Configuring a DWDM interface on asr9k
Paul Lachance
Happy Holidays
We are trying to configure a DWDM interface from one asr 9k to another asr 9k both are running ios-xr 5.1.3
and both DWDM transceivers are in a A9k-MPA-4x10GE Spa within a A9k-mod80-tr.
our configuration goes like this :
Can anybody add something we get down down on both sides
ONS optical circuit is built and shows no errors . our chosen wave length is 1560.61.
we have very good confidence that the OTN path is not causing us problems.
All optical values meet or exceed other values of working circuits.
R1
Mon Dec 29 14:32:10.317 EST
interface TenGigE0/1/0/0
  bandwidth 10000000
 cdp
 ipv4 address 192.168.0.1 255.255.255.252
 transport-mode wan
Mon Dec 29 14:34:09.242 EST
controller dwdm0/1/0/0
 wavelength 81
 network connection id 0/1/0/0
 network port id 0/1/0/0
 admin-state in-service
controller wanphy 0/1/0/0
wanmode on
R2
  bandwidth 10000000
 cdp
 ipv4 address 192.168.0.2 255.255.255.252
 transport-mode wan
 wavelength 81
wanmode on
R1
NAME: "module 0/1/CPU0", DESCR: "80G Modular Linecard, Packet Transport Optimized"
PID: A9K-MOD80-TR, VID: V06, SN: FOC1835NNEG
NAME: "module 0/1/0", DESCR: "ASR 9000 4-port 10GE Modular Port Adapter"
PID: A9K-MPA-4X10GE, VID: V05, SN: FOC1836N7H5
NAME: "module mau 0/1/0/0", DESCR: "DWDM Tunable Wavelength XFP, Channel 1 to 82"
PID: DWDM-XFP-C          , VID: V02 , SN: JFX1741A037
Mon Dec 29 14:30:55.955 EST
Default Profile:
  SDRs:
    Owner
  Active Packages:
    disk0:asr9k-services-infra-5.1.3
    disk0:asr9k-bng-px-5.1.3
    disk0:asr9k-doc-px-5.1.3
    disk0:asr9k-fpd-px-5.1.3
    disk0:asr9k-li-px-5.1.3
    disk0:asr9k-mcast-px-5.1.3
    disk0:asr9k-mgbl-px-5.1.3
    disk0:asr9k-mini-px-5.1.3
    disk0:asr9k-mpls-px-5.1.3
    disk0:asr9k-optic-px-5.1.3
    disk0:asr9k-services-px-5.1.3
    disk0:asr9k-video-px-5.1.3
    disk0:asr9k-px-5.1.3.sp1-1.0.0
    disk0:asr9k-px-5.1.3.CSCui35197-1.0.0
    disk0:asr9k-px-5.1.3.CSCuo85256-1.0.0
    disk0:asr9k-px-5.1.3.CSCur17130-1.0.0
    disk0:asr9k-px-5.1.3.CSCur22750-1.0.0
    disk0:asr9k-px-5.1.3.CSCur31362-1.0.0
    disk0:asr9k-px-5.1.3.CSCur31975-1.0.0
    disk0:asr9k-px-5.1.3.CSCur44366-1.0.0
    disk0:asr9k-px-5.1.3.CSCur50363-1.0.0
    disk0:asr9k-px-5.1.3.CSCur54568-1.0.0
    disk0:asr9k-px-5.1.3.CSCur61441-1.0.0
    disk0:asr9k-px-5.1.3.CSCur68953-1.0.0
    disk0:asr9k-px-5.1.3.CSCur74875-1.0.0
    disk0:asr9k-k9sec-px-5.1.3
Mon Dec 29 14:46:03.358 EST
Port dwdm0/1/0/0
Controller State: Up
Transport Admin State: In Service
Loopback: None
G709 Status
         G709 Disabled
Connectivity Info
                Network Port ID:  0/1/0/0
                Network Connection ID:  0/1/0/0
Optics Status
         Optics Type:  10G-TUNABLE-by-CHANNEL,
         Wavelength Info: C-Band, MSA ITU Channel=81, Frequency=192.10THz, Wavelength=1560.606nm
         Wavelength Owner: Configuration, ITU Channel: GMPLS Signaled=None, Configured=81, Hardware Default=82
         TX Power = -40.00 dBm
         RX Power = -17.93 dBm
TDC Info
        TDC Not Supported on the Plim
Network SRLG values:
        Not Configured
Mon Dec 29 14:47:19.738 EST
Interface: wanphy0/1/0/0
Configuration Mode: LAN Mode
SECTION
  LOF = 1, LOS = 2, BIP(B1) = 0
LINE
  AIS = 0, RDI = 0, FEBE = 0, BIP(B2) = 0
PATH
  AIS = 0, RDI = 0, FEBE = 0, BIP(B3) = 0
  LOP = 0, NEWPTR = 0, PSE = 0, NSE = 0
WIS ALARMS
  SER = 592986, FELCDP = 0, FEAISP = 0
  WLOS = 2, PLCD = 2
  LFEBIP = 0, PBEC = 0, PLMP = 0
Active Alarms[All defects]:
Active Alarms[Highest Alarms]:
  Rx(K1/K2): N/A, Tx(K1/K2): N/A
  S1S0 = N/A, C2 = N/A
PATH TRACE BUFFER
Remote IP addr:
