Showing results forĀ
Search instead forĀ
Did you mean:Ā
configuring ipv6 multicast routing with VRFs
marhifer2003
I want to activate ipv6 multicasting on a ASR9k router but I get the following error when I commit the configuration:
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted. Please issue 'show configuration failed' from this session to view the errors
RP/0/RSP0/CPU0:Router(config-pim-ipv6-if)#show configuration failed
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
multicast-routing
address-family ipv4
address-family ipv6
vrf VPN1
address-family ipv6
   interface TenGigE0/0/0/2.122
!!% A SysDB client requested a function that the server or EDM does not currently support: Command not supported on this platform
    enable
router pim
vrf VPN1
  address-family ipv6
    enable
Could anyone help me??
Thank you in advance
Ivan Krimmel
Level 7
Level 7
mVPNv6 is not yet supported.
Hope that clarified,
Ivan.
Ivan Krimmel
Level 7
Level 7
Ivan.
Ivan,
Thank you for your answer.
I have read this in Realese Notes 4.2
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.2/general/release/notes/reln_a9k_42.html
Multicast VPN
Cisco IOS XR Software Release 3.9.1 added support for the  Multicast VPN feature. (For IPv4 address family only - MVPNv6 is not supported  on the Cisco ASR 9000 Series Aggregation Services Routers in  Cisco IOS XR Software Release 4.2). For more information on this feature, refer  to the Cisco ASR 9000 Series Aggregation Services Router  Multicast Command Reference and the Cisco ASR 9000  Series Aggregation Services Router Multicast Configuration Guide online.
Thank you again!
