Bookmark
Subscribe
455
Cisco ASR XR QoS - Policy Rate not honoured
francisco.baena
Hi all,
We're trying to cap bandwidth on an Ethernet Bundle subinterface to 50mbps, but regardless of what we do, is just doesn't cap it at exactly 50 Mbps. What we did notice though, is that a ‘normal’ file download is limited to 50Mbps but certain other traffic can exceed this.
We cannot define what this traffic is as it appears to be random. It is almost as if the limit is applying to single streams and not the traffic leaving the interface as a whole.
Sample config below
!========= Using shape Average =========
policy-map TestPolicy-50Mbps
description TestPolicy 50Mbps
class class-default
random-detect default
shape average 50 mbps
end-policy-map
!========= Also tried using police rate =========
class class-default
police rate 50 mbps
end-policy-map
interface Bundle-Ether1.1234
description #### Test link ####
service-policy output TestPolicy-50Mbps
ipv4 address x.x.x.x 255.255.255.252
encapsulation dot1q outerQVID second-dot1q InnerQVID
Many thanks and best regards
Francisco
smilstea
Do you by chance have multiple interfaces in the bundle?
Service policies are replicated to each bundle member, so each will get 50Mbps, not the entire bundle. To get around this on ingress you would need to do src-dst load-balancing on the downstream device so that traffic only goes to one bundle member.
Sam