BER thresholds: SF = E-3 SD = E-6
TCA thresholds: N/A
Alarm reporting enabled for:
REGISTERS
P_FEBE  : 0
L_FE_BIP: 0
L_BIP   : 0
P_BEC   : 0
S_BIP   : 0
J1-Rx0  : 0x   0
J1-Rx1  : 0x   0
J1-Rx2  : 0x   0
J1-Rx3  : 0x   0
J1-Rx4  : 0x   0
J1-Rx5  : 0x   0
J1-Rx6  : 0x   0
J1-Rx7  : 0x   0
Internal Information
Operational Mode: WAN Mode
Curent Alarms: 0x0
Mon Dec 29 14:48:32.392 EST
TenGigE0/1/0/1 is down, line protocol is down
  Interface state transitions: 0
  Hardware is TenGigE, address is e0ac.f12d.0f59 (bia e0ac.f12d.0f59)
  Layer 1 Transport Mode is LAN
 Internet address is 192.168.0.1/30
  MTU 1500 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation ARPA,
  Full-duplex, 10000Mb/s, link type is force-up
  output flow control is off, input flow control is off
  loopback not set,
  Last input never, output never
     0 packets input, 0 bytes, 0 total input drops
     0 drops for unrecognized upper-level protocol
     Received 0 broadcast packets, 0 multicast packets
              0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 total output drops
     Output 0 broadcast packets, 0 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     0 carrier transitions
R2
PID: A9K-MOD80-TR, VID: V06, SN: FOC1835NNKY
PID: A9K-MPA-4X10GE, VID: V05, SN: FOC1836N7KL
PID: DWDM-XFP-C          , VID: V02 , SN: JFX1830A006
Mon Dec 29 14:37:26.163 EST
Default Profile:
  SDRs:
    Owner
  Active Packages:
    disk0:asr9k-9000v-nV-px-5.1.3
    disk0:asr9k-px-5.1.3.CSCuo94506-1.0.0
    disk0:asr9k-px-5.1.3.CSCup67076-1.0.0
    disk0:asr9k-px-5.1.3.CSCuq81002-1.0.0
    disk0:asr9k-px-5.1.3.CSCuq94618-1.0.0
    disk0:asr9k-px-5.1.3.CSCur18995-1.0.0
Mon Dec 29 14:46:38.046 EST
Port dwdm0/1/0/0
Loopback: None
G709 Status
         G709 Disabled
Connectivity Info
Optics Status
         Wavelength Owner: Configuration, ITU Channel: GMPLS Signaled=None, Configured=81, Hardware Default=81
         RX Power = -19.13 dBm
TDC Info
        Not Configured
Mon Dec 29 14:48:02.064 EST
SECTION
  LOF = 1, LOS = 1, BIP(B1) = 0
LINE
PATH
WIS ALARMS
  SER = 1213154, FELCDP = 0, FEAISP = 0
  WLOS = 1, PLCD = 2
PATH TRACE BUFFER
Remote IP addr:
TCA thresholds: N/A
REGISTERS
P_FEBE  : 0
L_FE_BIP: 0
L_BIP   : 0
P_BEC   : 0
S_BIP   : 0
J1-Rx0  : 0x   0
J1-Rx1  : 0x   0
J1-Rx2  : 0x   0
J1-Rx3  : 0x   0
J1-Rx4  : 0x   0
J1-Rx5  : 0x   0
J1-Rx6  : 0x   0
J1-Rx7  : 0x   0
Curent Alarms: 0x0
Mon Dec 29 14:48:41.989 EST
TenGigE0/1/0/0 is down, line protocol is down
  Interface state transitions: 2
  Hardware is TenGigE, address is e0ac.f12d.0f88 (bia e0ac.f12d.0f88)
  Layer 1 Transport Mode is WAN
   Internet address is 192.168.0.2/30
  Encapsulation ARPA,
  loopback not set,
  ARP type ARPA, ARP timeout 04:00:00
     2 carrier transitions
11 Replies 11
xthuijs
I think you're missing the "controller wanphy 0/1/0/0 wanmode on" config.
ps, minor thing but you displayed the 0/1/0/1 where the interface/dwdm controller is 0/1/0/0...
cheers!
xander
Yes , it's in the config
I had hand wrote it in the post so was probably not that clear.
I was editing out a few numbers also that was why the interface numbers didn't match.
We opened a TAC case with CISCO to hopefully bear fruit on what we could be missing.
Hope it's not a license . Which is required for the G.709 wrapper .
Yes now I see , The interface displau is on 0/1/0/1 not 0/1/00
it is the same as the other . down down
could you share the show controller dwdm <ctrlr> optics|tdc|pm history
and a show controller teng <if> mac|phy|stat|int
maybe that signifies something also.
one thing that pops into my mind also is possibly an unsupported optic possibly (eg due to hw rev).
