Commit and Update taking too long on XR OS
witani
Dears,
We have using an ASR9K for 3 years. Commit and update used to take 1 or 2 sec. Suddenly it started to take 20 sec to finish.
CPU is around 9 %. Any idea how to approach this problem ?
8 Replies 8
Eddie Chami
Dear its probably due to a leak, or a process blocked, or some busted verifier. What release is this on? TO check these you normally start with show log, you'll see noise there, followed by show process blocked, then show proc mem..
if your running old release you may want to upgrade.
If you want to stay on your current release, start looking at the above to give you some leads.
Eddie.
Thank you Eddy.
My version i Cisco IOS XR Software, Version 4.2.1[Default]
I see processes in reply state for a long time, is that what you are talking about ?
RP/0/RSP0/CPU0:cvas-2#sh processes blocked
Thu Feb 25 09:27:08.311 EET
  Jid       Pid Tid            Name State   TimeInState    Blocked-on
65549     16397   1             ksh Reply 31175:43:10:0070   16395  devc-conaux
65554     65554   2      devb-umass Reply    0:00:00:0120   53284  io-usb
   97     49187   2      umass-enum Reply 31175:43:13:0250       1  kernel
   97     49187   6      umass-enum Reply 31175:43:07:0854   53284  io-usb
   97     49187   7      umass-enum Reply 31175:43:10:0372       1  kernel
   97     49187   8      umass-enum Reply 31175:43:09:0191       1  kernel
   97     49187   9      umass-enum Reply 31175:43:07:0855       1  kernel
   52     65574   2         attachd Reply 31175:43:11:0191   57381  eth_server
   52     65574   3         attachd Reply 31175:43:11:0189   24595  mqueue
   88     65580   6            qnet Reply    0:00:00:0037   57381  eth_server
   51     65584   2   attach_server Reply 31175:43:11:0000   24595  mqueue
65588     65588   2      devb-umass Reply    0:00:02:0553   53284  io-usb
65593     77881   2      devb-umass Reply    0:00:50:0963   53284  io-usb
  435    233568   1     tftp_server Reply 13748:49:31:0186   24595  mqueue
  317    295142   2         lpts_fm Reply    0:00:00:0074  282764  lpts_pa
65868 128377164   1            more Reply    0:00:00:0063   24593  pipe
65882 128377178   1  show_processes Reply    0:00:00:0000       1  kernel
65892 128323940   1            exec Reply    0:00:00:0161       1  kernel
Nothing there looks odd, you probably want to look at this during a commit when its hanging, or syslog/memory leak. You have a pretty old release here, you should upgrade.
Hi Eddie,
As you suggested, I looked at blocked processes during commit hanging. Four extra processes appeared. Appreciate if you have a look.
Output before commit command:
65549     16397   1             ksh Reply 31223:55:29:0824   16395 devc-conaux
65554     65554   2     devb-umass Reply   0:00:33:0568   53284 io-usb
   97     49187   2     umass-enum Reply 31223:55:33:0004       1 kernel
   97     49187   6     umass-enum Reply 31223:55:27:0608   53284 io-usb
   97     49187   7     umass-enum Reply 31223:55:30:0126       1 kernel
   97     49187   8     umass-enum Reply 31223:55:28:0945       1 kernel
   97     49187   9     umass-enum Reply 31223:55:27:0609       1 kernel
   52     65574   2         attachd Reply 31223:55:30:0945   57381 eth_server
   52     65574   3         attachd Reply 31223:55:30:0943   24595 mqueue
   88     65580   6           qnet Reply   0:00:00:0048   57381 eth_server
   51    65584   2   attach_server Reply 31223:55:30:0755   24595 mqueue
65588     65588   2     devb-umass Reply   0:00:03:0573   53284 io-usb
65593     77881   2     devb-umass Reply   0:00:13:0939   53284 io-usb
435   233568   1     tftp_server Reply 13797:01:50:0940   24595 mqueue
317   295142   2         lpts_fm Reply   0:00:00:0661 282764 lpts_pa
65882 179966298   1           exec Reply   0:00:04:0826 295133 devc-vty
65888 179970400   1           exec Reply   0:00:00:0149       1 kernel
65889 179974497   1           more Reply   0:00:00:0064   24593 pipe
65890 179974498   1 show_processes Reply   0:00:00:0000       1 kernel
Output after commit command:
65549     16397   1             ksh Reply 31223:55:43:0739   16395 devc-conaux
65554     65554   2     devb-umass Reply   0:00:04:0533   53284 io-usb
   97     49187   2     umass-enum Reply 31223:55:46:0921       1 kernel
   97     49187   6     umass-enum Reply 31223:55:41:0525   53284 io-usb
   97     49187   7     umass-enum Reply 31223:55:44:0043       1 kernel
   97     49187   8     umass-enum Reply 31223:55:42:0862       1 kernel
   97     49187   9     umass-enum Reply 31223:55:41:0526       1 kernel
   52     65574   2         attachd Reply 31223:55:44:0862   57381 eth_server
   52     65574   3         attachd Reply 31223:55:44:0860   24595 mqueue
   88     65580   6           qnet Reply   0:00:00:0005   57381 eth_server
   51     65584   2   attach_server Reply 31223:55:44:0671   24595 mqueue
65588     65588   2     devb-umass Reply   0:00:17:0489   53284 io-usb
65593     77881   2     devb-umass Reply   0:00:27:0856   53284 io-usb
435   233568   1     tftp_server Reply 13797:02:04:0857   24595 mqueue
317   295142   2         lpts_fm Reply   0:00:01:0060 282764 lpts_pa
65882 179966298   1           exec Reply   0:00:06:0289       1 kernel
65889 179982689   1       rpl_edit Reply   0:00:05:0176       1 kernel
65890 179986786   1         config Reply   0:00:03:0545 233567 rdsfs_svr
65892 179986788   1           more Reply   0:00:00:0068   24593 pipe
65893 179986789   1 show_processes Reply   0:00:00:0000       1 kernel
That doesn't look problematic, you'll need to start looking at the configmgr traces to see why there is a delay, are you in a position to upgrade to 5.1.3 or 5.3.3?
Eddie.
Thank you Eddie,
I read that moving from 4.2 to 5.x requires long outages, is that true ?
The downtime should not be more than 15mins.
Eddie.
AARON WEINTRAUB
On several 4.x releases we had issues with the vic/ether_ctrl processes getting locked up and tied up with the license manager, sometimes causing commits to timeout or take a very long time.  A show proc blocked (from another terminal) would be a good starting point.
