CBC FPD UPGRADE FAIL
I try to make an upgrade of an ISM FPD and generates an error that is:
FPD upgrade started.
FPD upgrade in progress on some hardware, reload/configuration change
on those is not recommended as it might cause HW programming failure
and result in RMA of the hardware.
Starting the upgrade/download of following FPD:
Current Upg/Dng
Location Type Subtype Upg/Dng Version Version
0/4/CPU0 lc cbc upg 18.5 18.6
FPD upgrade sent to location node0_4_CPU0
FPD upgrade completed for location node0_4_CPU0
% Failed to upgrade 1 FPD for A9K-ISM-100 on location 0/4/CPU0
which could be the problem?
smilstea
It looks like you are hitting the following bug, no need to worry about the FPD upgrade not working.
CSCue46842
Sam
smilstea
CSCue46842
Sam
thanks a lot for you help smilstea, I'll make the upgrade to version indicating the fix