Can you also show the run of the dwdm controller and the tengig interface?
that might give me some more clue.
If you can share the tac case ID then I can have a look there also to see if any of that info may be present already I Am looking for.
cheers
xander
The transceivers were purchased from a Cisco partner.
Tac case
SR 633175547 : Interface down down between a DWDM transceivers on the ASR9k platform
R1
Wed Dec 31 11:33:57.778 EST
Optics Status
         RX Power = -18.63 dBm
RP/0/RSP0/CPU0:ott.kedc.pe2#sh controllers dwdm 0/1/0/0 tdc
Wed Dec 31 11:34:03.999 EST
TDC Info
RP/0/RSP0/CPU0:ott.kedc.pe2#sh controllers dwdm 0/1/0/0 pm history optics
Wed Dec 31 11:34:07.661 EST
Optics in the current interval [11:30:00 - 11:34:07 Wed Dec 31 2014]
Interval: Valid
              MIN     AVG     MAX  Threshold  TCA  Threshold    TCA
                                   (min)  (enable) (max)    (enable)
LBC[mA ]  :  0       0       0       0          NO      0        NO
OPT[dBm]  :  -40.00   -40.00   -40.00   0.00       NO      0.00     NO
OPR[dBm]  :  -18.73   -18.63   -18.54   0.00       NO      0.00     NO
Optics in interval 1 [11:15:00 - 11:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.73    -18.63    -18.51
Optics in interval 2 [11:00:00 - 11:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.73    -18.60    -18.45
Optics in interval 3 [10:45:00 - 11:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.70    -18.60    -18.48
Optics in interval 4 [10:30:00 - 10:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.73    -18.60    -18.48
Optics in interval 5 [10:15:00 - 10:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.70    -18.63    -18.48
Optics in interval 6 [10:00:00 - 10:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 7 [ 9:45:00 - 10:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 8 [ 9:30:00 -  9:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.70    -18.60    -18.45
Optics in interval 9 [ 9:15:00 -  9:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.73    -18.63    -18.48
Optics in interval 10 [ 9:00:00 -  9:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 11 [ 8:45:00 -  9:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.79    -18.70    -18.54
Optics in interval 12 [ 8:30:00 -  8:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 13 [ 8:15:00 -  8:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.70    -18.57    -18.42
Optics in interval 14 [ 8:00:00 -  8:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.70    -18.60    -18.42
Optics in interval 15 [ 7:45:00 -  8:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.76    -18.66    -18.48
Optics in interval 16 [ 7:30:00 -  7:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 17 [ 7:15:00 -  7:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.79    -18.70    -18.57
Optics in interval 18 [ 7:00:00 -  7:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.76    -18.66    -18.54
Optics in interval 19 [ 6:45:00 -  7:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.79    -18.66    -18.57
Optics in interval 20 [ 6:30:00 -  6:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.76    -18.66    -18.51
Optics in interval 21 [ 6:15:00 -  6:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 22 [ 6:00:00 -  6:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.76    -18.66    -18.57
Optics in interval 23 [ 5:45:00 -  6:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.83    -18.70    -18.51
Optics in interval 24 [ 5:30:00 -  5:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 25 [ 5:15:00 -  5:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 26 [ 5:00:00 -  5:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 27 [ 4:45:00 -  5:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.79    -18.66    -18.54
Optics in interval 28 [ 4:30:00 -  4:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 29 [ 4:15:00 -  4:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.79    -18.66    -18.51
Optics in interval 30 [ 4:00:00 -  4:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 31 [ 3:45:00 -  4:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 32 [ 3:30:00 -  3:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in the current interval [00:00:00 - 11:34:08 Wed Dec 31 2014]
Interval: Valid
OPR[dBm]  :  -18.79   -18.63   -18.42   0.00       NO      0.00     NO
Optics in interval 1 [00:00:00 - 24:00:00 Tue Dec 30 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.89    -18.66    -18.27
RP/0/RSP0/CPU0:ott.kedc.pe2#sh controllers tenGigE 0/1/0/0 mac
Wed Dec 31 11:39:20.594 EST
 HW_LINK LASI
