CISCO ASR901 BRIDGE BETWEEN 2 INTERFACES
gfreitasf
Hi All!
  I'm looking for some way to make a transparent bridge between two interfaces of a Cisco router ASR901 , is there any possibility? I ask this because I have a scenario where I would use the ASR901 to the following question :
POP01 (                       ) ASR901  g0 / 6 -------- > ISG_7206
POP02 ( MPLS CLOUD )               g0 / 7 -------- > ISG_7206
POP03 (                       )
The ASR901 will focus EoMPLS with other points in the network and pass on to ISG routers , ie , VLANs would have to be two ports with XConnect to a remote router , the configuration would be something like this :
interface GigabitEthernet0/6
Core description : MPLS CONC PPPOE02
no ip address
negotiation auto
hold- queue 1024 in
hold- queue 1024 in October
service instance 4095 ethernet
  encapsulation dot1q 4094
  rewrite ingress tag pop 1 symmetric
interface GigabitEthernet0/7
Core description : 7206_PPPOE_01
no ip address
negotiation auto
end
L2VPN XConnect context TEST
ethernet interworking
member 201.55.127.202 1212 encapsulation mpls group TEST
member GigabitEthernet0 / 7 service -instance TEST 4095 group priority 1
member GigabitEthernet0 / 6 service -instance 4095
redundancy group delay 1 3 TEST
But without an interface that was redundant of other , what I need is the 2 interfaces in " bridge " making a XConnect to a remote router , and these 2 interfaces connected ISGs in 2 to make a balance .
Rivalino Tamaela
This discussion is for IOS-XR related questions. You should post your question under Service Provider > MPLS.
thanks,
rivalino
Thanks Rivalino! I post the discussion on the right place.
