Dear All
I need to install the LC CIO:A9K-2T20GE-L in my new ASR9010 Chassis and wanted to know if there are any limitations for which Line Card Slots this can be installed into. Tried to look online but did not get any thing related to this yet.
Varma
Solved! Go to Solution.
there are no limitations or directions, you may use any slot except those for RSPs.
Hello Varma,
therse is no such PID as CIO:A9K-2t20GE-L
http://www.cisco.com/en/US/partner/prod/collateral/routers/ps9853/data_sheet_c78-501338.html
For the A9K-2t20GE-L there is no limitation.
wbr
/vadim
Hello Varma,
wbr
/vadim
Hi Folks
Thanks a ton for the clarification and confirmation.
Varma