RP/0/RSP0/CPU0:ott.kedc.pe2#sh controllers tenGigE 0/1/0/0 phy
Wed Dec 31 11:39:27.073 EST
XFP EEPROM  port: 0
        Xcvr Type: T-XFP
        Ext Type: 3.5 W, CDR Supported, No Tx Ref Clk input req., CLEI present,
        Connector Type: LC
        Ethernet Xcvr Codes:
        SONET Xcvr Codes: 10G-TUNABLE-by-CHANNEL,
        Encoding: 64B/66B, SONET Scrambled, NRZ,
        Bit Rate Min.: 9900 Mbit/s
        Bit Rate Max.: 11300 Mbit/s
        Link Reach 9u SM fiber: 80 Km
        Device Tech.: Active wavelength ctrl, Cooled Xmtr, APD detector, Xmtr tunable,
        Vendor Name CISCO-JDSU
        CDR Support: 9.95 Gb/s, 10.3 Gb/s, 10.5 Gb/s, 10.7 Gb/s, 11.1 Gb/s, Lineside Loopback Mode, XFI Loopback Mode,
        Vendor OUI: 00.01.9c
        Vendor Part Number JXP01TMAC1CX5TM3  (rev.: 00)
        Wavelength: 0.000 nm
        Wavelength Tolerance: 0 nm
        Vendor Serial Number: JFX1741A037
        Date Code  (yy/mm/dd): 13/10/07  lot code:
        Diagnostic Monitoring: FEC BER not supported, average Rx power measured,
        Enhanced Options: Soft TX disable, Soft Power-down, Active FEC control, Wavelength tunability,
        Extended Id: XFP-DWDM-TUNABLE (0x70 )
 MSA Data (Table 01)
0x0080: 0c 98 07 00 00 00 00 00 : 00 00 08 b4 63 71 50 00
0x0090: 00 00 00 9f 43 49 53 43 : 4f 2d 4a 44 53 55 20 20
0x00a0: 20 20 20 20 fb 00 01 9c : 4a 58 50 30 31 54 4d 41
0x00b0: 43 31 43 58 35 54 4d 33 : 30 30 00 00 00 04 46 4d
0x00c0: af 96 a8 a0 4a 46 58 31 : 37 34 31 41 30 33 37 20
0x00d0: 20 20 20 20 31 33 31 30 : 30 37 20 20 08 66 00 97
        CLEI Code: IP9IAGGCAB
        Part Number 10-2544-02  (ver.: V02 )
        Temp/Alarm/Power Flags: COM, commercial -5C to 70C
        Product ID: DWDM-XFP-C
 Cisco Specific Data (Table 02)
0x0100: 49 50 39 49 41 47 47 43 : 41 42 31 30 2d 32 35 34
0x0110: 34 2d 30 32 56 30 32 20 : 01 00 00 00 00 00 00 00
0x0120: 00 75 00 00 00 00 00 00 : 00 00 00 64 00 64 00 64
0x0130: 00 64 00 00 23 00 8c a0 : 37 2d 00 43 00 00 aa aa
0x0140: 44 57 44 4d 2d 58 46 50 : 2d 43 20 20 20 20 20 20
0x0150: 20 20 20 20 00 00 00 00 : 00 00 00 00 00 00 00 f7
0x0160: 34 34 32 37 34 37 00 1b : 00 57 4a 44 53 55 20 20
0x0170: 20 20 20 20 20 20 20 20 : 20 20 20 20 20 20 20 20
        Signal Condition Control: Normal Async REFCLK,
        Thresholds:                    Alarm High         Warning High          Warning Low            Alarm Low
              Temperature:               73.000                70.000                -5.000                -8.000
                  Voltage:           0.000 Volt            0.000 Volt            0.000 Volt            0.000 Volt
                     Bias:         85.000 mAmps          72.000 mAmps          10.000 mAmps           5.000 mAmps
           Transmit Power:  3.98110 mW (6.00003 dBm)   2.51190 mW (4.00002 dBm)   0.79430 mW (-1.00015 dBm)   0.50110 mW (-3.00076 dBm)
            Receive Power:  0.39810 mW (-4.00008 dBm)   0.25110 mW (-6.00153 dBm)   0.00160 mW (-27.95880 dBm)   0.00100 mW (-30.00000 dBm)
        Laser First Frequency: 191 THz, 950.000 GHz
        Laser Last Frequency: 196 THz, 0.000 GHz
        Laser Min Grid Spacing: 50.000 GHz
        Wavelength Control: setpoint=0.00 nm, error=0.00 nm
        FEC Control: amplitude_threshold=50.00%, phase_setpoint=50.00%
        Temperature: 29.195
        Voltage: 0.000 Volt
        Tx Bias: 0.000 mAmps
        Tx Power:  0.000 mW (<-40.00 dBm)
        Rx Power:  0.01370 mW (-18.63279 dBm)
        Control Status: Interrupt,  Tx not ready,
        Wavelength Channel: 0
        Wavelength Error: 0.000 GHz
 Digital Diagnostics Data (Lower Memory)
0x0000: 0c 00 49 00 f8 00 46 00 : fb 00 00 00 00 00 00 00
0x0010: 00 00 a6 04 09 c4 8c a0 : 13 88 9b 83 13 93 62 1f
0x0020: 1f 07 0f 8d 00 0a 09 cf : 00 10 00 18 ff e8 00 0c
0x0030: ff f4 00 00 00 00 00 00 : 00 00 00 00 00 bf 25 1c
0x0040: 00 c4 00 00 01 f4 00 00 : 00 00 00 00 00 00 00 00
0x0050: 00 10 00 10 80 20 00 00 : 00 00 00 00 00 00 00 00
0x0060: 1d 32 00 00 00 00 00 01 : 00 89 00 00 00 00 00 80
0x0070: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 02
RP/0/RSP0/CPU0:ott.kedc.pe2#sh controllers tenGigE 0/1/0/0 stat
Wed Dec 31 11:40:23.639 EST
Statistics for interface TenGigE0/1/0/0 (cached values):
Ingress:
    Input total bytes           = 0
    Input good bytes            = 0
    Input total packets         = 0
    Input 802.1Q frames         = 0
    Input pause frames          = 0
    Input pkts 64 bytes         = 0
    Input pkts 65-127 bytes     = 0
    Input pkts 128-255 bytes    = 0
    Input pkts 256-511 bytes    = 0
    Input pkts 512-1023 bytes   = 0
