Cisco ASR 9010 Error
Bilal Raziq
Hi All
Playing around with EBGP XOR ver 5.1.3 ....I got some below log messages ..Everything is fine as far as routing and traffic is concerned ..A friend told me its a bug ..i couldn't find anything on it ..Please share your thoughts
LC/0/1/CPU0:Dec 28 00:38:25.991 : fib_mgr[184]: %ROUTING-FIB-5-ROUTE_UPDATE_DROP : FIB dropping route update: LABEL-RECYCLING: label=36682 new-prefix=172.30.155.160/29, tbl=UP, old-prefix=0.0.0.0/0, tbl=GN,  lcnt=1, rt-src=6
LC/0/0/CPU0:Dec 28 00:38:26.097 : fib_mgr[184]: %ROUTING-FIB-5-ROUTE_UPDATE_DROP : FIB dropping route update: LABEL-RECYCLING: label=36682 new-prefix=172.30.155.160/29, tbl=UP, old-prefix=0.0.0.0/0, tbl=GN,  lcnt=1, rt-src=6
Bilal
smailmilak
Level 4
Level 4
Hi Bila,
check out this link (CCO needed). Do an upgrade to 5.3.4 if possible. We have upgraded around 8 devices because of several bugs on previous versions.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCun29482
Symptom:
RP/0/RSP0/CPU0:Mar 3 16:19:10.009 : fib_mgr[221]: %ROUTING-FIB-5-ROUTE_UPDATE_DROP : FIB dropping route update: LABEL-RECYCLING: label=120734 new-prefix=192.0.48.0/24, tbl=red445, old-prefix=202.153.144.26/32, tbl=default, lcnt=1, rt-src=6
This results in the new-prefix being incorrectly programmed in CEF or missing.
Conditions:
May occur under the following conditions:
- A /32 prefix (mentioned in old-prefix) is present as a result of an attached route in RIB out of a multi-access interface; and
- LDP has advertised the prefix such that a local label has been allocated for it; and
- An RP switchover has happened in the past where after switchover the prefix stopped being advertised for some reason.
Workaround:
Use a different length prefix if possible to avoid the issue. After the issue occurs perform "clear cef linecard loc <>" to clear the stale CEF information and reprogram.
smailmilak
Level 4
Level 4
Hi Bila,
Symptom:
Conditions:
Workaround:
