.32.0/24 as-set
aggregate-address ##.###.33.0/24 as-set
redistribute connected route-policy BGP-CONNECTED
redistribute static route-policy BGP-STATIC
address-family vpnv4 unicast
address-family ipv6 unicast
redistribute connected route-policy IPV6-BGP-CONNECTED
redistribute static route-policy IPV6-BGP-STATIC
neighbor-group MPBGP-vpn
remote-as ###82
update-source Loopback14
neighbor-group iBGP-Peers
remote-as ###82
password encrypted *************************
description "BGP Peers config"
update-source Loopback15
route-policy PASS-ALL in
maximum-prefix 524288 97
next-hop-self
neighbor-group IPV6-iBGP-Peers
remote-as ###82
route-policy IPV6-PASS-ALL in
next-hop-self
neighbor #########::e
remote-as ###15
password encrypted ***************************
description BGP
route-policy IPV6-PASS-ALL out
next-hop-self
neighbor ##.###.37.201
remote-as ###15
password encrypted ******************************
description BGP
route-policy PASS-ALL out
next-hop-self
05-15-2019 08:17 AM
Sam
05-15-2019 08:34 AM
Peer is set up very similar. Would the require ebgp multihop 4?
05-15-2019 09:59 AM
Wow, That was it.. I removed update source loopback and Now I am established. Thank you so much for everything..
05-15-2019 06:44 AM
Message sent and received is 0. BGP is actively trying set up a TCP session.
Can you check if no issues with peer IP and update source
Check no ACLs in path and TCP port 179 open . try telnetting manually to peer port 179 from right source and verify if a successful session is set up.
Ashish
05-15-2019 07:52 AM
I don't have any ACL or blocks that I can see, I have a juniper on the /29 that peers to same unit far side and they are working fine. The ISP has stated 179 is not open for me. Unfortunately I can not figure out how or why.
interface Loopback15
description BGP-LOOPBACK
ipv4 address ##.###.32.225 255.255.255.255
ipv6 address #########::100/128
ipv4 access-list 5
10 permit ipv4 ##.###.11.160 0.0.0.31 any (5042426 matches)
20 permit ipv4 ##.###.0.0 0.0.31.255 any
ipv4 access-list MPLS_LOOPBACK_RANGE
10 permit ipv4 ##.###.32.192 0.0.0.31 any
ipv4 access-list NTP-SECURITY
10 permit ipv4 host ##.###.10.1 any (2309 matches)
20 permit ipv4 host ##.###.10.2 any (2323 matches)
210 deny ipv4 any any (353 matches)
ipv4 access-list QACL-L3-ROUTING
10 remark ports for bgp and ldp
20 permit tcp any any eq bgp
30 permit tcp any eq bgp any
40 permit tcp any any eq ldp
50 permit tcp any eq ldp any
60 permit udp any any eq ldp
70 permit udp any eq ldp any
ipv4 access-list QL-ALL
10 permit ipv4 any any
snmp-server community $$$$$$$p view restricted RO SystemOwner IPv4 5