    Input pkts 1024-1518 bytes  = 0
    Input pkts 1519-Max bytes   = 0
    Input good pkts             = 0
    Input unicast pkts          = 0
    Input multicast pkts        = 0
    Input broadcast pkts        = 0
    Input drop overrun          = 0
    Input drop abort            = 0
    Input drop invalid VLAN     = 0
    Input drop invalid DMAC     = 0
    Input drop invalid encap    = 0
    Input drop other            = 0
    Input error giant           = 0
    Input error runt            = 0
    Input error jabbers         = 0
    Input error fragments       = 0
    Input error CRC             = 0
    Input error collisions      = 0
    Input error symbol          = 0
    Input error other           = 0
    Input MIB giant             = 0
    Input MIB jabber            = 0
    Input MIB CRC               = 0
Egress:
    Output total bytes          = 0
    Output good bytes           = 0
    Output total packets        = 0
    Output 802.1Q frames        = 0
    Output pause frames         = 0
    Output pkts 64 bytes        = 0
    Output pkts 65-127 bytes    = 0
    Output pkts 128-255 bytes   = 0
    Output pkts 256-511 bytes   = 0
    Output pkts 512-1023 bytes  = 0
    Output pkts 1024-1518 bytes = 0
    Output pkts 1519-Max bytes  = 0
    Output good pkts            = 0
    Output unicast pkts         = 0
    Output multicast pkts       = 0
    Output broadcast pkts       = 0
    Output drop underrun        = 0
    Output drop abort           = 0
    Output drop other           = 0
    Output error other          = 0
RP/0/RSP0/CPU0:ott.kedc.pe2#sh controllers tenGigE 0/1/0/0 int
Wed Dec 31 11:40:52.705 EST
Port Number         : 0
Board Type          : 0x00000237
Port Type           : 10GE
Transport mode      : WAN
BIA MAC addr        : e0ac.f12d.0f88
Oper. MAC addr      : e0ac.f12d.0f88
Egress MAC addr     : e0ac.f12d.0f88
Port Available      : true
Status polling is   : enabled
Status events are   : enabled
I/F Handle          : 0x020005c0
Cfg Link Enabled    : tx/rx enabled
H/W Tx Enable       : yes
MTU                 : 1518
H/W Speed           : 10 Gbps
H/W Duplex          : Full
H/W Loopback Type   : None
H/W FlowCtrl Type   : None
H/W AutoNeg Enable  : Off
H/W Link Defects    : (0x00000028)  HW_LINK LASI
H/W Raw Link Defects : (0x00000028)  HW_LINK LASI
Link Up             : no
Link Led Status     : Link down -- Red
Serdes hw version   : 0.4
Serdes sw version   : 8.0
Pluggable Present   : yes
Pluggable Type      : 10GBASE-TUNABLE
Pluggable PID       : DWDM-XFP-C
Pluggable Compl.    : Compliant
Pluggable Type Supp.: Supported
Pluggable PID Supp. : Supported
RP/0/RSP0/CPU0:ott.kedc.pe2#sh run controller dwdm 0/1/0/0
Wed Dec 31 11:41:55.596 EST
 wavelength 81
 network connection id 1
 network port id 1
RP/0/RSP0/CPU0:ott.kedc.pe2#sh run controller wanphy  0/1/0/0
Wed Dec 31 11:42:09.343 EST
controller wanphy0/1/0/0
 wanmode on
R2
RP/0/RSP0/CPU0:ott.mcdc.p1#sh controllers dwdm 0/1/0/0 optics
Wed Dec 31 11:45:55.186 EST
Optics Status
RP/0/RSP0/CPU0:ott.mcdc.p1#sh controllers dwdm 0/1/0/0 tdc
Wed Dec 31 11:46:01.549 EST
TDC Info
RP/0/RSP0/CPU0:ott.mcdc.p1#sh controllers dwdm 0/1/0/0 pm history optics
Wed Dec 31 11:46:12.161 EST
Optics in the current interval [11:45:00 - 11:46:12 Wed Dec 31 2014]
Interval: Valid
OPR[dBm]  :  -17.99   -17.93   -17.85   0.00       NO      0.00     NO
Optics in interval 1 [11:30:00 - 11:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.07    -17.93    -17.80
Optics in interval 2 [11:15:00 - 11:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.04    -17.93    -17.80
Optics in interval 3 [11:00:00 - 11:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.01    -17.93    -17.77
Optics in interval 4 [10:45:00 - 11:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.01    -17.93    -17.80
Optics in interval 5 [10:30:00 - 10:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 6 [10:15:00 - 10:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 7 [10:00:00 - 10:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 8 [ 9:45:00 - 10:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.04    -17.96    -17.85
Optics in interval 9 [ 9:30:00 -  9:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.07    -17.96    -17.83
Optics in interval 10 [ 9:15:00 -  9:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.07    -17.96    -17.85
Optics in interval 11 [ 9:00:00 -  9:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 12 [ 8:45:00 -  9:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 13 [ 8:30:00 -  8:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.07    -17.99    -17.83
