Cisco ASR 9006 - Upgrade to 6.5.3 from 4.2.3
farooqateeq123
Hello Everyone!!!
I am new to ASR 9000 series..
We are having 2 ASR 9006 routers and we are planning to upgrade IOS-XR from 4.2.3 to 6.5.3.
Can someone suggest which upgrade document to follow and the required SMUs to commit before the upgrade.
Mohammed Farooq.
philclemens1835
This is the go-to thread for upgrades:
https://community.cisco.com/t5/service-providers-documents/ios-xr-release-strategy-and-deployment-recommendation/ta-p/3165422
That said, this is a big jump, so you'll definitely want to cover the release notes for 6.5.3.
Also, if you're running an RSP-440, you'll only be able to get to 6.4.2.
smilstea
You will need to go to 5.3.x first, or turboboot the router.
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-xr-software/213745-ios-xr-upgrade-changes-certificate-expi.html
What hardware are you running, RSP4G/8G and any -L,-T, -B, -E cards are not supported past 5.3.4, only -TR and -SE cards.
Sam