Optics in interval 14 [ 8:15:00 -  8:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 15 [ 8:00:00 -  8:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.07    -17.96    -17.77
Optics in interval 16 [ 7:45:00 -  8:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.01    -17.96    -17.80
Optics in interval 17 [ 7:30:00 -  7:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 18 [ 7:15:00 -  7:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 19 [ 7:00:00 -  7:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 20 [ 6:45:00 -  7:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 21 [ 6:30:00 -  6:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 22 [ 6:15:00 -  6:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 23 [ 6:00:00 -  6:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.04    -17.96    -17.80
Optics in interval 24 [ 5:45:00 -  6:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.04    -17.96    -17.83
Optics in interval 25 [ 5:30:00 -  5:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.07    -17.96    -17.80
Optics in interval 26 [ 5:15:00 -  5:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.04    -17.93    -17.85
Optics in interval 27 [ 5:00:00 -  5:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.04    -17.93    -17.77
Optics in interval 28 [ 4:45:00 -  5:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 29 [ 4:30:00 -  4:45:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 30 [ 4:15:00 -  4:30:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 31 [ 4:00:00 -  4:15:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in interval 32 [ 3:45:00 -  4:00:00 Wed Dec 31 2014]
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
Optics in the current interval [00:00:00 - 11:46:12 Wed Dec 31 2014]
Interval: Valid
OPR[dBm]  :  -18.07   -17.96   -17.77   0.00       NO      0.00     NO
Interval: Valid
              MIN       AVG       MAX
LBC[mA ]  :   0         0         0
OPR[dBm]  :   -18.15    -17.96    -17.75
RP/0/RSP0/CPU0:ott.mcdc.p1#sh controllers ten 0/1/0/0 mac
Wed Dec 31 11:47:23.038 EST
 HW_LINK LASI
RP/0/RSP0/CPU0:ott.mcdc.p1#sh controllers ten 0/1/0/0 phy
Wed Dec 31 11:47:31.563 EST
XFP EEPROM  port: 0
        Xcvr Type: T-XFP
        Connector Type: LC
        Vendor Serial Number: JFX1830A006
        Date Code  (yy/mm/dd): 14/07/19  lot code:
 MSA Data (Table 01)
0x00c0: af 96 a8 a0 4a 46 58 31 : 38 33 30 41 30 30 36 20
0x00d0: 20 20 20 20 31 34 30 37 : 31 39 20 20 08 66 00 9c
        Temperature: 36.617
        Voltage: 0.000 Volt
        Rx Power:  0.01610 mW (-17.93174 dBm)
0x0060: 24 9e 00 00 00 00 00 01 : 00 a1 00 00 00 00 00 80
RP/0/RSP0/CPU0:ott.mcdc.p1#sh controllers ten 0/1/0/0 stats
Wed Dec 31 11:47:58.687 EST
Ingress:
    Input total bytes           = 214
    Input good bytes            = 214
    Input total packets         = 2
    Input pkts 65-127 bytes     = 1
    Input pkts 128-255 bytes    = 1
    Input good pkts             = 2
    Input multicast pkts        = 2
    Input error CRC             = 0
    Input MIB giant             = 0
    Input MIB CRC               = 0
Egress:
RP/0/RSP0/CPU0:ott.mcdc.p1#sh controllers ten 0/1/0/0 int
Wed Dec 31 11:48:26.347 EST
Port Number         : 0
Port Type           : 10GE
BIA MAC addr        : e0ac.f12d.0f58
Oper. MAC addr      : e0ac.f12d.0f58
Egress MAC addr     : e0ac.f12d.0f58
I/F Handle          : 0x020001c0
H/W Tx Enable       : yes
MTU                 : 1518
H/W Speed           : 10 Gbps
H/W Duplex          : Full
Link Up             : no
RP/0/RSP0/CPU0:ott.mcdc.p1#sh run controller dwdm 0/1/0/0
Wed Dec 31 11:49:16.861 EST
 wavelength 81
 network port id 1
RP/0/RSP0/CPU0:ott.mcdc.p1#sh run controller wanphy 0/1/0/0
Wed Dec 31 11:49:24.691 EST
 wanmode on
Paul Lachance
To correct the first error
R1
Wed Dec 31 11:20:36.563 EST
  Description: [trunk][10G TenGi0/1/0/0][ott.mcdc.p1][TenGi0/1/0/0][Itsb11xx kedc.roadm mcdc.roadm]
  Internet address is 192.168.0.01/30
  MTU 1514 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
  Encapsulation ARPA,
  loopback not set,
Paul Lachance
Update we may suspect that the cabling may have been crossed over to another circuit build that was under way. Cabling to Verify and report back. Will update with status when completed.
ok thanks for the update so far! let me know.
when it still doesn't work, the controller wan and controller teng all outputs would help me providing some extra suggestions.
cheers!
xander
From last update , cabling was going out to check our z site , it was found that the cabling was crossed with another build using the same lamba.
Once this was corrected the second link came up but ours did not. Troubleshooting found that the TX on the transceiver at the z end was -40
The dwdm transceiver was replaced and showed a 1.4 on the tx . Still the link did not come up . Troubleshooting found that the tx on the transceiver at the A end was -40
It was replaced yesterday and the link came up.
hi paul, thanks for the updates and good to hear that it is working in the end. sounds like some light saga you were facing there! like 3 ft of snow in an overnight :)
really cool to let us know that things are resolved!
cheers
xander
I'm having the same issue, but in my case I know the cabling is in place because the interfaces are connected directly to each other.  This is in a lab where I'm trying to verify the functionality of these optics.  The interface is sending and receiving light, but the 10G interface is still down/down.
RP/0/RSP0/CPU0:ASR9006-1-LAB#show run controller dwdm0/3/0/22
wavelength 50GHz-Grid update 1532290
network connection id 0/3/0/22
network port id 0/3/0/22
RP/0/RSP0/CPU0:ASR9006-1-LAB#show run controller dwdm0/3/0/23
network connection id 0/3/0/23
network port id 0/3/0/23
RP/0/RSP0/CPU0:ASR9006-1-LAB#show run controller wanphy 0/3/0/22
controller wanphy0/3/0/22
wanmode on
RP/0/RSP0/CPU0:ASR9006-1-LAB#show run controller wanphy 0/3/0/23
controller wanphy0/3/0/23
wanmode on
RP/0/RSP0/CPU0:ASR9006-1-LAB#show run int te0/3/0/23
interface TenGigE0/3/0/23
transport-mode wan
RP/0/RSP0/CPU0:ASR9006-1-LAB#show run int te0/3/0/22
interface TenGigE0/3/0/22
transport-mode wan
RP/0/RSP0/CPU0:ASR9006-1-LAB#show controllers te0/3/0/22 phy
PHY data for interface: TenGigE0/3/0/22
SFP EEPROM port: 22
Xcvr Type: SFP
Xcvr Code: 10GBASE-TUNABLE
Encoding: 64B66B
Bit Rate: 10300 Mbps
Link Reach 9u fiber (Km): 80000 meter
Link Reach 9u fiber (100m): 25500 meter
Vendor Name: TRANSPORTOPTICS
Vendor Part Number: DWDM-SFP10G-C (rev.: B1 )
Laser wavelength: 0 nm (fraction: 0.00 nm)
Optional SFP Signal: Tx_Tunable, Tx_Disable, Tx_Fault,
Vendor Serial Number: GDT391D32336
Date Code (yy/mm/dd): 17/10/25 lot code:
Diagnostic Monitoring: DOM, Int. Cal.,
Enhanced Options: SW RX LOS Mon., SW TX Fault Mon, SW TX Disable, Alarm/Warning Flags
MSA Data
0x0000: 03 04 07 00 00 00 00 00 : 00 00 00 06 67 00 50 ff
0x0010: 00 00 00 00 54 52 41 4e : 53 50 4f 52 54 4f 50 54
0x0020: 49 43 53 20 00 00 01 9c : 44 57 44 4d 2d 53 46 50
0x0030: 31 30 47 2d 43 20 20 20 : 42 31 20 20 00 00 00 93
0x0040: 05 58 0a 04 47 44 54 33 : 39 31 44 33 32 33 33 36
0x0050: 20 20 20 20 31 37 31 30 : 32 35 20 20 68 f0 05 79
0x0060: 70 00 11 61 5b ce ad b8 : 2c 09 62 90 de 43 59 dc
0x0070: f5 e5 38 00 00 00 00 00 : 00 00 00 00 0b 59 f0 91
Temperature: +75.000 C +70.000 C +0.000 C -5.000 C
Voltage: 3.630 Volt 3.465 Volt 3.135 Volt 2.970 Volt
Bias: 75.000 mAmps 70.000 mAmps 30.000 mAmps 25.000 mAmps
Transmit Power: 3.98100 mW (5.99992 dBm) 1.99520 mW (2.99986 dBm) 0.79430 mW (-1.00015 dBm) 0.31620 mW (-5.00038 dBm)
Receive Power: 0.50110 mW (-3.00076 dBm) 0.19950 mW (-7.00057 dBm) 0.00200 mW (-26.98970 dBm) 0.00080 mW (-30.96910 dBm)
Temperature: 34.984
Voltage: 3.229 Volt
Tx Bias: 50.000 mAmps
Tx Power: 1.08710 mW (0.36269 dBm)
Rx Power: 1.13780 mW (0.56066 dBm)
Oper. Status/Control:
EEPROM Memory (A2 lower)
0x0100: 4b 00 fb 00 46 00 00 00 : 8d cc 74 03 87 5a 7a 75
0x0110: 92 7c 30 d4 88 b8 3a 98 : 9b 82 0c 5a 4d f0 1f 07
0x0120: 13 93 00 08 07 cb 00 14 : 00 00 00 00 00 00 00 00
0x0130: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x0140: 00 00 00 00 3f 80 00 00 : 00 00 00 00 01 00 00 00
0x0150: 01 00 00 00 01 00 00 00 : 01 00 00 00 00 00 00 8d
0x0160: 22 fc 7e 20 61 a8 2a 77 : 2c 72 00 00 00 00 00 00
0x0170: 00 80 00 00 00 80 03 00 : 00 00 00 00 00 00 00 00
CLEI Code: IP9IATGCAA
Part Number: 10-3036-01 (ver.: V01 )
Temp/Alarm/Power Flags: COM, commercial 0C to 70C
Minimum Temperature: 0
Maximum Temperature: 70
Calibration Constants: LBC Scale, Temperature, Laser bias current, Output power,
Product Id: DWDM-SFP10G-C
EEPROM Memory (A2 upper)
0x0180: 49 50 39 49 41 54 47 43 : 41 41 31 30 2d 33 30 33
0x0190: 36 2d 30 31 56 30 31 20 : 01 00 46 00 00 00 00 c2
0x01a0: 00 00 00 00 00 00 00 00 : 00 00 85 99 8f 00 a8 3b
0x01b0: d4 4b 00 00 1e 00 0a 98 : 13 51 0f e2 00 00 aa aa
0x01c0: 44 57 44 4d 2d 53 46 50 : 31 30 47 2d 43 20 20 20
0x01d0: 20 20 20 20 20 20 20 20 : 20 20 20 20 20 20 20 9a
0x01e0: 14 1b 20 20 20 26 20 26 : 00 00 00 00 00 00 bf 03
0x01f0: e8 00 c4 05 dc fb 00 5c : ff ff ff ff 00 00 00 e2
Laser First Frequency: 191 THz, 100.000 GHz
Laser Last Frequency: 196 THz, 150.000 GHz
Wavelength Channel: 92
EEPROM Memory (A2 02 page)
0x0200: 07 00 00 00 00 bf 03 e8 : 00 c4 05 dc 01 f4 00 00
0x0210: 00 5c 77 b6 00 00 00 00 : 00 04 00 00 00 00 00 00
0x0220: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x0230: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x0240: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x0250: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x0260: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
0x0270: 00 00 00 00 00 00 00 00 : 00 00 00 00 00 00 00 00
RP/0/RSP0/CPU0:ASR9006-1-LAB#show controllers te0/3/0/23 phy
PHY data for interface: TenGigE0/3/0/23
SFP EEPROM port: 23
Xcvr Type: SFP
Encoding: 64B66B
Vendor Serial Number: GDT391D32335
MSA Data
0x0040: 05 58 0a 04 47 44 54 33 : 39 31 44 33 32 33 33 35
0x0050: 20 20 20 20 31 37 31 30 : 32 35 20 20 68 f0 05 78
0x0060: 70 00 11 89 f5 ec 26 6d : d9 d9 bb 83 75 7a 81 2e
0x0070: 71 97 84 00 00 00 00 00 : 00 00 00 00 24 c6 b8 30
Temperature: 34.457
Voltage: 3.241 Volt
Tx Power: 1.07640 mW (0.31974 dBm)
Rx Power: 1.10900 mW (0.44932 dBm)
0x0160: 22 75 7e 9e 61 a8 2a 0c : 2b 52 00 00 00 00 00 00
0x0210: 00 5c 77 b6 00 00 00 00 : 00 03 00 00 00 00 00 00
RP/0/RSP0/CPU0:ASR9006-1-LAB#show controllers dwdm 0/3/0/22
Port dwdm0/3/0/22
VTXP Monitor : Disabled
G709 Status : Disabled
RP/0/RSP0/CPU0:ASR9006-1-LAB#show controllers dwdm 0/3/0/23
Port dwdm0/3/0/23
RP/0/RSP0/CPU0:ASR9006-1-LAB#show controllers dwdm 0/3/0/22 optics
Optics Status
Optics Type: 10GBASE-TUNABLE
Wavelength Info: C-Band, MSA ITU Channel=10, Frequency=195.65THz, Wavelength=1532.290nm
Wavelength Owner: Configuration, ITU Channel: GMPLS Signaled=None, Configured=10, Hardware Default=84
TX Power = 0.36 dBm
RX Power = 0.55 dBm
RP/0/RSP0/CPU0:ASR9006-1-LAB#show controllers dwdm 0/3/0/23 optics
Optics Status
TX Power = 0.31 dBm
RX Power = 0.44 dBm
Can you tell what I'm missing here?
